Question about Konica Minolta DiMAGE A200 Digital Camera
What is the distance at Macro mode? - Konica Minolta DiMAGE A200 Digital Camera
    Master:
  • 425 Answers
In wide-angle macro mode, the minimum focus range is as close as 30cm from CCD (21cm from the lens front.) At this point, the magnification is 0.03x (equivalent to 0.12x in 35mm format).(Focal length is 7.2mm. At maximum magnification 283mm x 213mm of the subject can be captured.) In telephoto macro mode, the minimum focus range is 25cm from CCD (13 cm from the lens front) and the magnification is 0.18x (equivalent to 0.7x in 35mm format). (Focal length is 42.7mm to 50.8mm. At maximum magnification 52mm x 39mm of the subject can be captured.)
Posted on Sep 15, 2005
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Canon S5 IS. I am having problems with Macro shooting. As I look through view finder, object seems in focus, but when I press focus lock button (halfway) the image jumps out of focus.
Dear Stefan:
Barring a malfunction with your len's autofocusing mechanism, the problem that you're experiencing is likely due to the limitations of the camera's focusing / zoom range in Macro mode.
You didn't say what ranges you were shooting from but basically, in order to get proper focus, you must first make sure you're within the proper lens to subject distance for the macro mode that you've chosen.
There are two macro modeson the S5, Macro and Super Macro. Macro shooting is done only within the ranges of 3.9 inches to 1.6 feet from your subject. SuperMacro mode (which is entered into by simply pressing the Macro button for one second) will only focus within the ranges of 0 inches to 3.9 inches. So if you are in either of these modes and stray from their focusing ranges, your camera won't focus properly.
Another issue that you may be dealing with is the very limited zoom range in Macro/Super Macro Modes. The zoom is basically meant to be set toward the maximum wide angle end of the zoom range. There is a yellow indicator bar below the Zoom Bar in the viewfinder that indicates the Out-Of-Zoom range in which the zoom basically can't be used. As you may see, only the first 10% or so of the zoom range is useable.
It might be that you could possibly be wavering in and out of the two macro mode focusing ranges and/or zooming into the Out-Of-Range zone during your session. Either can cause a similar effect such as you are describing. It's hard to say without actually being there.
To test this out I would simply set my camera on a tripod or other stand at a known fixed distance from the subject, set the camera to the macro mode indicated by that distance (either MACRO or SUPERMACRO), zoom out to the widest focal length and take the shot to see if it is clear or not.
If so, your camera probably has no problem. If it is still not focusing properly you might want to send it into the service center for a diagnostic. There is no charge to diagnose a problem with your camera and if nothing is found to be wrong you will only be out of the shipping charges spent to send the camera in to the service center. If a repair is needed, it can be done at that time.
Hope this helps you.
Sincerely,
HeavyDLB
Jun 01, 2008 | Canon Cameras
With Macro flash unit attached, and using the closest subject distance, images are extremely over-exposed.
The camera fails to control the flash output automatically due to the high intensity of Macro ring flash, causing the image to be over-exposed. Please set the camera as below to prevent a undesired result. Camera and Flash Settings - Set the sensitivity to ISO 100 using the function dial of the camera. - Set the flash metering of the camera to Pre-Flash TTL from the recording-mode menu. MACRO RING FLASH 1200 - Set the camera exposure mode to A or M mode. - Set the aperture to f/6.7. - Attach a ND filter x4 (0.6D) to the camera lens. MACRO TWIN FLASH 2400 - Attach a diffuser to the flash tube units. In case the flash tube and the subject is too close, eg. Not using the arms, set the camera exposure mode to A or M mode and the aperture to f/6.7. A subject at minimum distance may still be overexposed. Use exposure compensation to obtain the best result.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Minimum focusing distance In the Super Macro mode
In super macro mode, pictures can be taken as close as 2 inches. Subjects measuring up to approximately 1.9 inches by 1.4 inches can be captured on the monitor.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Focusing distance in macro mode
On a D-565 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus Camedia C-450 Zoom Digital Camera
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
On a D-580 Zoom camera, the Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
On a D-575 camera, The Macro Mode operating range is 8 inches to 20 inches. This means the camera must be between 8 inches and 20 inches away from the subject for a picture to be in focus.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Using the Macro mode, it is possible to zoom through all ranges from telephoto to wide down to a minimum distance of 7.9 inches.
Sep 01, 2005 | Olympus Camedia D-550 Zoom Digital Camera
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Konica Minolta DiMAGE A200 Digital Camera Logo
61 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
