Question about Compaq Presario 700 470024-192 Notebook
Laptop can't get past POST
My Preario 700, on power up with either battery or mains, will not get past POST. If I hit when the little white square appears I see the POST happening and it gets stuck at "ATAPI CD-ROM: sR243T" and will remain there until quite possibly the next ice age. If I hit F10 it proclaims that it is entering setup but again, it will just sit there until the end of the universe as we know it.
Any suggestions ??
Ooroo
Mark F...
    Sergeant:
  • 293 Answers
It sound's like you're having a cmos issue. The controller card for the cd-rom is hanging waiting for something else to run. Remove any media (cds etc) from the machine and start it again. Enter the cmos and turn the CD rom off as one of the boot devices. Then try to restart the computer. If this doesn't work then I would guess that the installed OS is fried and needs to be reinstalled as the only other thing that could cause this is a corrupted ini or dll file that the system can't read that is necessary for the cd rom to operate or function properly.
Posted on Sep 04, 2008
How to reset password,bios
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits
in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and
pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in
upper left corner( laptop battery slot is on right, DVD
drive is facing away from you)
5)Using a magnifying glass (unless you have perfect
vision)in the upper left corner you will see JOPEN1 with
a white silkscreen square next to it . Inside the square
you will see what looks like the letter T over a U.
Using a metal paper clip short the U to the Silver 1/4"
post connecting the motherboard to the laptop case(this
is you ground, it is located above what looks like a
silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery
and test start laptop. you should see a selection of F1
or F2 for setup. Using the F2 gets you into the Bios
menu where you reset the time and date. Then Tab over to
the SECURITY setting tab and change your passwords. Now
hit F10 key ,yes to save and your done!
check the video as well
https://www.youtube.com/watch?v=Eo1gg1EZV-o
Apr 03, 2015 | Toshiba Satellite A135-S2276 Notebook
Compaq presario C301TU laptop no power
Remove the main battery and try to power up, if it works replace the battery, no change! remove one stick of ram memory and repeat keeping one stick at all times, if none of these work the problem is more than likely the motherboard.
Jul 28, 2012 | Compaq Presario 700 470024-192 Notebook
Toshiba satellite pro sp2100 -> Mod No: ps210E
TOSHIBA
Remove Laptop Battery Remove Memory Cover Spread spring clips to outside and pull out RAM memory Remove clear vinyl label opposite RAM memory slots In the upper left corner you will see JOPEN1 with a white silkscreen square Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
May 15, 2011 | Toshiba Computers & Internet
Cant find cmos battery on toshiba satelite l300 motherboard, need to reset hdd password
You cannot reset a HDD password (if its a bitlocker one) and you have lost your encryption key reset file and forgot password.
if you mean the BIOS/Power on password then try this
May 10, 2011 | Toshiba Satellite Pro L300 Notebook
How to bios recovery on toshiba satellite l500.where is the chip on matherboard
Follow these steps:
  • Remove Laptop Battery
  • Remove Memory Cover
  • Spread spring clips to outside and
  • pull out RAM memory
  • Remove clear vinyl label opposite RAM memory slots
  • In the upper left corner you will see JOPEN1 with a white silkscreen square
Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key. Regards, Shami
Dec 03, 2010 | Toshiba Satellite (K000004080) Motherboard
I need to reset the bios password on my daughters laptop
ReSetting Bios Password on Toshiba Satellite A135-S2386
2)Take off Memory Cover(underneath - square cover, Sits in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in upper left corner( laptop battery slot is on right, DVD drive is facing away from you)
5)Using a magnifying glass (unless you have perfect vision)in the upper left corner you will see JOPEN1 with a white silkscreen square next to it . Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4" post connecting the motherboard to the laptop case(this is your ground, it is located above what looks like a silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Now hit F10 key ,yes to save and your done!
Note: if your having trouble your most likely grounding the ground(that blob of solder about 1/8"dia on both ends of the "silkscreen chip outline"
Sep 23, 2010 | Toshiba Satellite A135-S2386 Notebook...
I forgot my password and can't get in. Is there a
Well, the problem with this could be a simple one or difficult depending on what motherboard you have in the system. Look for the CMOS battery, it usually resides in one of the compartment on the bottom of the case.
On the bottom of the laptop, take off the access door to the memory, see if your laptop has the Cmos battery that has a small plug attached to the battery. There are two types that went with the F700...one would be a "Disc" battery that sits in a slot on the motherboard. The other is that same battery but it is covered and has a cable and plug attached to it. Here is what needs to be done to wipe out the BIOS password. The contacts between the + and - need to be grounded while the laptop is turned on. You can accomplish this with just a small wire that is attached to each lead. In the disc and socket type, ground the side contacts with the center contact. In the case of the plug and cable, simply ground the two pins of the socket on the motherboard. This will effectively "bridge" the two contacts. Now power up the laptop with this bridge in place. Wait approx. 2-3 minutes, ot long enough for the unit to "POST". Now shut the laptop down, remove the unit's main battery. Remove the "bridge" between the two contact points and re-install the CMOS battery. Now using only power from the AC adapter, power the laptop back up. If it still asks you for a password, just hit enter and see if it will let you into the BIOS. If it does not ask for a password then you are all set, either way. Once it powers on and there is no problem, power it down and reinstall the main battery. Reboot once more.
Jun 07, 2010 | Compaq Presario 700 470024-192 Notebook
I am a tech trying to reset the password on a Toshiba 135-s2326
ends of the "silkscreen chip outline" This is about as simple as i can break it down
There is no guaranty this will work though.
Jan 05, 2010 | Office Equipment & Supplies
Compaq Presario 700 Series Laptop wont turn on
Please first make sure that your adaptor is working.
Try to remove the battery and connect your laptop to the adaptor. Swith on. If nothing chages, then there is good chance that you have a motherboard related problem.
Nov 23, 2008 | Compaq Presario 700 470024-192 Notebook
RE: bios password reset
You have to remove the CMOS battery then put it back in to reset the password. The CMOS battery is on the motherboard itself, so you will need to strip down the computer to the motherboard and do it. The battery looks like a little watch battery. There are a few online tutorials you can find on google to take apart your computer.
Feb 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Compaq Presario 700 470024-192 Notebook Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
