Question about LG WM-1832C Front Load Washer
Whirlpool Stylemaster 4214164
My washer is 15 years old and in otherswise great shape but it no longer runs properly through the cycles. Each cycle will come on, but like during the wash cycle (any of them), the machine fills up and sits for several minutes and either trys to start agitating and stops or will only agitate for a minute or so and then drain. Then re-fill to rinse but never agitates during the rinse and then drains & spins. So, soapy residue is left behind. I believe the timer is bad but want to be sure before I attempt to replace it. The reason I believe this is because if I go around the knob in an attempt to get agitation, I can get it to agitate. It just doesn't do the run through of a complete wash cycle without manual help from me.
jsrock516
  • 5911 Answers
SOURCE: Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
Posted on Jan 25, 2008
SOURCE: When to know if the motor is going out ?
This fix below completely fixed my LG front loader issue of the drum "freezing" and "studdering" on fill and a lot of times giving a LE (motor overload) error. Bought position sensor as described and doing a load right now!
Wolfster you are awesome...you saved me probably $200.
Definitely sounds like the position sensor is faulty. I had this happen to my WM2277HB recently. Motor would start to turn, then jerk, hum, and not move, eventually gives LE code. Powering down, all the other tips had no effect. Very unlikely that the motor itself is bad if it still turns freely. You could confirm the stator wiring is OK by unplugging it and taking resistance readings across the stator terminals of the 3-pin connector (any combo of two should be 7-15 ohms). I was able to order the part from an online electronics supplier (www.mcminone.com, P/N 6501KW2002A, description is "sensor assembly") and several other places may have it as well. You can download a basic but somewhat helpful service manual here http://136.166.4.200/contents/Laundry/WM2277.htm that has some disassembly instructions and exploded view diagrams, explains the troubleshooting mode. Don't even bother calling LG or a service tech unless it's under warranty. If you're here you probably have some basic repair skills and tools4.gif and can easily replace it yourself for about $20. My washer was about a year and a half old when the sensor went out, now it runs great again.
Posted on Dec 18, 2007
SOURCE: Washing Machine will not agitate
how to take off agitator
Posted on Feb 10, 2008
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
tzweeb
  • 318 Answers
SOURCE: kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Posted on Jan 31, 2009
How do I take the whirlpool washer cabnet off?
Earlier whirlpool tubs had 4 screws under rubber plugs that unfortunately rusted if you manage to get them out then the complete top lifts of the base section
later models just prise apart as they have eliminated the screws
there are manuals on line to download
Apr 09, 2015 | Whirlpool Washing Machines
Why does my GE washer get stuck in Drain cycle??
for one G.E not a good choice mostly junk. the timer may indeed be bad if its sticking at 1 point and u can move it manually?
Feb 27, 2015 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
Why is my washer making loud knocking sounds?
the bearings may need to be changed
Aug 18, 2014 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control locked, how do I unlock it. I can't start the washing cycle.
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
OR press options and select for 10 secs till LOC is no longer displayed
Apr 03, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have a 15 yr old Whirlpool washer that has run great. During a cycle, it stopped full of water. I moved the dial around to different areas pushing it in and out and got a cyle to run long enough to pump...
Not always a Timer issue. could be stopping at the cold fill part of the cycle which is the 8 o clock position on the dial. This would be fault with the cold fill vavle.
Sep 15, 2010 | Whirlpool LXR6432JQ Top Load Washer
Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Wife just told me this
try a new drain pump make sure there is no foriegn objects in there
Mar 27, 2008 | Washing Machines
LG WM-1832C Front Load Washer Logo
2,073 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
