When i switch ON the TV it automatically switches back OFF in about 2-3 seconds.
I have a Sony Trinitron KVG21Q1 TV. When i switch ON the TV it automatically switches back OFF in about 2-3 seconds. Sometimes i see athin silver line in the centre of the display also none of the lightsin front flashes. What is the problem with my TV?
It is about 7 years old. I was advised by a person, to check around"Vertical Out" area to see if there is any dry solders but i didnt findany.Also i checked the whole board for any dry solders or any shorts or for any burnt components didnt find any.
The tv is old but my grandparents use so it not muchused and they dont want to go to a new one as new tvs are complicatedfor them to use.
  • FckForcedReg
    FckForcedReg Sep 05, 2008
    Thanks for the solution i will do it let you know about it. Also some time my display doses something like in picture(Pincushion) if i tilt the circuit board or the outer shell it goes of what can cause, this isue started before the TV started switching OFF.
  • FckForcedReg
    FckForcedReg Sep 06, 2008
    I replaced the Vertical IC but still no change the TV shuts off as i switch it on within 2-3 second, but i still can hear clear audio of the channel it is tuned to.
  • 4,234 Answers
The vertical IC is faulty and needs to be replaced. Look for a small flat IC attached to a heat sink. It will be marked LA7837 or something similar. Replace that part and update this with your results. That may resolve the problem or at least get you a distorted picture which will indicate a few other parts that need to be replaced.
Keep us posted.
Dan
Posted on Sep 04, 2008
  • ABRsvcs Sep 05, 2008
    The picture you posted is inded a problem with the pincushion circuit. Unfortunately I do not have access to the service manual for your model so I can't tell you what part is bad. I can tell you that it is a capacitor in that circuit though. The vertical IC failure would cause the picture to look line a single horizontal line across the tube.
    If by moving either the board or the set the problem gets worse or cured, the problem is likely to be a bad solder connection on the board. Resolder any connections that appear grainy or have rings. That may cure the problem without the need for parts.
    Keep me posted.
    Dan
Sony Trinitron KD-28DL10U switched off suddenly to standby mid programme and won't come back on.When trying the remote on I can hear it click on and immedietly off again.Switched off at set and socket and...
Hello
In time as the Sony Trinitron ages it begins to have power issues. While this can be true of most tube televisions it's the rate and severity at which this happens to Trinitrons that makes it particularly of note. Many Trinitron owners have complained of the Trinitron set turning itself off randomly and frequently. Some sets have failed to stay on for longer than a few minutes at a time. Eventually some sets will not turn on at all. These problems grow more severe with age.
Check the power cable running from the Sony Trinitron 32. Make sure the cable is completely inserted into the power connection on the rear of the TV as well as the local power outlet.
Disconnect the power cable from the electrical outlet, then plug it into a different connection. It is possible to electrical outlet has died, forcing you to obtain a power current from a different source.
Check the cable connection running from the cable/satellite receiver or VCR. If the TV is on but no picture is on the screen, the problem is most likely due to a connection issue.
Power off the cable/satellite receiver, then press the "Video" button on the remote control to switch the Trinitron 32 to the video input signal. Turn on the cable/satellite receiver and the programming now loads onto the television screen.
Nov 21, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
No picture no sound
Forward voltage/current problem....needs a new board....You might try unplugging it for a few hours...If the TV starts you will need to leave it on until it gets repaired or replaced.
Jun 12, 2009 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv Switchs off automatically
Hello SpyTan,
You have a vertical deflection problem. This is either caused by the vertical yoke transformer going bad or the vertical coupling capacitor going bad. It may even be one of the components in the biasing circuit that delivers the vertical deflection signal. In any event this may be causing excessive current which then causes the shutdown circuit to activate. I would have a qualified TV technician check the vertical defelection section of the TV.
I hope This helps,
Thank you,
Shuttle83
Oct 04, 2008 | Televison & Video
Sony FD Trinitron WEGA Tv KV32FQ86E two flashing led
Check 470 uF 450 V in the power supply. I don't know if the chassis is the AE-5, but I had a similar case and the capacitor was bad.
Please tell me if it worked.
e-mail: jlopes.electronica@sapo.pt
Aug 11, 2008 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Sony tv KV25X5U
have to replace the push switches behind the front buttons for channel change, chassis has to come out to repair
May 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Double images on my Sony FD Trinitron WEGA KV-27FS100
You may want to try disconnecting the power for about 30 seconds and rechecking the TV. Otherwise, it may not be worthwhile repairing.
May 29, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
