Question about Sony FWD50PX2/S 50 in. Plasma Television
No sound when using HDMI Cable Sony FWD50PX2/S
No sound comes through the set when I use the HDMI cable. On the other channel I get sound from the component video. The picture is fine with the hdmi cable. Just no sound. Could it be the cable, the set or the dvd player or am I missing something?
Thanks,
Adam
  • awasesq Sep 04, 2008
    this is for a
    Sony FWD50PX2/S
SOURCE: TV not finding Digital Channels from Cable Box
I just bought Sony LCD 46 inches, with model KDL 46 V 2500 about less than 9 months,now TV lost digital channels, I tried every thing to program it but it's not working, when I program it the screen come up and stay about 20 minutes for searching digital channels then disappeared.and always no digital found.I don't know what wrong?
Posted on Feb 07, 2008
HDTV GURU
  • 261 Answers
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
Posted on Feb 08, 2008
We had the same problem. Called Sony and they advised there was a "Software Mismatch" and suggest using a newer set top box. I'm just going to use the component. You would think they could resolve this with a firmware flash or something. Hope this helped.
Posted on Feb 27, 2008
Cybertech
  • 149 Answers
SOURCE: Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
Posted on Apr 10, 2008
We have Comcast and we plugged the cable straight into our Bravia, searched for Digital Channels and it found 131. We actually get all the HD channels that we had using the box, plus a few more. It's worth a try.
Posted on Aug 24, 2008
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
Sony BDV 370 home cinema system and Sony 40hx703 television. The home cinema plays disks etc. through the cinema speakers. But will not play television sound through the cinema speakers it is connected...
You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
Aug 29, 2010 | Sony BDVE300 Theater System
Sound issues with HDMI connection.
manape7
It depends on the device that you are connecting to the HDMI Cable to. Some devices like LCD monitors are not designed to pull audio from the HDMI channel. In those cases you will need to use the Optical or Analog audio output. Note when you do this you wil need to change the settings in the audio setting option to select those outputs.
Let me know if you have any problems or questions
Issken
http://www.fixya.com/users/issken
May 30, 2010 | Sony Playstation 3 (PS3) Console
I just hooked up a Time Warner Cable 4250HD Box via HDMI to DVI cable to a 50 inch Sony Grand Wega. The problem is on some channels the bottom of the screen (like a news crawl) gets cut off. This happens...
You need to make sure that the settings on your TV for the DVI connection are set properly. It sounds as if it is set to stretch or zoom. The reason the HD channels look great is that they dont zoom because the resolution fills up the entire screen without stretching.
I know you want to use your HDMI cables, but since you are going HDMI to DVI you are removing the benefit of the single cable since you still have to use audio cables. You are not going to get any appreciable difference between the setup yo uare using and the component (red, green, blue) cable.
If I have helped you, please rate me as such. It allows me to help others. Thank you.
Aug 06, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
Jul 17, 2009 | Sony Playstation 3 (PS3) Console
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
Hdmi channel not showing PS3 only sound
might be problem with PS3 rather than telly. Try another HDMI cable in case something wrong with yours. You can try and reset PS3 video output by holding power button down (when in standby mode) until it beeps, them use original cable and see if that shows up on your TV. If so reconnect HDMI cable Ps3 will detect it and change settings back to HDMI then see if the TV picks it up.
Dec 11, 2008 | Televison & Video
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Tv sound on home theater kit
Hi Every one.
Had same problem with my HDMI connection on my sony bravia and sony theatre system, resolved by conecting a scart lead from the theatre system to one of the free scart sockets on the back of the TV, leave your HDMI connection in place as the DVD signal comes from this,
hope this helps!
Dec 20, 2007 | Audio Players & Recorders
Sony fwd50px2/s
The monitor should have come with several cables and adapters. One adapter converts the stereo RCA plugs to a stereo 1/4 inch plug that connects next to the dvi outlet.
May 12, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Sony FWD50PX2/S 50 in. Plasma Television Logo
89 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
