Question about Zenith XBR413 DVD Recorder
Finalizing DVD HI, I copied a vhs program to DVD and it seemed to work but nothing came up to finalize it. I clicked on Title or Disc/setup and nothing happened except for the main screen popped up that showed the video i copied. The DVD does not play in any dvd player or computer. Also, can I go back and finalize it once I know how? Is it too late? What setting do I need to be in to finalize it? Desperate, Thanks!
  • 8,596 Answers
If the size of the vhs recording was in 2hr mode, and the size of the recording itself is about 2 hrs, you may not have enough space to finalize. I would use your PC to finalize the disc - I use Dr. Divx, but you can find many finalizing programs out there.
Posted on Sep 04, 2008
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Limited viewing
It sounds like the recorder will only record the dvd+ format, which does NOT need finalizing to play in other machines. ( you can record a dvd- , play it back on the machine you recorded it on, but need to finalize it to play on other machines)
The other units may only accept dvd-.(dvd- being the same format as you would buy or rent a film on)
One option, record the dvd on a dvd+rw (if possible) then copy to a dvd-r using your computer. The average use of a dvd+ is 1000 recordings.
There are many free disc burning suites available to download. Just google "free disc burning software" and take your pick.
I use 1 called "magix goya base" for copying disc to disc and "NTI" for burning to HDD and then to disc, if you only have use of 1 drive.
Sep 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Finalizing DVD-R fails, rendering Verbatim disc non-readable
You might try finalizing the disc in a PC using IMGBURN or other DVD recorder software. It couldn't hurt...
tom
Jan 09, 2009 | LG DR787T DVD Recorder
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
Finalize dvd
Turn off the machine and turn it back on again, before the dvd loads hit the setup button on the remote, you will see a list of possible choice and edit will be one of them, wait until it lights up like the rest, that will mean that your disc is loaded, finalize is one of the choice under edit.
Aug 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Finalizing
-R and +R auto-finalize, only +RW and -RW require manual finalization - if the option is no longer available, it is because the discs are already considered finalized by the player. If the disc edit option is greyed out, and you cannot play the discs in another player, then the recorder will need to be replaced b/c it is consistently producing bad recordings. Try unplugging and replugging the recorder once just to be sure it isn't a temporary problem.
May 22, 2008 | Philips Magnavox DVD/VCR Dual Player
Finalizing dvd
VHS tape to a DVD-R
Jan 13, 2008 | Zenith XBR413 DVD Recorder
Transfer VHS to DVD
The illustrations within the PDF is very help!
To play disc in other DVD players…
The disc needs to be finalized.
Page 37 of the manual has “Finalizing a disc”.
Recording from DVD to VCR…
Page 39 “Dubbing Mode”
http://www.funai-corp.com/support/manuals.aspx
Type in the box: MWR20V6
Nov 09, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Battery died in the middle of finalizing
Hi, If you want to edit the video, try copying the unfinalized VOB or VRO file from the mini-DVD onto your harddrive by just putting it on the dvd drive of your pc.. u can use premire or some other tolls to get the work done and finally burn it another dvd as you like. good luck my friend sreejith
Jan 25, 2007 | Sony Handycam DCR-DVD101 DVD Camcorder
Zenith XBR413 DVD Recorder Logo
327 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
