Question about InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector
HP VP6210 won´t turn on at all
Hi, my HP VP6210 Projector won´t turn on at all, nothing, completly dead. I have tried different power cords and nothing, I have check the voltage of the cords to see any damage and they are OK, the deliver the 120V to the projector but it´s dead, exactly as if it had a blown fuse but I can´t find it´s location, I opened it and there is no fuse (at least any I can see).
Please help me ut, it´s out of guarantee but I have used it for no more than 50 hours! I use it few times a year.
I can´t find any repair manual on the web to try to locate the fuse will power up, lamp light not on fan works,no sound either.
help please
cj
Try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Posted on Oct 13, 2008
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: HP VP6210 won´t turn on at all
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Posted on Dec 23, 2009
My nc6400 won't power up even when connected to a power adapter. How can I fix this?
Since you already tried another power cord (assuming that it was a working cord and for the exact same model). Then I would say your motherboard is dead.
Aug 17, 2012 | HP Compaq nc6400 Notebook
Can l have instraction to conect projector with pc
connect the vga cable to your projector and to your computer.
set your projector input to pc
on your computer you will have to set it to duel screen
usually this is the f8 key or some are fn + f8
or you can get a vga splitter on desktop computers.
hope this helps
Jul 08, 2012 | HP VP6210
My panasonic TH42PX60U won't power up. No red light flashing. Completely dead. I tried unpluging and using different power outlets. Still nothing. Any help?
1. Check all cable and input connections are secure & all are tightly connected.
2.Check power cords and also power outlet , if possible try to unplug and reconnect . A replacement of power cable or use another power outlet is another good option.
3. If you are sure that power is reaching your TV(check it out with a test lamp that both neutral & ground or earthing is functioning, i.e. the test lamp glows) then probably the power board needs replacement.
Dec 10, 2011 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Hi my Sony VPL S600 won't turn on at all. It seems like it's not getting any power. I turned it off and a few days later i went to turn it on and nothing, no lights or sound or anything.. What is the...
I know this sounds silly, but check the switch on the back of the projector. There is normally a hardware switch, somewhere around where the power goes into the projector. Make sure this is on. Second, try taking out the bulb, WITHOUT TOUCHING ANY GLASS, and replace it. There is often a safety switch that prevents it from powering up without a bulb. Also, try using a different power cord, or try using a different outlet. If it works with a different power cord, your cord was bad. If it works with a different outlet, your outlet will need to be inspected by a qualified electrician, to make sure there are no shorts or other hazards. If none of this works, contact Sony about getting the projector in for repairs. Please do not try to open the projector your self, there are a lot of capacitors that store energy for long periods of time.
Thank you! Jordan
Mar 01, 2011 | Sony VPL S600 LCD Projector
Hp zd9500 My I.T. put in a new hard drive the other day and it was running fine. Today I turned it on, it was booting up and then went completely dead - no lights, or anything. The power cord is working -...
You could test to see if hard drive is culprit by removing the drive. This is done by removing the access panel on bottom of laptop and slipping out the drive. Once out, try turning on laptop. It won't boot up, but you should get power light on.
I suspect you will not.
If so, problem is in power supply within laptop. Fixing requires a full diagnostic check of the power supply and battery charger. I highly recommend a trained technician for that.
Oct 05, 2009 | HP Pavilion dv6000z Notebook
Projector will not turn on. No lights no nothing
I opened mine up and in th front was a red reset button now I'm good!
May 22, 2009 | Sharp XR-11XC Multimedia Projector
Dead Unit
The projector bulb was burned out.
Jul 30, 2008 | Epson EMP-740 Multimedia Projector
Jul 18, 2008 | Office Equipment & Supplies
Projector
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Feb 19, 2008 | Hitachi PJTX100 Multimedia Projector
InFocus LP120 / 1000 Lumens / XGA / DLP Projector Refurbished Multimedia Projector Logo
736 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
