Question about Protron PLTV-32 Television
Cable hook up
I disconnected my other tv went to hook up new tv didnt see a cable hook up on tv
  • pumpkin416 Sep 05, 2008
    hook up to cable
    Scholar:
  • 65 Answers
Most new televisions High Definition televisions in particular may not have the regular cable hook up. They generally have an HDMI connection that you connect with an HDMI cable.
To me it is similar to a computers usb connection.
What type of television do you have?
Posted on Sep 04, 2008
New starter wont start just click
Will it jump start? What shape is the battery in?
Mar 23, 2014 | Dodge Grand Caravan Cars & Trucks
Samsung 42" Plasma HDTV cable hookup problem
There sould not have been sparks. Check the following: Using a voltmeter check between the cable itself and ground. There should not be any reading (anything less than .1V is normal). Check again between the inner hole of the RF connector and the outside part. Again there should be less than .1V. If you read any voltage at the RF connector, the TV is faulty and should be exchanged. If you read voltage at the cable, have teh cable company check again.
Dan
Jul 30, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
No sound
Check the tv menu to ensure that speakers are on. And disconnect any cables that went to the surround sound.
Nov 30, 2013 | Sylvania LC420SS8 LCD TV
Frys tvs .luckly they were old 13" tvs .dont have any more tvs that I would want to fry .this happened twice hooked to tv in travel trailer,turned on tv went out checked wall voltage 118 volts rca...
this could be your power brick being faulty and letting to much power through to the xbox and earthing it through the TV resulting in the TV frying.
try changing your AV cables from the xbox to TV and your power brick and leads going to the console
Jan 28, 2010 | Microsoft Xbox 360 Console
A humming noise coming from tv when cable and ps3 are hooked up
I fixed mine by removing the cable wire from my tv. For some reason tv cable and the old PS3's cause a problem.
Feb 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 only works with hdmi cables?
Did you try holding down the Power button until you heard 3 beeps? It is not uncommon for the video output to exceed the resolution of different television. This hard reset feature was added to troubleshoot such a problem, factory resetting the video settings.
Apr 02, 2017 | Sony Playstation 3 (PS3) Console
Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
Jul 16, 2008 | Vizio P4221 Television
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
i have the same model, so try going to menu and doing the add/delete channel thing....also i found that i only get all my channels if the tv is set to catv instead of tv
Feb 22, 2008 | Televison & Video
Frozen on a menu screen
Just fixed ours with the same problem. You need to hit the volume buttons on the remote during the time the screen goes black but BEFORE it gives you the "Connect cables" message.It should trick the TV into giving you a blank channel.
Sanyo TVs are made notoriously cheap, and have little glitches like this. Best of luck, space cowboy.
Oct 13, 2007 | Sanyo HT27546 TV
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Protron PLTV-32 Television Logo
212 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
