Question about Konica Minolta DiMAGE A200 Digital Camera
What is the frame rate of LCD display? - Konica Minolta DiMAGE A200 Digital Camera
    Master:
  • 425 Answers
Both EVF and LCD displays at 60fps for still image recording and 30fps for movie recording.
Posted on Sep 15, 2005
Need to know how to replace a cracked screen on dell adamo 13
Hi
Click here to know how to replace and also to know more about the replacement instructions.
Regards,
Saleem
Jul 14, 2011 | Miscellaneous
When the computer comes on it starts fading out then it goes blank
Laptop? The Inverter is going bad. (Screen Inverter)
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to the Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average Backlight is approximately half the thickness of a No.2 pencil, and 3 to 4 inches long.
There are many variations, however)
An Inverter is used to convert the electricity provided by the laptop, for the LCD screen, and Backlight.
90 percent of the time the fault is a bad Inverter.
The Inverter is usually located behind the Display Bezel in the Display Assembly, and at the middle/bottom of the LCD screen.
It is a small circuit board.
Example of a typical Inverter,
http://www.laptopparts101.com/screen-inverter-board/
[The Display Assembly consists of all the parts that make up the display.
A) LCD screen
B) Display Bezel (Thin plastic frame in front of the LCD screen, and surrounds the LCD screen)
C) Top Cover (Top plastic piece of laptop)
D) Screen frame (Metal frame that resembles a picture frame. Surrounds the LCD screen.
{The LCD screen is composed of layers. This frame keeps them in an aligned state)
E) Hinges
F) Hinge Brackets
These are a few of the Display Assembly hardware components.
What is the laptop manufacturer's name, and Model Number?
(On the bottom of the laptop is the Model Number. Sometimes referred to as Product Number. P/N)
If I knew this information I may be able to provide a link to a free Service Manual
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 03, 2011 | Computers & Internet
My hp dv600 when powered up looks normal but if i give it a few seconds the screen goes black and wont come back i shined a light and i do have picture but no light maybe ballast?
alejandro,
Very similar to the Fluorescent lamps, (Bulbs), used in homes and businesses, but on a MUCH smaller scale.
HP Pavilion dv6000z series Notebook PC, is a general series designation. The EXACT model number is on the bottom of the laptop in a white Service Tag.
The HP Pavilion dv6000z series of Notebook PC's used either an LED or CCFL type of Backlighting.
Depends on which model it is.
http://www.screentekinc.com/backlight-ccfl-led-explained.shtml
As stated in the above information a Backlight is mounted in the back, or on the side of the LCD screen.
The LCD screen is composed of layers. These layers are held together by a metal frame which emulates a picture frame. If the Backlight is a side unit it will be held in place next to the layers, and inside the metal frame.
[Which means the LCD screen's metal frame, (LCD Panel Frame), needs to be opened on one side.
This will leave the layers which compose the LCD screen loose. The layers MUST be held in the proper placing when changing out the Backlight. Not an easy job to accomplish]
An Inverter is used to change the power coming from the laptop, to be used by the LCD screen, and Backlight.
90 percent of the time the problem is the Inverter.
The Inverter for the Pavilion dv6000z series of Notebook PC's is located inside the Display Assembly.
The Display Assembly is the
1) Display Enclosure Cover, (Plastic top of laptop),
2) LCD screen,
3) LCD Panel Frame, (Metal frame around LCD screen),
4) Display Bezel, (Thin plastic frame which surrounds the LCD screen in the front)
5) Camera Module
6) Inverter
7) Display Enclosure Cover Hinges (2)
8) Display Enclosure Cover Hinge Covers (2)
9) Wireless Antenna Transceivers and Antenna Cables
10) Microphone receivers and cables
11) Various mounting screws
[The Top Cover for a Pavilion dv6000z series Notebook PC is essentially the Palm Rest. The cover under the Keyboard]
With the Display Bezel removed the Inverter is located at the bottom.
(Display Assembly removed from laptop first)
HP Support > Pavilion dv6000z Notebook PC series> Manuals>Service Manual>
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3224052&
One example of an Inverter for an HP Pavilion dv6000z series Notebook PC,
http://www.amazon.com/DV6000-DV9000-V6000-INVERTER-AS0231721C1/dp/B00480MXUS
Please post additional questions in a Comment.
Regards,
joecoolvette
Jun 11, 2011 | HP Pavilion dv6000z Notebook
WHAT IS THE DIFFERENCE BETWEEN 1080I AND 1080P AND WHICH ONE IS BETTER?
1080i vs 1080p - Similarities and Differences Between 1080i and 1080p
How 1080i and 1080p Are Both The Same and Different
1080i and 1080p are both High Definition display formats for HDTVs. 1080i and 1080p signals actually contain the same information. Both 1080i and 1080p represent a 1920x1080 pixel resolution (1,920 pixels across the screen by 1,080 pixels down the screen). The difference between 1080i and 1080p is in the way the signal is sent from a source component or displayed on an HDTV screen. In 1080i each frame of video is sent or displayed in alternative fields. The fields in 1080i are composed of 540 rows of pixels or lines of pixels running from the top to the bottom of the screen, with the odd fields displayed first and the even fields displayed second. Together, both fields create a full frame, made up of all 1,080 pixel rows or lines, every 30th of a second.
In 1080p, each frame of video is sent or displayed progressively. This means that both the odd and even fields (all 1,080 pixel rows or pixel lines) that make up the full frame are displayed together. This results in a smoother looking image, with less motion artifacts and jagged edges.
Differences Within 1080p 1080p can also be displayed (Depending on the video processing used) as a 1080p/60 (Most common), 1080p/30, or in 1080p/24 formats. 1080p/60 is essentially the same frame repeated twice every 30th of a second. (Enhanced video frame rate.) 1080p/30 is the same frame displayed once every 30th of a second. (Standard live or recorded video frame rate.) 1080p/24 is the same frame displayed every 24th of a second (Standard motion picture film frame rate.)
For more detalis visit http://hometheater.about.com/od/televisionbasics/qt/1080ivs1080p.htm
Oct 09, 2010 | Vizio VP322 32 in. Plasma TV
How do i change the frame rate on my samsung lcd
You can't. It changes automatically to fit the input video. 480i, 480p, 720p, 1080i. have different frame rates.
Apr 19, 2010 | Samsung LN-S4695D 46 in. LCD HDTV
Avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Mar 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
Refresh rates on flat crt moniter
The refresh rate (most commonly the "vertical refresh rate", "vertical scan rate" for CRTs) is the number of times in a second that display hardware draws the data it is being given. This is distinct from the measure of frame rate in that the refresh rate includes the repeated drawing of identical frames, while frame rate measures how a video source can feed an entire frame of new data to a display.
For example, most movie projectors advance from one frame to the next one 24 times each second. But each frame is illuminated two or three times before the next frame is projected using a shutter in front of its lamp. As a result, the movie projector runs at 24 frames per second, but has a 48 or 72 Hz refresh rate.
On CRT displays, increasing the refresh rate decreases flickering, thereby reducing eye strain. However, if a refresh rate is specified that is beyond what is recommended for the display, damage to the display can occur.
Frame rates are considered important in video games. The frame rate can make the difference between a game that is playable and one that is not. The first 3D first-person adventure game for a personal computer, 3D Monster Maze, had a frame rate of approximately 6 frame/s, and was still a success. In modern action-oriented games where players must visually track animated objects and react quickly, frame rates of between 30 to 60 frame/s are considered minimally acceptable by some, though this can vary significantly from game to game. Most modern action games, including popular first person shooters such as Halo 3, run around 30 frames a second, while others, such as Unreal Tournament 3, run at 60 frames a second. The framerate within games, particularly PC games, typically varies with the hardware configuraton, and depending upon what is currently happening in the game at a given moment. When the production of a frame makes large demands on the CPU and / or GPU, the framerate falls.
A culture of competition has arisen among game enthusiasts with regards to frame rates, with players striving to obtain the highest frame/s count possible. Indeed, many benchmarks (such as 3DMark) released by the marketing departments of hardware manufacturers and published in hardware reviews focus on the frame/s measurement. Modern video cards, often featuring NVIDIA or ATI chipsets, can perform at over 160 frame/s on graphics intensive games such as F.E.A.R. One single GeForce 8800 GTX has been reported to play F.E.A.R. at up to 386 frame/s (at a low resolution).[citation needed] This does not apply to all games: some games apply a limit on the frame rate. For example, in the Grand Theft Auto series, Grand Theft Auto III and Grand Theft Auto: Vice City have a standard 30 frame/s (Grand Theft Auto: San Andreas runs at 25 frame/s) and this limit can only be removed at the cost of graphical and gameplay stability. It is also doubtful whether striving for such high frame rates is worthwhile. A regular CRT monitor (somewhat outdated now) runs at up to 85 hertz, meaning that any performance reached by the game over 85 frame/s is discarded. For that reason it is not uncommon to limit the frame rate to the refresh rate of the monitor in a process called vertical synchronization. However, many players feel that not synchronizing every frame produces sufficiently better game execution to justify some "tearing" of the images.
In conclusion: If you want better experience in games you must upgrade your videocard.
Jul 29, 2009 | Microsoft Windows Vista Home Premium...
LCD Display Won't Come On
check the LCD frame, maybe the frame is loosen,, make it tighten,, try it
May 29, 2009 | AT&T Cell Phones
LCD and Gaming
Monitor should not have anything to do with frame rate.
If you have increased the resolution of your video card because the 19" is larger than what you had before, that could cause a frame rate issue.
Something else got installed, that is slowing down your machine...
Coincidence...
Connect the old monitor and what is the outcome? Does the frame rate improve again?
May 15, 2008 | Acer AL1916W 19" LCD Monitor
No pic framing on LCD display - playback is OK
ON digital slr cameras there is no pic framing on the LCD display.
Apr 25, 2008 | Pentax K100D Digital Camera
Konica Minolta DiMAGE A200 Digital Camera Logo
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
