Question about LG Microwave Ovens
LG Countertop Microwave why stopped rotating?
LG Countertop Microwave why stopped rotating inside?
    Genius:
  • 1,036 Answers
Microwave turntables are belt driven from a small motor.
Usually it is the belt that needs replacement.
Unplug, and remove the outer case to inspect the belt. If it is still tight and attatched, the chances are it needs a new motor - often it's cheaper to buy a new unit.
Posted on Sep 04, 2008
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
Need a new rotating base
go please to www.repairclinic.com or www. appliancepartspros.com
God bless you
Jul 17, 2012 | LG Galaxy Countertop Microwave Oven
LG Microwave oven Tried to remove the countertop light bulb. Glass came off metal base still in unit. How do I remove the base, ist screw type bulb?
try using a small potato,push it into the base while turning the potato.it may lock onto the base and unscrew it....UNPLUG IT FIRST...
Nov 16, 2010 | LG LMV1630ST Microwave Oven
NOT WARMING
I never encourage a non technician to repair microwaves as the internal voltage is truly dangerous. I will tell you that if you want a no noncence repair to your micro. then have the technician replace the magnatron:Capacitor and Hv Diode.(Will definately work well again.)Only problem, you need to identify the profile of the magnatron and wattage.)
Jun 05, 2010 | LG Galaxy Countertop Microwave Oven
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Have an amana countertop combination oven
the microwave was in use and when i press stop the microwave never come back on can you help me slove this problem
Jul 25, 2009 | Microwave Ovens
Turntable does not rotate
Well it seems that there is some fault in the turnable motor, turntable system consists of the motor and coupler, turntable support with rollers and the tray.
I have a video link to help you more on this -- how a turntable motor should sound when you rotate it by hand... please follow the below link -
http://www.youtube.com/watch?v=rPSWi_z7M58
If motor grinding... etc., it means you may have a bad motor or plastic coupler.
Post further comments if you need more help....
Good Luck!!
Mar 14, 2009 | Microwave Ovens
Microwave Ovens Logo
132 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
