Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune LR, Locked Rotor error code. What do I do. I live in Pasadena, CA
    Scholar:
  • 79 Answers
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new motor conversion kit which includes the motor, motor control board and the wire harness.
See www.neptunewaxmotor.com for disassembly photos and other Neptune information.
Posted on Sep 24, 2008
Westinghouse electric oven. 3 button clock timer relay. Model no PXN688S*40 Need wireing plan?
If you live in Pasadena, CA and need appliance repair service call us (626) 460-0903 or visit our website and schedule service online.
Appliance Repair Pasadena CA 626 460 0903 Pasadena CA
Sep 02, 2017 | Ovens
Maytag Neptune front loader, model # MAH5500BWW had a digital error code reading Lr. Will not agitate or spin out.
the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit boardat the top of the unit has lost connection to the motor and its controlboard at the bottom (connector loose) or 2) the motor and or controlboard at the bottom have trashed and need to be replaced (P/N12002039).
Hope that helps,
Thanks,
Lee
Jul 11, 2008 | Maytag Washing Machines
Error code LR
LR stands for "Locked Rotor." For some reason, the main board isn't detecting motor movement. The causes are too numerous for this format. Best to call a tech.
Oct 28, 2014 | Washing Machines
It said Lr on screen and stops
LR = Locked Rotor on the motor. Many things can cause this. Please contact me, with more details willing to help all I can.
Apr 12, 2014 | Maytag Neptune MAH5500B Front Load Washer
My Maytag washer will not complete a cycle. The code Lr is display on the front of the washer. I have pulled the plug and reset the breaker.
Hi.
LR stands for locked rotor. The code is returned by the Motor Control Unit (an electronic module connected to the motor and to central control unit). The code is returned when no motion from motor rotor is detected. With many models LR may be due to a factory defect. Please call Maytag and check if any recall has been issued for error LR concerning your washer model. If recall has been issued you will get a kit comprising a new motor and wiring harness.
You can also try temporarily resetting the error by disconnecting power at circuit breaker (or unplugging power cord). If the error message is prompted again call Maytag.
Regards.
Ginko
Aug 08, 2011 | Maytag Washing Machines
We have a maytag neptune washer and it is suddenly not working and displaying a code of LU it kinda looks like>?
perhaps and lr??? LR--- means locked rotor assy. you will need to replace your motor control board and motor assy, comes as a kit not a bad repair (NEPTUNE REPAIR KIT) if thats indeed the issue you seeing that is
Oct 09, 2010 | Maytag Neptune Washer
I have an Maytag neptune with an error code of Lr. It fills but doesn't seem to turn when washing.
Hi
Thanks for using FixYa. Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards. Please rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Getting error code LR
Hi
Thanks
Rylee
Oct 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Displays lr code
Hi
Thanks for using FixYa. Error Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Lr code went into service mode but wont respond to commands model #fav6800aww
Tom,
The LR error code can be a tough one to troubleshoot but I'll see what if any help I can be.
The LR code stands for Locked Rotor.
If you Power Cycle the 120VAC to the machine will the error code clear?
What cycle was the machine in when you took the error code wash, spin?
If you remove the front panel and with the 120VAC power cord removed from the service outlet can you rotate the Clutch Pulley CCW (Spin direction) or CW (wash/agitate) direction.
Sounds like you have the FAV6800A/FAV9800A Service Manual.
Let’s see if the drive system is free and not locked up…………Rich
Jul 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
599 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
