Question about Palm LifeDrive Mobile Manager Handheld
Lost files - due to soft reset?
Lots of files on my LD have vanished (or maybe only partly so). I'm not sure exactly when it happened, but the LD did what I think is a soft reset this evening, mid-use. Sometime later, going in D2G and Files, lots was missing. In fact, I think they were empty, but my memory may be at fault by now. I did a soft reset and some files appeared. In Files, there a just a few recognisable files listed under LIFEDRIVE. Before this happened, Files had two different places where files were stored. Was the other the one with the blue card symbol? Or is that only seen in D2G? Under LIFEDRIVE, as well as the few recognisable documents, I now have a CHDSK.TXT file telling me >>FAT filesystem check detected problems that were fixed: has entried after end of directory repair action: extending directory<< Then lots of messages about lost clusters. Also in LIFEDRIVE are lots of files that have numbers for names, an icon like a piece of paper with turned down top right corner - and they won't open. I wonder if these are the missing files and how do I get them back? And get back the usual division into the two different sections. (Are they LD and hard drive?) At some point I tried HotSynch, hoping they'd come back. No joy. Had an error message >>
    Master:
  • 542 Answers
Just check your PalmOne folder, see if anything there, i.e., : C:\Program Files\palmOne\\Internal Drive Backup *********************** well, a hard reset should be able to restore to LD new-out-of-the-box state, if you don't need to save any corrupted files in LD drive... But if they are something really important, what you can do is to copy whatever files out to a PC (i.e., via drive mode on a PC), and see if you can recover it with data recovery apps, or better yet, do it straight on the LD drive - although the chance of success is slim. What you described on previous post, sounds like the FAT table has messed up, and seems very similar to a PC HDD failure.
Posted on Sep 15, 2005
Whats ld on cannon copier
YOUR COPIER IT MAYBE THAT YOUR IN THE WRONG FORUM
May 02, 2014 | Kenmore Washing Machines
Washing machine candy grand'o 1400 has stuck, vanish stain light
Ok, turn the washing machine off and unplud. Open the flap at the bottom left of the machine. Put a bucket underneath it. Unscrew the cap. Water will pour out - lots of it and very quickly - so make sure you have a bucket underneath it and lots of towels round that.
Once the water has drained out, check there are no blockages in there. You may find that some coins or buttons flush out with the water. That will be your problem.
Once clear, screw the plug back in and turn on machine.
Dec 23, 2009 | Candy Washing Machines
Tom Tom 130 will not power-up ( no working screen) when power button is activated.
If your device is not starting up properly, follow the steps below:
soft reset:
How to soft-reset my navigation device Answer In rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting.
To reset your TomTom device, do the following:
Check that the battery is charged properly.
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
Reset your device.
Press and hold the On/Off button until your device restarts. This can take more than fifteen seconds.
Oct 09, 2009 | Tomtom ONE 130 GPS Receiver
1999 Saturn SL1 Service Engine Wrench
Some codes are HARD codes & some SOFT codes. The hard code are stored in the computer memory because "something was wrong and is wrong." A soft code is when an issue happened but vanishes.Sounds like you might have something soft.You'll need that scanner hooked up when that light comes on to check the specs of the car.
Feb 03, 2009 | 1999 Saturn SL
HTC P3400 Memory Card data corrupted!
micro sd memory card isnot fromating my pc
Nov 10, 2008 | HTC Touch P3450 Smartphone
HP PDA h1940
I just found the most protracted set of instructions to reset it for reference.
1. charge on ac only = 8 hrs
2. remove battey, soft reset, reinsert battery
3. charge on ac only = 30 minutes, remove battery, remove power, hard reset then soft reset.
4. charge on ac only = 4 hrs
5. Power off. Soft reset.
Oct 13, 2008 | HP iPAQ H1940 Pocket PC
ASUS MyPal A626 Wouldn't boot
On the right side of your ASUS A626 there is a switch that says "HOLD". Make sure that isn't flipped on.
-Sean
Apr 02, 2008 | ASUS MyPal A626
Copying MP3s using Drive Mode
yup! soft reset and all was fine but looked pretty grim for a moment. Happened to me when i put the SD/LD icons into the trash (mac osx) before I hit the first 'turn off drive mode' page rather than hitting 'turn off' button, then trashing the icons, then hittinf turn of drive mode button. Is this in the manual....nope!
Sep 15, 2005 | Palm LifeDrive Mobile Manager Handheld
Copying MP3s using Drive Mode.
yes! soft reset and all was fine but looked pretty grim for a moment. Happened to me when i put the SD/LD icons into the trash (mac osx) before I hit the first 'turn off drive mode' page rather than hitting 'turn off' button, then trashing the icons, then hittinf turn of drive mode button. Is this in the manual....nope!
Sep 15, 2005 | Palm LifeDrive Handheld
hmm, just check your PalmOne folder, see if anything there, i.e., : C:\Program Files\palmOne\\Internal Drive Backup *********************** well, a hard reset should be able to restore to LD new-out-of-the-box state, if you don't need to save any corrupted files in LD drive... But if they are something really important, what you can do is to copy whatever files out to a PC (i.e., via drive mode on a PC), and see if you can recover it with data recovery apps, or better yet, do it straight on the LD drive - although the chance of success is slim. What you described on previous post, sounds like the FAT table has messed up, and seems very similar to a PC HDD failure.
Palm LifeDrive Mobile Manager Handheld Logo
93 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
