Question about Refrigerators
Ambient switch when do you use it - Refrigerators
    President:
  • 1,462 Answers
Use it in winter if appliance is in a cold area
Posted on Sep 04, 2008
2006 grand Prix the drl stay on and will not go off if they do go off the come back on with nobody around the car keeps running the battery dead ????? Ready to burn it
Daytime Running Lamps (DRL)
The ambient light sensor is used to monitor outside lighting conditions. The ambient light sensor provides a voltage signal that will vary between 0.2 and 4.9 volts depending on outside lighting conditions. The body control module (BCM) provides a 5-volt reference signal to the ambient light sensor. The ambient light sensor is permanently grounded at ground G202. The body control module (BCM) monitors the ambient light sensor signal circuit to determine if outside lighting conditions are correct for either daytime running lights (DRL) or automatic lamp control (ALC) when the headlamp switch is in the AUTO position. In daylight conditions the BCM will command the low beam headlamps ON at reduced intensityy. Any function or condition that turns on the headlamps will cancel DRL operation.
There could be a DTC stored in the BCM pointing to a problem !
DTC B2645 Ambient Light Circuit
Turn the headlamp switch to the OFF position.
Do the low and high beam headlamps remain OFF?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 3
Remove the appropriate low or high relay.
Do the lamps turn OFF?
Go to Step 5
Go to Step 4
there could
Oct 26, 2015 | Cars & Trucks
Locate the ambient light sensor
Automatic Headlamps- Vehicles with the automatic headlamps option are equipped with a unique headlamp switch that includes an A (Automatic) position and have a sun load sensor located on the top of the instrument panel to sense ambient light levels. When the A position of the headlamp switch is selected while the engine is running, the headlamps are turned ON and OFF automatically as ambient light levels dictate.
Feb 08, 2015 | Cars & Trucks
Replace dimmer switch
The headlamps ( high an low ) are controlled by the LCM lamp control module .
Headlamp Dimmer Switch
Under the left side of the IP, on the base of the steering column
Headlights Circuit Description (Buick)
Battery positive voltage (B+) is supplied at all times to the lamp control module (LCM) through the LH underhood fuse block LCM/HDLP circuit breaker via CKT 242 (RED). When the headlamp switch is placed in the ON position, the headlamp switch input to the LCM is grounded via CKT 103 (WHT). The LCM then supplies battery positive voltage (B+) via CKT 12 (TAN) to the following components:
• Left low beam headlamp
• Right low beam headlamp
When the headlamp dimmer switch is placed in the HIGH position, the LCM removes battery positive voltage (B+) from the low beam headlamps. The LCM supplies battery positive voltage (B+) via CKT 11 (LT GRN) to the following components:
• Left high beam headlamp
• Right high beam headlamp
The LCM provides battery positive voltage (B+) to the appropriate headlamps under the following conditions:
• The ignition switch is in the RUN position.
• The ambient light sensor indicates darkness.
The lamp control module (LCM) monitors the ambient light conditions through the ambient light sensor. The ambient light sensor is a variable resistor whose resistance changes as the surrounding ambient light level changes. As the ambient light decreases, the resistance of the ambient light sensor increases. The LCM measures the resistance across the ambient light sensor and determines whether it is day or night.
Search from over 10 Million Auto Parts
Do you know how to test automotive electrical circuits ? Check power in an power out . Videos on youtube on basic automotive electrical testing .
Mar 08, 2017 | Buick LeSabre Cars & Trucks
Ambient remote control 5884 won't turn fireplace on and off
  • Make sure your valve is in the "on" position and not "pilot".
  • Install fresh batteries in both remote and receiver (remotes are finicky about good batteries.
  • Ensure the switch on your receiver is in the "remote" position.
  • Follow manual to re-sync handheld to receiver if necessary.
  • A burner not lighting could also be the fault of the appliance (bad thermopile). Check this too, and replace if needed.
  • Replace remote if necessary: Universal Fireplace Remotes
Dec 28, 2012 | Ambient Tech. Rcmt Manual Fireplace Remote...
On my 1996 ss impala what low side pressure should I see on the a/c with the system running
It all depends on the outside (ambient) air temperature. Your A/C low pressure switch is designed to turn the compressor off at 24 Psi. and turn it back on at 45 Psi. Most systems will normally run at between 25 and 40 Psi when the system is running on HIGH blower and "MAX" or "RECIRCULATE". A system that is fully charged may run at 25 Psi when the ambient temperature is 75 Deg. (F) and may run at 40 Psi when the ambient temperature is at 90 Deg. (F). (it can be even higher if ambient temperatures are higher than 90 Degrees.)
To properly diagnose a malfunctioning A/C system, the HIGH side pressure must also be checked. Restrictions in the system can make the low side pressure look normal while the high side pressure is high enough to blow hoses apart. (400+ Psi.)
Sep 04, 2011 | 1996 Chevrolet Impala SS
My 1996 passat is shutting off when the ambient temperture is hot, when is cool outside it starts fine but then as it warms up it shuts off. I purchased a new ignition switch but that didn't help.
the ambient temp. is reading more hight to ECU , ECU cut off . check sensor cable for short sercuit . try disconnected and check . note if disconnect mybe A/C not working ,
Jun 23, 2011 | 1996 Volkswagen Passat
Code 1494
P1494 - LEAK DETECTION PUMP SWITCH OR MECHANICAL FAULT
When Monitored: Immediately after a cold start, with battery/ambient temperature between 40 deg. F and 90 deg. F and coolant temperature within 10 deg. F of battery/ambient.
Set Condition: The state of the switch does not change when the solenoid is energized.
This code sets when the LDP Switch does not close when the vacuum is let into the LDP. An evap leak will not set this code. First check the vacuum to the LDP. IF it is ok, you will need a wiring diagram to check the battery voltage, and the control wire, and the switch state wire to the LDP. If the wiring to the LDP is good, then the switch in the LDP is bad, and you replace the LDP. This is the case almost 100% of the time.
Good luck.
Aug 25, 2009 | 1999 Jeep Grand Cherokee
99 olds aurora ac issues
Both switches are simple on/off, so you can test with an ohmmeter or just bypass with a paper clip. See your diagram at the link below.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=17528
Aug 01, 2017 | 1999 Oldsmobile Aurora
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
