Question about Casablanca Fan Versa Touch2 W-72 Remote Control
My casablanca fan versa touch 2 does not respond to remote control - batery is fine, breaker fuse too. I recall having a same problem some time ago, forgot, how I fixed it - I know it was something with some changes in the dip switch code
    New Friend:
  • 45 Answers
I believe there is a dipswitch, and a non- dipswitch version. To sinc the remote to receiver, shut power off to the fan receiver by either a switch or breaker for about 10 minutes, turn power back on and press Hi, Medium, Low on the remote in that order. this should get them "talking" again. If this does not work, contact toll-free Jason at Fan Man Lighting 1-866-600-3267, he has 30 years experience with casablanca
Posted on Oct 17, 2009
Casablanca Visa-touch fan
most problems solved with new batteries
Jul 31, 2013 | Casablanca Fan Versa Touch2 W-72 Remote...
Have W-52 adapt touch. Light stays on all the time. Remote works only the fan (all speeds and on/off). It used to work fine.
I posted a solution to this problem earlier. Again, please go to www.casablancafan.com and go to the troubleshooting index. Here you will most likely find your answer. Thank you and good luck!
Jan 28, 2011 | Casablanca Fan W-52 Remote Control
Remote works fine for fan and uplight however, lower light goes bright then dims to off.
there seems to be a problem try pressing and holding the light button see if that helps if not there is an issue with the module on the fan itself
Jan 02, 2011 | Casablanca Fan Versa Touch2 W-72 Remote...
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Dec 01, 2010 | Casablanca Fan Dryers
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Casablanca Stealth Fan - Unresponsive To Remote
I fixed this myself by upgrading to an Advan Touch unit. Details here: http://www.casablancafanrepair.com/HTMLFiles/ do_it_yourself/ComfortTouchCommonRep/CTToItConvert6-12- 07Web/SM_CTToAdvanConvert_P1.htmI purchased the P-RMM CT to AT Converts Comfort-Touch to Advan-Touch upgrade kit from http://www.fanmanlighting.com/shop/pc/viewPrd.asp? idcategory=56&idproduct=966The fan man was helpful and my parts reached me in 2 days, normal shipping!
Jan 02, 2010 | Dryers
Casablanca fan stopped working suddenly, both fan & light
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Sep 29, 2009 | Casablanca Fan Versa Touch2 W-72 Remote...
Casablanca Fan Versa Touch2 W-72 Remote Control Logo
2,411 people viewed this question
Top Casablanca Fan Televison & Video Experts
Steve
Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
