Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Scanner When I try to scan a document it comes up with "no scan option". The printer is 5 months old and when I got it the scanner did work but has not for about 3 months.
  • 234 Answers
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution (if not got to Start> All Programs> HP> HP Solution Center) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Posted on Sep 11, 2008
Where is the scan button and how do I start it?
Try this steps:
1. Load the document in your printer/ copier/scanner
2. On your computer, click on start (the windows logo button)
3. From the pop-up menu, click on Devices and Printers
4. From the window that opens, right-click on the printer/ scanner you loaded the document and click on the options for scan. (Make sure it is checked as the default printer)
5. A dialogue box will pop up options for you to choose and scan your document. It will be saved to a folder in the documents My Scans. Does this help?
Aug 05, 2014 | Canon PIXMA MG2520 Inkjet All-in-One...
How do i scan?
Dallis,
1. Please power on the scanner.
2. Place the document to be scanned in the scanner face down and close the lid.
3. Start the word processor.
4. In the File menu you will find an option to either scann a document or Import from scanner. Use this and start the Scan Document.
5. First you will get a rough scanned image. Set it right for everything to be scanned by using a dotted rectangle on the scanned image. Once that is done, then use the SCAN option and you will get the final scanned image.
6. Save it to a folder.
Feb 08, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Printer works just fine, but scanner no longer has option to scan
Hi ,
  • Unplug the Scanner cable from the computer.
  • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the Scanner.
  • then you can connect the Scanner and and try to Scan.
Hope this help. Please Rate My Response! Thanks!
Aug 19, 2009 | HP Photosmart C4280 All-in-One InkJet...
No scanning option in my HP office jet 5610 All in One
I had the same problem for months. I couldn't solve it but found a work around. Place the document to scan in the scanner.
Open MS Paint (Start/Programs/Accessories/Paint). Click on File in the menu bar, then from Scanner or Camera. It scans!
Aug 17, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i setup the scanning part?
hiii
You can perform following step:=====
1.Insert the document you want to scan into your scanner.
2.Click Start, click All Programs, click Accessories, and then click Scanner and Camera Wizard
3.The Scanner and Camera Wizard appears. Click Next.
4.In the Choose Scanning Preferences page, click the Picture type option that best matches the paper you are scanning, and then click Next
5.In the Picture Name and Destination page, type a name for your image, select JPG as the file format, and select the folder where you would like the scanned image to be saved. Click Next.
6.Windows XP scans your document. On the Other Options page, click Nothing. Then, click Next.
7.On the Completing the Scanner and Camera Wizard page, you can view your scanned document by clicking the link shown. If you are not satisfied with the results, click Back to return to the Choose Scanning Preferences page, adjust your settings, and try your scan again. Repeat until you are satisfied. Click Finish to close the wizard and open the folder containing your scanned document.
Jul 28, 2009 | HP Officejet 4315v All-In-One InkJet...
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
How to use the scanner on my Epson 60000
there are different type of scannig programs. I am not that particular with your epson scanner. You can try scanning the document and if you want to archive it you can try choosig the option of file type as compressed tif. If you do not have this option there would be times that scanning software will have the preview of the document you have scanned and will asked you if you want to reduce or enlarge size. If resizing option is not available in your scanner software you can try saving it first in your computer. After saving the document try to open microsoft word and create a new file. Then look for the document you have scanned and copy that document. Once you have copied it go back to microsoft word and paste the documet. you could now resize the document manually. but for further clarification you can try calling your scanner provider. they might have some programs for it and will give it to you
Nov 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
HOW TO SCAN ON HP PSC 1315
i have a Vista system and an old hp 1315. the CD driver that came with it includes some very useful software that cannot be installed in my laptop. according to the hp website, that's because Vista comes with a compatible software for my hardware. checking Windows Help & Support gave me this solution:
Open to Windows Photo Gallery, click File then click Import from Camera or Scanner.
i did exactly that and it worked!
i hope this was of some help.
Jan 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
Scanner doesn't work
If you've tried the printer on different PCs and still didn't work looks like there is something wrong with the scanner internally. When you start the scanner fresh, the scanning light has to move up and down the glass if it doesn't may be something is stuck on the mechanism open it and check for lose cables or dirt. Other option will be that If you bought it on the last 11 months try send it for "Manufacturer's Warranty Repair" you can call HP costumer service and ask them where you can send your unit for service, make sure you use a traceable method and keep records. Or take it to the nearest dealer and have them look at it.
Aug 26, 2007 | HP PSC 2410 All-In-One InkJet Printer
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
107 people viewed this question
Seeker5211
Seeker5211
