Question about Konica Minolta DiMAGE A200 Digital Camera
The shutter speed cannot be set to 1/3200 second both in M and S mode. How can I set it to 1/3200 second?
    Master:
  • 425 Answers
The speed, 1/3200 sec. is the highest when the aperture is used. As a condition, it is controlled only when the aperture is F8 or over in P/A mode. The highest speed in S and M mode is 1/1600 sec.
Posted on Sep 15, 2005
SOURCE:
I have a Nikon D40 and when it's in M and S mode the shutter stays open for too long and my pictures come out completely white.
What shutter speed(s) are you using? What happens when you use a faster shutter speed? In the S and M modes you are responsible for setting the shutter speed, and you can set it to anything within the camera's range.
Aug 28, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
How do I change the shuuter speed on my A550 power shot canon camera
Since there is no shutter or aperture priority mode on the A550, the shutter speed is predetermined by the shooting mode. You can try changing the ISO speed when in a certain mode, but the camera may compensate by changing the aperture setting rather than the shutter speed. You'll have to experiment.
You can place the camera in Long Shutter Mode, however, when you want exposures times between 1 and 15 seconds. You set that by pressing the Function menu and Func. Set button when in [Camera icon]M mode, then using the < and > buttons to cycle through the long shutter settings.
Hope this helps!
Mar 10, 2011 | Canon PowerShot A550 Digital Camera
I mounted the Canon 580EX II to my Canon 5D Mark II. When I using Manual Mode, I can't set the shutter speed more faster then 1/200 sec. Is this problem normal/limitation of it?
Yes. If you were able to set a faster shutter speed, then you would not expose the entire frame and would have the shadow of either the first or second shutter curtain (or both) partially masking the frame.
At higher speeds, the shutter is never fully exposed: before the first shutter curtain has finished travelling across the frame, the second one has stated it's journey. All SLR's have this issue and on some older models you could only use a maximum 1/60th of a second.
In practice though, in dark conditions the "slow" shutter speed does not affect exposure as the true exposure will be determined by how much light the flash puts out, and it puts this light out in as little as 50 microseconds (50 millionths of a second) for a modern electronic flash bulb.
Faster shutter speeds can be used successfully, but only with flashes which operate in high speed mode. What they do is to make the flash burst seem longer by rapidly firing the flash bulb many times. This trick can ensure that there is sufficient light to expose the frame at the highest shutter speeds. Shutters which operate at, say, 1/4000 may seem fast, but compared to the speed at which a single electronic flash burst operates, it's an eternity.
May 11, 2010 | Canon Speedlite 580EX II TTL Flash
My Rebel XT automatic sport mode photos are all blurry. I noticed that the shutter speed only reads around 13. There is also a pause indicating a slower shutter speed. Any suggestions?
There isn't enough light for that scene. 1/13th of a second is the fastest at that ISO (automatically set by camera in Basic Mode) and Aperture (auto set by camera too, in Basic Mode) that the camera can handle to provide a reasonably exposed image. Try using Tv on the Mode Dial, set a higher ISO (trade off is image noise) of around 800-1600 or even 3200 if available on your camera. Set shutter speed at 200-1000 (1/200th to 1/1000th of a second) and see if it freezes your subject. An external flashlight with hi-sync mode would help in this situation if the subject is not too far away.
Dec 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Shutter speed
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
Apr 12, 2009 | Nikon N55 35mm SLR Camera
Power Shot A75
Of course it does, it has full manual control (M), but may I suggest first trying "shutter priority" (Tv). This mode lets you set shutter speed up to 15 seconds, but it automatically sets the aperture to match the shutter speed that you set. Merely turn the mode dial to Tv, then use the right/left buttons to select the shutter speed.
Now before pressing the shutter button, may I also suggest that you use the camera's shutter delay timer to take the picture (this will eliminate any shake from you pressing the button). Just press the function button to bring up the menu. then find the timer setting (try 2 seconds).
Here's where you can download your camera's user manual if you want to read more on what your camera can do:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=221&modelid=9828#DownloadDetailAct
Jul 19, 2008 | Canon PowerShot A75 Digital Camera
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Dark Pictures
I've tried some night shots, and I would either adj the exposer compensation level, or you can lower the ap value witch would increase the diaphragm opening. try this out and tell what you get. I believe you can adjust your iso settings, too much you might get some digital noise.
Aug 31, 2005 | Canon PowerShot G5 Digital Camera
Interlace Scan (IS) mode and the Progressive Scan (PS)
The Interlace Scan (IS) mode the camera uses a mechanical shutter with shutter speeds up to 1/640th second. It also uses the maximum resolution that is possible with the CCD (5.0 MP). In the Progressive Scan (PS) mode the camera operates with the electronic shutter with shutter speeds up to 1/4000th second and a 1/18000 second shutter speed (1/18000 in Shutter or Manual Priority modes only). In this mode the resolution is reduced in half (2.5 MP).
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Konica Minolta DiMAGE A200 Digital Camera Logo
54 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
