Question about HP Pavilion dv2000t Notebook
I have a hewlett packard laptop and on the right hand side of the keyboard are the keys with a small box with alternative symbols that can be used. I seem to have locked the computer into typing only these boxed symbols ie the L gives a 3 not an L. It is not num locked or ctrl locked so how can i unlock it
  • 186 Answers
This feature will be available with Notebooks which are small in form factor and there is no space to provide the Number Pad seperately. So, the Numbers will be integrated on to the Alphabets.
Inorder to switch on the Number Pad, you need to hold the FN key and press the Number Lock. Pressing the Number Lock alone will not disable the integrated Number Pad.
Hope this helps...
Posted on Sep 04, 2008
How to adjust contrast
Are you asking because the screen has gone dark?Darkness is a backlight issue,can be the screen backlight,inverter or the cable itself causing it.Screen too bright can be adjusted via personalization or often keyboard shortcuts that have what looks like a sun symbol on them,the left key darkens when pressed and the right brightens
Aug 06, 2014 | HEWLETT-PACKARD HP EliteBook Notebook
Turn wireless
You may have a small switch on the side of your laptop that turns on/off wireless and/or Bluetooth. Or you may have to use "fn" keys to do that. If you've tried both methods and nothing happens, check that your devices in Device Manager have good drivers installed.
Jan 14, 2014 | HEWLETT-PACKARD Hewlett Packard BLUE HP...
How do i turn on my bluetooth on my laptop
You had been provided a "fn" key on your keyboard, keep pressing the same key and tap the key which has the symbol made like Bluetooth.
You will be able to turn on the Bluetooth on your laptop.
Apr 22, 2013 | HEWLETT-PACKARD G72250US Laptop
Numbers key board not working
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk hope this helps Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
Feb 22, 2013 | Packard Bell EasyNote E2 316 Notebook
8710w Battery recognize probleme
That sounds more like an alternator problem. If you have a multimeter start the car and check the voltage on the battery terminal it should be around 14Volts if it is getting to 15 Volts then the alternator is overcharging if it is 12.5 Volts then the battery is not getting enough charge and your alternator needs attention.
Jan 18, 2013 | HEWLETT-PACKARD Hewlett Packard 8710w - HP...
Number key not working on laptop
If you are talking about the number symbols that are on keys U,I,O,P,J,K,L,M then notice what color the number symbols are on those keys. Normally they are blue or might have a square around them. That means you have to press and hold the key that is the same color or has the square around it on the left side of the keyboard. Normally you would Press and Hold the FN function key at the lower left hand portion of the keyboard, then hit the key for the number you want. Notice that the FN function key will be the same color as the numbers. If it's not the FN function key then it will be the key that has the square around it like the numbers has.
May 23, 2012 | HEWLETT-PACKARD Pavillion DM1-3020US...
My wireless button wont turn on?
either your drivers are missing, which you can get from the HP site under the support tab....or you need to switch it on using the switch or holding down the FN key on your keyboard & pressing the wireless key, which should be on an F key with a little picture of a wireless symbol.
Like the one below:
Jan 30, 2012 | HEWLETT-PACKARD HP ProBook 4525s Notebook...
I buy PC packard bell easynote_TS11HR-032FR and the touchpad does not work, when i use my pc for the first time.
Check this:
Many laptops with touchpads have a switch or a keyboard combo that will disable the touchpad. Look to see if there is a little button you can push located near the touchpad. Alternately, there is normally a Fn-special function key combination you can use. You press the Fn key and also the special function key that has a little symbol on it that looks like a touchpad. That can turn the touchpad on or off.
Aug 05, 2011 | Packard Bell 160240 Mouse
I can't locate the volume control button
what is the operating system you are using ?
Mar 01, 2011 | Computers & Internet
I have hp laptop on the keyboard when i used the shift key to get @ what appear is this symbol,can you assist me with problem,or advice what to do.
make sure your keyboard settings in control panel are correct(location and layout settings) then make sure your fn key is not pressed down
Nov 05, 2009 | HP Hewlett Packard Compaq 6720s Laptop...
HP Pavilion dv2000t Notebook Logo
152 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
