The driver that ships on the CD with Casio CTK-810IN keyboard is not compatible with Windows Vista 64bit. What do I need to do to the laptop to make the driver work?
You can play back standard MIDI files from the SD card slot, or load them into memory via USB. However, it is not possible to add new tones or rhythms.
Make sure the driver is compatible with your operating system... often stuff will not work with Vista for example. Often SOME software REQUIRES it to be installed before USB cable is connected, and yet other requires it not be connected till software is installed... read the manual...
Vista has SO MANY compatibility problems that it MAY be futile to try finding a specific driver for thaat synth. Consider going to Windows 7. HOWEVER, a MIDI driver is a MIDI driver and anything specific to the synth is really not truly just a driver as such, but a user interface type program that may contain things like voice editors and other functions specific to the synth.
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
Hello - I am too a personal owner of a CASIO CTK keyboard, a little older than yours (model CTK-601) a great keyboard BTW, and I have connected it to my computer successfuly.
There are 2 ways of connecting the keyboard to your PC......Using the MIDI outputs and a special MIDI to gameport adapter - if you have a very old system and have a joystick port (D-sub shape) on your soundcard or PC, then you use that cable. Of course this is legacy and stopped existing in newer computers, now USB is used.
Only the professional line of soundcards have direct MIDI inputs. For most of us, with consumer soundcards and PCs, there are no MIDI inputs.
The good news is that newer keyboards support USB MIDI and features direct USB connection - so all you have to do is install the drivers that are provided with your keyboard, usually a CD, and follow the instruction to install the USB drivers for your casio keyboard, BEFORE you plug in the cable (very important!) once installed you reboot and connect your keyboard using a USB cable
Now if your keyboard is older and has MIDI outputs, like mine for example, you will need to purchase a MIDI to USB adapter, those have MIDI cables in one end that plug to your keyboard and the other end a USB connector....... I don't know about the rules if I am allowed to post websites, but the product i'm using is the Uno from M-Audio - in google do this search:
"m-audio"uno
(exactly as shown above with quotes, and uno outside quotes)
Your CTK-810 may alreayd have a USB connector on it, as it is a newer generation keyboard - I am pretty sure it does - what you will have to do as stated above is located your bundled CD-ROM and install the USB drivers - you will need to purchase a USB cable (seperately).
