Question about RIM BlackBerry 8700g Smartphone
BlackBerry 8700c Hang-up
I am using Cingular BlackBerry 8700c.I downloaded skype into my Device.After downloading the device fails to restart and the cursor is rotating on the screen for more than 12 hours. Can u please give me a solution ?
  • Khoo73 Dec 02, 2008
    I installed two software using desktop manager and suddenly a message prompt: Fatal error when installing. The hourglass icon has been spinning for some time> i tried to take out the battery for an hour and it didnt work
  • findit_fast May 11, 2010
    the problem is with a bb 8700 why are you giving instructions on a palm?
  • 2,071 Answers
Try to take the battery first and leave it for 3 hours and put it back again,and try to check if the screen respond in tapping if still not working then do some reset procedure...
Soft Reset
A soft reset tells your handheld to stop what it's doing and start over again. All records and entries stored in your handheld are retained with a soft reset. After a soft reset, the Welcome screen appears, followed by the General Preferences screen.
Use the reset tip tool (see below), or the tip of an unfolded paper clip (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your palm handheld.
Reset Tip Tool: On most PalmOS handhelds, the stylus that comes with your handheld has a reset tip inside. To use it, unscrew the barrel from the stylus quill.
Double-Soft Reset
If your device doesn't seem to want to power up after a soft reset, and you've checked the other obvious solutions (fresh batteries, power button, contrast wheel, contrast button) you may want to try the 'Double-Soft Reset'. Simply perform a soft reset as directed above, but press the reset button twice in quick succession.
Warm Reset
A warm reset bypasses any system extensions (such as HackMaster hacks, OS patches, Alarm settings, etc) that are loaded on your handheld. Sometimes a damaged third-party application will try to respond to a reset but will fail and cause the handheld to 'hang'. Using a warm reset, you can start the handheld, then delete the damaged application before it has a chance to try to run again. After deleting the application, follow with a soft reset to start up the handheld normally.
To perform a warm reset:
  1. Press and hold the upper half of the scroll button on your handheld.
  2. Using the reset tip tool (or a similar object without a sharp tip), gently press the reset button inside the hole on the back panel of your handheld.
  3. When the Palm Computing Platform logo appears on the screen, release the scroll button.
If you're not sure which application is damaged, you can use a tool like ResetEmu in conjunction with a warm reset to help pinpoint the offending application.
Hard Reset
With a hard reset, all records and entries stored in your handheld are erased, except for the default or specimen databases predefined by the manufacturer (but see Extended Hard Reset below). Formats Preferences and other settings are restored to their factory default settings. You can restore any data previously synchronized with your computer during the next HotSync operation. If you're running OS 3.1 or earlier, and you're not using a third-party backup utility like BackupBuddy, you may need to reinstall your third-party applications.
Never perform a hard reset unless a soft or warm reset does not solve your problem.
To perform a hard reset:
  1. Hold down the power button on the front panel of the handheld.
  2. While holding down the power button, use the reset tip tool (or similar object without a sharp tip), to gently press the reset button inside the hole on the back panel of your handheld.
  3. Release the reset button.
  4. When the logo screen appears on the screen, release the power button.
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press the upper half of the scroll button on the front panel of the handheld to complete the hard reset and display the Digitizer screen.
Pressing any other button instead of the upper half of the scroll button will perform a soft reset.
Extended Hard Reset
An Extended Hard Reset will completely erase your handheld, and will also bypass the creation of some default databases.
This differs from a normal hard reset, which will automatically create the databases for the built-in applications, and will insert some specimen records into those databases: numbers for Accessories and Technical Support will be created in your Address database, a registration reminder will be created in your ToDo database, and several helpful memos will be created in your Memo database.
In addition, a normal hard reset will also create a Network database with some default Network profiles for your Network panel in Prefs, and a file of several default MIDI alarm sounds will be created.
If you have the Notepad application, a normal hard reset ensures a sample note will appear on your NotePad, and if you have the Mail application, an email message from 'Mail Help' will be automatically inserted in your handheld Inbox.
An Extended Hard Reset will ensure that all of these startup files are not created.
If you decide to perform an Extended Hard Reset and install one or more third-party applications that expect to see the built-in databases present, you may encounter an error. For this reason, it's suggested that after an Extended Hard Reset, you run each of the built-in applications (Datebook, Address, ToDo, Memo, and if installed, NotePad and Mail) at least once to ensure empty built-in databases are created.
After an Extended Hard Reset, you will not be able to select alternate alarm sounds for Datebook alarms, but the default alarm sound will still be heard for appointments with alarms set.
To perform an Extended Hard Reset:
  5. When the message appears on the handheld screen warning that you are about to erase all the data stored on your handheld, press and hold the upper half of the scroll button on the front panel of the handheld.
  6. While still holding down the scroll button, press, in any order, the Datebook button, the Address button, the ToDo button, and the Note/Memo button.
  7. Release the scroll button, to to complete the hard reset and display the Digitizer screen.
Pressing some but not all the buttons while holding the scroll key will result in a normal soft reset. Pressing no buttons while holding the scroll key will result in a normal hard reset.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 04, 2008
Im just trying to use a blackberry 8700c cingular to t mobile but i dosent recognize the sim card what can I do?
Get the phone unlocked. cingular can give you the code, or you can buy one online. It should be just fine after that.
Sep 07, 2010 | RIM BlackBerry 8700c Cellular Phone
I need the unlock code for a cingular blackberry 8700c so i can use it with tmobile
YOU CAN VISIT HERE. GIVE YOUR IMEI NUMBER AND GET YOUR BLACKBERRY 8700C UNLOCK CODE . AFTER GETTING YOUR UNLOCK CODE. YOU CAN USE YOUR BLACKBERRY 8700C TO ANY NETWORK WORLD WIDE. I HOPE THIS WILL HELP YOU.
Sep 04, 2010 | Motorola Mobility SLVR L7 Cellular Phone
If i buy a blackberry 8700c for cingular or att
Yes you can.
I am currently using my blackberry in Portugal although I bought it in the UK.
If the telephone is really unlocked you could insert any SIM card from any carrier.
Hope it helped.
Nov 18, 2009 | RIM BlackBerry 8700c Cellular Phone
Can u switch blackberry 8700c thats on cingular network to nextel network that will work with boost mobile
YES PROVIDED HANDSET IS UNLOCKED.
FOR THE SAME YOU NEED TO CONTACT YOUR SERVICE PROVIDER FOR YOUR UNLOCK CODE.
AFTER UNLOCKING THE DEVICE YOU CAN SWITCH TO DIFFERENT SERVICE PROVIDER.
Oct 27, 2009 | RIM BlackBerry 8700c Cellular Phone
507 error, BB Desktop & Device issues, PC connect issues, Loader?
First, download and install the latest version of BlackBerry Desktop Manager software (5.0.1) from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
then, download and install the latest Handheld Software for your model then open Desktop Manager and run the application loader once the USB cable is connected to the device. 8700 Software located here https://www.blackberry.com/Downloads/contactFormPreload.do?code=1905AEDAB9BF2477EDC068A355BBA31A&dl=B0B9CBB64182F79C8C4590A0001FC049
Just fill out the form and the software download is free.
May 11, 2009 | RIM Blackberry 8700c
Unlock 8700c blackberry
Enter a Unlock code, goto - Blackberry 8700c (Cingular) Unlock
hope this may help;
Aug 26, 2008 | RIM BlackBerry 8700c Cellular Phone
Unlock Blackberry 8700c
hi all! i have a blackberry 8700c... it can't connect network..
status : No service. help me.. i'm in vietnam.
mail : thanhtu1234@yahoo.com
May 01, 2008 | RIM BlackBerry 8700c Cellular Phone
Unlock my BB 8700c???
need to unlock my Blackberry 8700r locked to Rogers. what should i do?
Feb 19, 2008 | RIM BlackBerry 8700c Cellular Phone
Blackberry 8700c
You maybe able to request thru cingular if that is your provider to unlock the phone. If it shows cingular it was a cingular phone.
Jan 26, 2008 | RIM BlackBerry 8700c Cellular Phone
BlackBerry 8700c Can be easily unlocked using remote IMEI MEP unlock code, you can purchase a code online and within seconds you can unlock your phone. Here is a good search result for BlackBerry 8700c Unlock code from google, I recently used this service and it was overall a good experience.
Oct 24, 2007 | Samsung SYNC SGH-A707 Cellular Phone
RIM BlackBerry 8700g Smartphone Logo
1,398 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
