Question about Motorola Mobility RAZR V3
RINGER STYLE the time iwant to change my ringer style, i cant open it, and it go back to the main menu. how can i fix it?
  • 87 Answers
Try doing a master RESET first. This will reset everything on the phone back to factory but you will keep all your information. If this doesn't work, I would try a master CLEAR.
Keep in mind that if you do a master CLEAR, this will erase any aftermarket data in the phone. Phone numbers, pictures, multimedia messages, text messages etc., and also set everything back to factory default.
Both of these options can be found under MENU>SETTINGS>INITIAL SETUP> (at the bottom of this list you will see both options vor Clear and Reset) - the code (unless you have changed it) is 6 0's. (000000).
Please remember to rate if this was helpful. If this doesn't work, there are alot more options, this is just the easiest and most common fix for something like the problem you are having.
Posted on Sep 04, 2008
To RAISE ringer volume on 5.8 Vtech instructions
This phone doesn't give you a way to change the ringer volume. However page 9 of this manual describes how to change the ringer style.
Mar 27, 2013 | Vtech IA5854 5.8 GHz Cordless Phone
How to RAISE ringer volume on 5.8 Vtech instructions
The IA5854 doesn't give you a way to change the ringer volume. However page 9 of this manual describes how to change the ringer style.
Mar 27, 2013 | Lands Phones
We dont know how to turn the ringer down on the phone
The IA5864 doesn't have a ringer volume control but it does offer you a choice of several different ring styles, some quieter than others.
With the handset in idle (off) mode, press PROG. Press up/down until the screen displays "RINGER:" and the current setting. Press SELECT and you'll hear a sample of the ring. Press up/down to change the style. You'll hear a sample ring each time.
Full instructions are on page 9 of the manual at
Jul 09, 2011 | Vtech ia5864 Cordless Phone
Where is the volume control on the stupid phone, it is nowhere in the menu and no buttons or slider control
While on a call, press down/CID to decrease or up/DIR to increase the volume. (page 11)
To change the answering machine volume, use the VOL- and VOL+ buttons. (page 31)
To change the ringer style, press PROG, use up/down to select "RINGER". Use up/down to select the desired style and press SELECT. (page 9)
The above page numbers are from the manual at
Jun 21, 2011 | Vtech ia5864 Cordless Phone
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Motorola cell phone sound problems W315
On the left side of the phone are two button: A rocker button and a push button. With the flip CLOSED, push the rocker button down. you will see Style:Silent. Push the other button until Style:Loud comes up. Push the rocker button down again to exit the function. Open the Flip and use the rocker button to set the Ringer volume. You can set the ringer volume however you want for each style. My phone swiches by itself constantly when I put it in my jeans pocket, very annoying.
Nov 01, 2008 | Motorola Mobility W315 Cellular Phone
I have a motorola bz60. just went on line to download music and wallpaper.but i dont know how to get it from my messages to my media gallery music and pictures
Here is how to set your default ringtone:
Main Menu Settings Audio __ Detail (2nd line .. if style:loud then line 2 will say Loud:Detail .. if style:soft then line 2 will say Soft:Detail) Now you'll see
Ring Volume: Calls: IM:  Messaging: Voicemail: Calendar Alarm: Data Calls: File Transfer: Ringer IDs Key Volume: Reminders:
Click on Calls  Click on Music
Now you can set the default ringtone.
To set a specific ringtone for each person in your address book:
Main Menu Address Book Click Options Click Edit Contact Scroll down to Ringer ID Music
Now you can set ringer ID for that contact.
Aug 08, 2008 | Lands Phones
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Motorola W 490 individual ringtone
To assign a ring alert (ringer ID) to an entry:
Phonebook > entry, then press
Options > Edit Contact > Ringer ID > ringer name
Note: The Ringer ID option isn’t available for
entries stored on the SIM card.
To activate ringer IDs:
> Ringer IDs > On
Dec 13, 2007 | Motorola Mobility RAZR V3
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
