Question about Brother HL 1240 Printer
Printing correctly on legal size paper
My HL 1240 won't print the full page of legal size in landscape position. It starts about 1/3 over from the left on the page and it runs off the right side. Is there a user manual I can download?
  • 286 Answers
You can get the users manual from www.brother.com.
Posted on Nov 04, 2008
Lexmark printer won't print on bottom half inch of page
Make sure to set the correct paper size when printing. Letter - letter; legal - legal size.
Sep 21, 2012 | Lexmark Platinum Pro905 multifunction...
My printer won't print letter automatically. It's stuck on printing only legal. If I pull legal tray out it will print letter. But I need it to adjust with alternating print jobs.
Printer wont stop paper, if any page length mismatch,Select page length as any size, as well as while shooting the print command select page length as legal & try it. I feel that teflon not rotating properly, result paper jamming at bottom end. If any paper length faulty printer detects the length give message of mis match..Pl check carefully...
Feb 01, 2012 | HP Laserjet M2727nf Multifunction Printer
How to print with the legal paper?
follw the given step and check-
1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
2-Go to the printer and take out the paper tray. Remove the letter size paper.
3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
7-Print a test page.
Thanks,
Dec 03, 2009 | Brother HL-2040 Laser Printer
Can't priny 8.5x14
program is set to 8/11 print size in progrm options paper size
Apr 22, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printing duplex and legal size.
I don't have legal size paper to test this with so it's a theoretical point but it looks like the printer will not do duplex in anything other than:
  • A4
  • Letter
  • B5 (JIS)
  • Executive
You can always print in duplex manually which is always an option regardless of paper size.
Hope that helps.
Mar 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
How to print picture using 10x15cm photo paper? usually the pictures printed only half
Hi
1) when you begin to print have you set the paper size to the size you require ?
2) If not when you press print a grey box appears to comfirm printing yes!
3) press properties top right of page
4) open tab basic
5) Alter paper size to correct size
6) Also check your paper setting on the programme you are using to print from,
7) Also that the orientation is correct "portrate or landscape"
grandpaben
Nov 24, 2008 | Brother DCP 115C All-In-One InkJet Printer
Legal size paper on LBP-1210
For printing the Legal Size (8.5′x14′) in cannon LBP-1210, follow the instruction:
Step 1- Go to start
Step 2-printer and faxs
Step 3-select printer(Canon LASER SHOT LBP-1210)
Step 4-go to file
Step 5-select Server properties
Step 6-select creat new form (for legal page)
Step 7-give form name legal 1
Step 8-give paper size width 8.50in, hight 14.00
Step 9-give paper margin top 0.30in, left 0.30in, right 0.30in, bottom 0.30in
Step 10-select save form Step 11-then select advanced
Step 12-select informational notifications for local printers
Step 13-select apply
Step 14-then close
Step 15-select Canon Laser Shot LBP-1210
Step 16-select printer
Step 17-select properties
Step 18-select-select forms
Step 19-select change forms
Step 20-select legal 1
Step 21-select OK
Step 22-select apply
Step 23-select OK
Remember: 1 U need to set paper size (8.5′ x 14′) manually in the word documents and befor printing you need to set in printer properties “Legal 1′ for printing. Print preview may not show the whole page but the printer will print the whole page.
All the best.
PARVEZ [ info(at)parvezbd(dot)com ]
Jun 22, 2008 | Video Cameras
Brother HL 1240 Printer Logo
88 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
