Dell 1815dn All-In-One Laser Printer Logo
Posted on Aug 10, 2011
How to Determine the Printer Total Page Count on a Dell 1815dn laser printer?
Brian Hogue
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Nov 10, 2015
Brian Hogue
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
9371
Points
22
Press the scroll button <--- highlight menu,
select (checkmark)
scroll to Reports, select
scroll to system data, select
Print out will contain the page count
5 Related Answers
Coss
  • 1056 Answers
  • Posted on Aug 11, 2008
SOURCE: Dell 1815dn all-in-one-laser
There is a little tab that locks the scanner bar.
Open the flatbed cover, and you'll see it in the left corner closest to you.
To unlock it, reach your hand (palm up) into the area the the paper comes out in.
Slide the tab to the unlock position (you'll be able to see it through the flatbed area.
If you need a complete manual for the MFP, you can go to the Dell website, in the support area, and download a copy of it.
Anonymous
  • 5158 Answers
  • Posted on Jan 29, 2009
SOURCE: Misplaced User Manual - Dell 1815dn Laser MFP
drivers and software are here
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WLH&osl=en&catid=&impid=&SystemID=PRN_ALL_1815DN
manual is here
http://support.dell.com/support/edocs/systems/prn1815/en/index.htm
Robert
Please take a moment to rate this solution thanks
Anonymous
  • 135 Answers
  • Posted on Apr 21, 2009
SOURCE: How to determine printer page count
that model of HP printer did not have a page counter that could be printed
Anonymous
  • 122 Answers
  • Posted on Jun 22, 2009
SOURCE: front door open message it won't print
There is a switch inside the front door that is not making contact when the door closes, making the printer think that the front door is open. The switch is recessed in the housing. Look for a plastic knob that protrudes from the front door that will mate with a hole in the frame. Inside this hole is the switch. Try activating the switch manually with a screwdriver to make sure the switch is functioning. If it is, you will need to take off the cover and reposition the switch forward. If it does not activate manually, the switch must be replaced.
Anonymous
  • 9 Answers
  • Posted on Aug 22, 2009
SOURCE: scanner locked printer dell laser mfp 1815dn
The lock for the scanner is on the roof of the cavity where the printed paper comes out. Simply flip it to the other position and restart the printer.
How can I get it to print the ip address to hook it to my computer
Dell Laser MFP 1815dn configuration page
To print a configuration page (also called system data report) from a Dell Laser MFP 1815dn printer:
- Press the right arrow button until Menu is the active choice on the screen
- Press the check mark button to select it
- Press the right arrow button until Reports is the active choice
- Press the right arrow button until System Data is the active choice
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/larry_1fe25e09c54eece2
Dell 1815dn jam in automatic document feeder on last page.
Message saying document Jam but can't find any paper stuck anywhere. Do you have any suggestions?
16helpful
Scanner locked printer dell laser mfp 1815dn
5helpful
2answers
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
Dell 1815dn says Open Heat error. How do I determine if the fuser or the power supply is the problem?
This is usually a problem with the fuser. Iteminc.com has these in stock and ships same day. Hope this helps any1 with this error. Good luck!
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
