Question about Earthquake Sound XTREME 900W.5 Car Audio Amplifier
Sound from speakers muffle mid song
This is a wierd problem and can't track down the cause. I have a set of comps in my front door hooked up to the amp. Have my gain at about 3/4 and my HU volume at 40 out of 63. The system is pumping sounds great all of a sudden poof it gets all muffled and murky and muzzled, I don't know how else to explain it the sound gets lower and gurgled, then out of nowhere it'll come back to normal then back to muffled. I lower the volume a bit switch songs and it'll be ok then put it back up after a bit it'll happen again. I don't think it;s the speakers cause it happens to both sides at the exact same time and comes back at the exact same time.
Could this be a ground problem or a volatge problem at the amp? or some other kind of problem?
  • stylez3 Sep 05, 2008
    Thanks for the reply. I am going to call earthquake tech support and see if I can send it to them or something to check since it's under warranty.
  • ishmailryan Sep 28, 2008
    same amp,same problem-so how did you fix it?
    Problem Solver:
  • 13 Answers
Assuming you've already checked all your wiring, it sounds like a problem in the amp circuitry. Would you say it happens when the amp heats up? I'm guessing an input opamp circuit is messing up when the amp gets hot. If you are electronically inclined you could open it up and look for a poor solder joint. Other than that you will likely have to get it professionally serviced.
Posted on Sep 04, 2008
Hooked to surround sound, two front speakers, 4 wall speakers, 1 sub woofer. Restart unit and reduce volume unit is OK but normal talking is too low.
Voice tracks are usually routed to the center channel. You don't mention having a center channel speaker hooked up. If this is the case, then you need to go into the receivers setup menu and set it for no center. This will reroute the voice tracks to your front speakers.
Feb 24, 2016 | Onkyo TX-DS575 Receiver
Hooking up speakers
first off stock wiring for speakers,and or amp are with minimal wiring.Rewire system for better sound quality,also use noise suppresors if needed.
Jan 18, 2014 | Toyota Cars & Trucks
DVD player only has background sound (songs, sound effects) but no dialogue when people are speaking
On 5:1 surround sound the voices are only directed to the center front speaker. If you do not have one, but your sound system has been set to surround sound (5:1 or 7:1) in its menus, this will happen. Use the menus on your sound system to set it to '2 channel' or 'Stereo' then all of the available sound on the DVD will be sent to the 2 front speakers.
Dec 20, 2013 | Televison & Video
Sound gets muffled at certain frequencies. Please Help!
I think that rather than the mixer, that your front speakers may have a limiter built into the high frequncey amp. You may be asking them to do more that they are capable of.
Mar 04, 2017 | Behringer Sx2442fx Eurodesk 24channel...
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
How to use Audioline Pro DJ Multimedia Mixer M Dex 3.0
I have been recently using this Cd Dj deck at parties and have some general knowledge of the product, it has alot of potential. Is there anything in particular that you need help with? Or is it the general concept of using them.
Currently, i don't think there are that many websites that explain how to use the Cd decks, however i can provide you with some basic information. Most of the information here could be worked out by trial & error.
- Pitch control on the right of each cd deck can be slid up ( slows it down %) and slid down (speeding the track up %) i think the pitch control has a range of either +-10% or +-16%.
- Cue button, has the potential for Cue'ing or setting up the cd to instantly jump to the "cue'd" point with the press of this CUE button. This is done by either pressing play/pause button and rotating the jog wheel to a point of time in the track which automatically sets the cue point OR holding down the >> or << search button to find a spot within the track at a greater speed.
-Vinyl mode. Pressing this button will set the deck to the "vinyl mode" to simulate scratching or even backspins. pressing this button again will change the mode back.
- the Crossfader (or 'X' fader) button will select the left cd track if the x fader is all the way to the left and the right track if the x fader is all the way to right. having the X fader in the middle will play both tracks together.
- Low, Mid, High. These nobs on the middle section of the deck change the individual track by which it is corresponds. (Left side = left cd track, and vica versa) Low refers to the Bass of a track which can be essential for mixing two tracks and elminating excess bass noise. Mid refers to the drumming and even synth of a track, and changing this can result in some cool sounding effects. High refers to the 'high' frequencies of the track playing, such as snares, hi hats and possibly vocals. All these controls are crucial to understand in order to mix 2 songs together successfully. It's good to get a chance to muck around with these cointrols. The middle of each control resets the setting to normal or default.
- Channel fader. the two controls that slide up & down on both sides of the mixer on the deck. This is also referred to the volume setting. Useful for mixing seamlessly one track into another.
- Gain. This control at the top of the mixer refers to the volume level or 'gain' of the cd track that it corresponds to.
- Jog wheel. Serves 3 purposes. firstly it can be used whilst a song is playing to temporarily speed up or slow down the track to match with the song on the opposite side. secondly, whilst holding down the 'search' button, operates as a control to quickly find a spot in a song. and lastly when selecting "vinyl" mode, can simulate the reaction of a vinyl turntable. The scatch function, and backspin effect.
- The pitch button, is just another control to speed up or slow down a song temporarily whilst holding down the '+' or '-' button.
- Reverse button, for a certain amount of time will play the song on the left or right in reverse.
- Time. this button is essential to change the time selection on the cd deck, to either "Time elapsed", "Time remaining" and "total time remaining on the cd".
- the "tap" button, allows the user to physically "tap" the button in time with the song's beat, which calculates the Beats per Minute (Bpm) of that song. which is essential to work out the bpm of 1 track to mix the speed with that of the opposite deck.
- Cd/usb/sd, changes the mode of system reading. from CD to USB or SD card.
I really hope this general guide to using the Audioline ProDJ MDex3 has helped!
Peace. Marc.
Apr 03, 2009 | Music
I have a creative inspire 5.1home theater i need 5.1 songs
5.1 plays surround sound tracks when available, when playing an audio track that was recorded in stereo (2 channel) it should only emit from the front left and right speaker, and when playing a movie in 5.1 at points in the audio track all five speakers should emit sound. Is this the case?
Feb 12, 2009 | Creative Labs Sound Blaster Live! 5.1...
Downloaded songs appear in iTunes library but won't play on comp
I had exactly the same problem and followed the OP's solution, which worked, but I couldn't hear the track as it was being recorded.  So I tweaked the solution.  If you do the following, you don't have to keep changing System Preferences as you switch from record to listening:
Go to System Preferences, press the Sound icon, and click on "Sound Effects."  Then select the drop down menu and select "Play alerts and sound effects through selected sound output device" rather than the USB choice.  Then click on "Output" and select how you want to listen; I used speakers so I selected "Headphones" where the port is "Built-in audio."  Then click on "Input" and select the USB choice.  Now record a track and you can hear it being recorded through your speakers (or headphones).  When it's done recording and after the software transfers it to iTunes, you can play it again through your speakers without going to the preferences panel.
Dec 25, 2008 | ION Audio iTTUSB Turntable
Speakers Muffled
Say "sound card" or maybe you fryed something due to overuse and or playing them too loud? Nah. Everyone plays speakers at the recomended level. Seriously, you need to get this checked out: radioshack.
Oct 20, 2007 | Audio Players & Recorders
Only two of the speakers are working
have you used the mic input connection as this is used to split the channels
May 21, 2007 | Logitech X-530 Computer Speakers
Earthquake Sound XTREME 900W.5 Car Audio Amplifier Logo
221 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
hoyzee1
Tom Chichester
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
