Question about Epson ActionPrinter 5000+ Matrix
Html to generic text
My application is printing in html i want my virtual printer to print in generic it possible
  • ontario wallace May 11, 2010
    yes, you would have to print the actual web page.
    are you using a particular software or is the document/web-page going directly to the printer?
    Problem Solver:
  • 10 Answers
Rename the file extension as .htm and then open the file in a browser. then go for printing... you will get text and not html codes..
Posted on Aug 07, 2009
Print - Generic Text/Only We didn't find the driver for the Olivetti PR 4RT for windos vista and now we are configuring the driver Generic Text / Only but we don't know how to print images, can you...
Please double check your model name and number on your printer. I have checked and do not find anything under PR 4RT. There are several other models which have available drivers, but this model is not found.
I look forward to hearing back from you.
Feb 18, 2010 | Office Equipment & Supplies
"Internal error - false" when printing on Samsung SCX-4200
Good day Sir, These are the possible causes why your machine print the wrong text.
Problem: The machine prints, but the text is wrong, garbled, or incomplete.
  • The printer cable is loose or defective.
  • the wrong printer driver was selected.
  • The software application is malfunctioning.
  • The operating system is malfunctioning.
Have a nice day!
Oct 25, 2009 | Samsung ML 1710 Laser Printer
I have a tally 2250 printer to beused under win98.
you can installed this printer driver of genric text only.
Jun 25, 2009 | Tally T2250 Matrix Printer
Try this !
in the software application you are printing from
Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
Look for a Best Mode Setting
this printer has several modes one being draft mode, another one best mode
in best mode the printer uses memory to render the photo you are trying to print.
Note that in this mode, printing takes
longer and more memory is required from your computer.
from page 17 of the hp k5400 user manual
Also you may have to increase the virtual memory of the windows pc to allow the computers hard drive to allocate more hard drive memory to the memory swap file if the computer's ram is not enough to print the photo.
It is a setting in the control panel under system - performance.
May 12, 2017 | HP Office Equipment & Supplies
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
"Generic / Text Only" driver printer and cyrillic
Unfortunately printing Cyrillic(Russian) is driver dependent and your application can only use generic/text driver.
Aug 05, 2008 | Epson TM-U220 Matrix Printer
Got virus, got rid of virus, cant print, not recognizing printer, uninstalled and reinstalled but wont finish saying "The specified print monitor is unknown"
Need to know more about the printer make and model to diagnose this completely. But the first step is to take the third party applications and software issues out of the equation.
For PCL printers setup and print to the printer using the "generic-text only" driver in Windows. For any PS laser printer, you can usually use the laserjet4 PS driver. If attached USB, unhook and plug the printer into a different port first.
If you still can't print, the print monitor in Windows was probably corrupted and you will have to run a repair using your original system disk. This happens often with virus which replace system files in order to hide from AV scanners.
If can print, then you (1) probably have an injet and (2) probably have a failed uninstall of the print applications. Third party print applications still running as a service can cause this same issue.
Jul 23, 2008 | Lexmark Office Equipment & Supplies
Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Nov 27, 2007 | Epson TM-U220 Matrix Printer
Printing from windows
as i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Nov 21, 2007 | Datamax I-4308 Thermal Label Printer
Epson ActionPrinter 5000+ Matrix Logo
2,743 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
