Question about Samsung SYNC SGH-A707 Cellular Phone
Phonebook i cannot save any contact in the phonebook save only the ones contained in my seem card. moreso, when i do receive any calls, only the numbers do appear without names that i have stored in my sim card. that is too bad because i keep on asking ''who is on the line question'' and my friends are disappointed that i have ignored them or deleted their numbers can someone be of help to me? my email address is kkarizona2008@yahoo.com thanks kennedy kenneth(kk).
  • Samsung Master
  • 456 Answers
Hey
go to contacts/setting and select phone and sim data on display data
Posted on Oct 06, 2008
How can I block numbers from my phone?
If the contact is saved in your phonebook, do the following below
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
Ref: http://tutorialboz.blogspot.com/2011/04/samsung-star-gt-s5233-cell-phone-if-you.html
May 12, 2011 | Samsung Star GT-S5233 Cell Phone
I bought a sharp 903sh online through YesAsia. On my pc it shows up a sx833. I can't make or receive calls but it will send and receive texts. System sounds eg text arriving,are fine but the voice...
Dear Amaxeen ,
Well It Seems the configuration problem ,you should have to configure your phone properly for that ,if you wanna to use its aal features you need to download proper drivers and manual ,so that you can use it smoothly.
You can download all stuff for your Sharp 903 , from this link:
http://www.sharp-phone.com/country/downloads/downloads.php?country=GB&lang=en&product=903
Cheerup and Be Happy Always
Mar 07, 2008 | Cell Phones
I want to block unwanted callers from calling me . i am unable to block these callers
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
4. select call
5. select all calls
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
Apr 11, 2011 | Samsung Star GT-S5233 Cell Phone
Dear Sir, I am using Samsung SJ700 mobile phone.And sometimes I get incoming call with no number displayed on the screen. It just shows incoming call. Can you pls help me in sorting out this...
This happens when two or more similar (saving one number with different names) contacts is saved on your phonebook, i.e. if you've saved my number on the sim card with a name and at the same time you have my number (same number) on your phone's memory, the caller id will not be displayed, you'll only see the "Incoming Call" or "Call". So I would suggest you to please check the phonebook and delete (keep only one per number) if there are multiple similar contacts saved on your phonebook.
You can also reset the phone to Factory default, in case there's no problem with your phonebook/contacts.
Good luck.
Thanks for using FixYa.
Aug 14, 2010 | Samsung Cell Phones
SamsungGT-S5233-A:How do i block message from a particular mobile
1. press menu,
2. select settings
4. select call
5. select all calls
10. select call log
>>now you are all done.
>>no need to buy medicine for your head aches.. :-D
regards.
Mar 03, 2010 | Samsung Star GT-S5233 Cell Phone
How to add calling card 800# and PIN to expedite LD calling.
When storing a calling card access number and your PIN in the
phonebook as one phonebook item, press {PAUSE} to add pauses after the number and PIN as necessary. Or, if stored as separate entries, during a call, press MENU, press 1 to select “Phonebook”, and scroll up or down to find the entry and press Call. Repeat to dial other numbers.
May 17, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
Trouble with contacts
Was your Sim card copied to the address book?
You may have to fix the entries copied from the sim card into the address book so that the cell phone number is in the correct field as well as the names. By default it may not be properly stored into the correct fields.
Mar 18, 2009 | RIM BlackBerry 8700c Cellular Phone
Motorola Problem
Thats not atall software prob buddy. You verify that your messages are saved on phone memory and that you are not using SIM stored numbers. You can surely backup all phone memory numbers to SIM by copying.
May 31, 2008 | Motorola Mobility W375 Cellular Phone
Unknown calls
copy the old contacts from sim card and save new numbers in phone memory
May 11, 2008 | Cell Phones
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 | Cell Phones
Samsung SYNC SGH-A707 Cellular Phone Logo
65 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
