Question about Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 cannot ring 1800 or 1300 numbers. Telstra can ring 1800 & 1300 numbers by-passing the PABX and plugging straight into the ISDN NT1. Suspected programming problem with system. Please advise on how rectify?
  • Panasonic Master
  • 2,460 Answers
Not knowing your complete dialing plan makes it difficult to figure out why you can't "ring" a certain number. What do you get? Can you call local? Is 1800 or 1300 a local or "free" call or is it long distance or premium? And, do you get bounced with a display that says something after you dial 1800 or do you have to dial a complete number.
These are all installer questions. It would be well beyond the scope of a public forum to do someone's restriction tables.
Carl
Posted on Sep 04, 2008
How can i program id caller for kx-t7330
Depends on line type, if ISDN lines caller ID is built in, if analogue lines you will need a cli card, tI display cli press TRSF while the phone rings, if you have subscribed to the caller I'd service of course
Oct 09, 2013 | Panasonic KX-T7630 Corded Phone
All lines are showing line not assigned. we cant ring out or receive calls on the 6 phones in the office
Contact your line provider the system cannot see the lines , if you have ISDN lines these should show a green light on each and should be solid when connected and flash if disconnected
Sep 02, 2013 | Panasonic KX-T7630 Corded Phone
How to store numbers using panasonic KX-T7630
Hello Jd,
For storing numbers in panasonic KX-T7630
While on-hook Enter phone number(max. 32 digits). AUTO DIALSTORE OR Press STORE or ENTER. Enter name(max. 20 characters). AUTO DIAL Store or Pres STORE or ENTER.Press Exit or Pause.
Aug 18, 2011 | Panasonic KX-T7630 Corded Phone
Panasonic kx-t7630. PABX lines have been reducede from 5 to 3. how can re assign CO buttons? now line 2 and 5 are no more in use, but still show as free. And if I press usual 9 to get outside line it...
If you know how to do system programming, the best thing to do is to move the lines into the first 3 positions on the cabinet and go into system program 600 and reduce the lines to 3. Your system installer or manager may be able to do the programming in less than 30 minutes.
Carl
Oct 21, 2010 | Panasonic KX-T7630 Corded Phone
How do I get my panasonic kx-t7630 to ring more than 3 times before going to my voicemail?
If you've set call forwarding from the set, try dialin *713 and a 2 digit number from 00-99. It's the number of seconds before the call forward and a ring cycle is approximately 6 seconds, so start with 24 and go up from there.
There's another feature that will work against you, and that's the transfer recall time. It may be set to 20 seconds, so you will never forward before the recall timer. It's set on a systemwide basis.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
Are you able to redirect calls coming into the Panasonic KX-T7630 phone system to a mobile handset phone
I can, but I'm not sure you can. On this side of the pond, we can send an inward CO call to an ICD group which has a forwarded number programmed into it. For example we usually take the owner's station and add 400 to it so his extension may be 110 and 510 is his cell phone. That way, it can be dialed from an intercom, as a transfer, from voice mail, or as a call forward argument.
Ring your engineer if you're not familiar with ICD groups and Panasonic programming. They should be able to guide you and tell you whether it can be done, especially if you have ISDN trunks.
Carl
Dec 06, 2009 | Panasonic KX-T7630 Corded Phone
Number of rings before going to voicemail on KX-T7630
Press the FWD/DND button, then scroll through the menu button until the screen shows "FWD No Answer time". Then use the number key pad to change from 000 seconds to 010 seconds (or longer if required). Then exit out of the menu.
Jan 22, 2009 | Panasonic KX-T7730 Corded Phone
My Phones only ring twice before it goes to VoiceMail
What you can do is go into the management console for your system and find the forwarding this is under extentions option 2 fwd/dnd select your extention number and on the bottom option FWD No Answer Time (s) set it to 10 or more and this will change the number of rings.
I use a KX - TDA600 PABX so I hope this helps
Jan 06, 2009 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
95 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
