Question about Hoover H130E Front Load Washer
Hoover nextra optima HNL 6166
Hi guys, when doing a wash it will not drain, I cant find the log book so please help where to check etc.
cheers
  • Hoover Master
  • 19,396 Answers
Nextra6.will only go on 40min wash and only spin on slow spin. checked motor brushes and there fine. is it the circuit board
I have a hoover optima 1400AAA, it began to give trouble with programs, 40 degrees washed at 80 degrees, would not spin or empty, etc, called in a hoover repair man who cost me 120euros to remove the program knob and spray the contacts with Servisol super 10 switch cleaning lubricant, apart from the fact that I am still furious, everyone who has a hoover washing machine should know this.
Mar 21, 2012 | Hoover Nextra HNL 3166 Z Front Load Washer
HNL 3146 WILL NOT EMPTY AT END OF WASH
Hi davebmail,
It could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover nextra washing machine model hnl 6166. how do i replace noisy drum bearings
If you are mecahical inclined look up the model and seriael
# on the web. ask them to send you a book of maitence on it and this should show you how and where the bearings are and where to get new and how to replace them.
May 10, 2011 | Hoover Washing Machines
Hi the belt on our hoover hnl 6166 nextra will not stay on. The motor and the drum seem to be out of alignment and there are no broken screws or bolts or wobbles. Any ideas please? Thanks Robert.
I would suggest that the drum is out of alignment because the main bearings have failed, or the drum shaft has collapsed due nto corrosion.
Spin the drum by hand, and listen for any noise, there should not be any, and see if the drum rotates centrally in relation to the outer drum
Feb 02, 2011 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover HNL 662. 'Delay start' light comes on and stops machine
my hoover nextra hnl 662 want wash or spin and the delay staart light flashes 5 times please help iv only had the machine a year and had nothing but trouble with it wouldnt recomend one of these washing machines to anyone jakki
Feb 16, 2010 | Hoover Nextra HNL 3166 Z Front Load Washer
How do you remove the filter for a Hoover washing machine Optima Nextra Model HNL 6166?
I included a link on Youtube to my Nextra where I show how I clean the filter (watch it from 08:55 onwords). Just remove the kick strip and unscrew (philips screwdriver needed) the little screw on the filter itself, then turn it anti-clockwise but while you're doing this make sure you insert the kick strip underneath to gather the residual water. Repeat this operation 3 o 4 times until the sump is totally empty, make sure you don't let the kick strip fill up too much otherwise you'll be spilling water all over the place, so just turn the filter clockwise everytime you want to stop the trickle of water. It's not too complicated and it won't be too messy if you follow these instructions carefully. Good luck ;-)
Oct 25, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Washing machine
Hoover washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 19, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Jan 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Flashing stop light
have you tryed unplugging it for 5 minutes to see if it resets itself?let me know-mike
Oct 31, 2008 | Hoover Washing Machines
Hoover H130E Front Load Washer Logo
1,097 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
