Question about HP Pavilion a305w (DM181AR) PC Desktop
My monitor doest open..
I tried to troubleshoot my computer setting but after i clicked ok, the monitor is dead even if i unplug and put back the cord. what should i do?? please help. please send me answer at ashanova143@yahoo.com... thanks a lot..
    Problem Solver:
  • 7 Answers
start your computer, upon start up hit F8 to get into the safe mode options. select start in safe mode. went into control panel, and do a system restore to a date from last month. Once that happen, the comp restarts itself and lo and behold everything was back to normal.
Regards
Rammohan
Posted on Oct 06, 2008
Buy a new monitor.
Posted on Sep 08, 2008
How can I get out of Safe Mode on this computer Hp Pavilion p7-1026b
turn it off and on again if that doesn't work take the battery out when it's powered on then put it back in and turn it on.
Aug 24, 2014 | Computers & Internet
I went on vacation and turned off my computer (the
mcdevito75 here, Your Monitor could be bad, (blown out) a monitor is just like a lite bulb. start your computer verify fan is on, verify monitor is on with on off switch on monitor, press shift key on keyboard maybe your computer is on stand by or hybirnation, also click the mouse at the screen left click and right click to bring picture to screen, if picture on monitor ok, if not press AUTO on the monitor, this brings back factory settings to your monitor. If all this fails, bring your monitor to a Radio Shack, Staples etc. for testing.
Jul 21, 2010 | HP Pavilion a1210n (ED895AA) PC Desktop
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
Having the same problem as others, my 912n monitor is a black
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 17, 2010 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    No display on the screen and beep.
    hi, i am pretty sure this is a bios problem! but it could be video card or monitor. put it all back the way it was-when it worked-then reset the bios-unplug the pc-take out the battery.(about the size of a coin) there should be a three prong jumper, near the battery-and move it to the two prongs that has not had the jumper on it-then push the power button- this is to discharge the power that will be stored in any components on the motherboard- the pc is must be unpluged- then wait 60 seconds and put the jumper back and the battery(see if the battery is dead first) new ones are about 4 bucks, and they last a long time. then boot up the pc!-you should also set the bios at the correct values, as it will use default settings. some hp and others default settings are fine. on custom pc's setting values will need to be set for optimal settings, for the particular hardware. if this fails, try a new video card and check the monitor also. if you know the model # and brand, you can go to the website,then download the manual. this will show you the location of everything i told you to look for. if you need further help, reply. please rate this solution. good luck! one last thought motherboards can fail, from any number of things. hope this is not the case on yours.
    Jul 18, 2009 | Intel Motherboard
    I installed a new video card in my system. I am not getting any picture on my screen. I contacted dell and it was determend that I might need some assistance from you. can you help
    Hi there ok you can try this first turn off the computer unplug the powercord from the computer , remove the monitor cable then open the case, remove the card and ensure that the slot is free of any debris canned air works good for this now now press the card back into the slot firmly and dont forget to put the screw back in if it has one now find the powersupply cable that hooks into the motherboard and unplug it and wait about 10 seconds now press the power on button on the front for 5 seconds this will clear the system now put the connector back into the motherboard and ensure that all of the cables are firmly into place hook up the monitor cable back up and put the power cord back into the computer and turn on the monitor and turn on the computer and see what happnes ok this should help if not let me know there is still things we can check ok best regards mike
    Feb 16, 2009 | X2Gen MG19MY 19" LCD Monitor
    Acer Model AL1916W A reads no signal after being on for 1 hr
    Jan 22, 2009 | Acer AL1916W 19" LCD Monitor
    My HP monitor (f50) has malfunctioned
    Try these 2 steps if they don't work get back to me :)
    Step 1. Connect the video cable and turn on the computer. What happens?
    • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
    • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
      NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
      1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
      2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
        1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
        2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
        3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
        4. Click OK and restart the computer.
        5. After Windows opens, click Start , and then click Run .
        6. In the Open field type msconfig and press Enter .
        7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
        8. Click OK . Do NOT restart the computer.
      3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
      4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
      5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
      6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
      7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
        NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
      8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
    Step 2: Connect to another monitor
    Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
    • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
    • If the monitor remains blank, repair or replace the monitor.
    Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
    Lg 5552 v set is dead
    try to resolder all points in fbt including fly back trans itself area also resolder the crt pcb area i had the same problem the reason was cold soders also put a good 2sc5297 for hor out.
    Dec 02, 2006 | LG Studioworks 552V 15" CRT Monitor
    HP Pavilion a305w (DM181AR) PC Desktop Logo
    102 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
