Question about Panasonic NV-DS29B Mini DV Digital Camcorder
Exact location of dew sensor for panasonic NV-DS29B
What is the Exact location of dew sensor?
  • 188 Answers
You can easily locate it pasted on the mechanism , either on the motor driving the mechanism or nearby capstan motor.
Posted on Sep 04, 2008
I have a Panasonic NV-GS 35 digiatl video camera. 'Dew Indicator' error is coming . How can I remove this problem??
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
Dec 25, 2010 | Panasonic NV-GS35 Mini DV Digital...
I can't watch back on the screen
screen conective might have broken,any way u can see it in the veiw-finder.
Mar 08, 2010 | Panasonic NV-DS29B Mini DV Digital...
Dew symbol on panasonic NV-DS60
My panasonic camera does the same- from what research I've done online the only method (that REALLY works) is removing the battery pack and hitting the camera (where the battery was at, don't hit it too hard) with the palm of your hand. I didn't believe this until I tried and *poof* it worked back normal.
Nov 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
Dew warning on Panasonic NV-DS29B Mini DV
I had the same problem, and solved it by having the heads cleaned.
Aug 27, 2008 | Panasonic NV-DS29B Mini DV Digital...
Dew problem
it is on the mechanical section and have two connection,use a 1k resistor to convert it..
Aug 23, 2008 | Panasonic NV-DS29B Mini DV Digital...
Transfer Movie Footage from my Panasonic NV-DS29B Camcorder to PC
You will need probably need a 4 pin to 6-pin firewire cable with adapter..
A software called Showbiz DVD2 was able to detect my camera and allow me to control the Camera options via the firewire cable to transfer the full video to my hard drive. You can also use a video program like Pinnacle or Roxio Media. Hope this helps you out. I know how bummed I was before.
Nov 02, 2007 | Panasonic NV-DS29B Mini DV Digital...
Flashing Power Light
The internal battery is worn out
Aug 05, 2007 | Panasonic NV-DS29B Mini DV Digital...
Power Light Flashing
HI
WHERE IS THIS SENSOR ?  PHOTO PLEASE ..
Jun 26, 2007 | Panasonic NV-DS29B Mini DV Digital...
Panasonic camcorder (NV-DS65) - Dew Indicator Problem
I found this on another site, but it WORKED great for me, and was a VERY easy fix, so I suggest everyone to try it before you go disassembling your camera. I know this sounds very stupid, but it actually somehow fixed my problem, so everyone should give it a go:
1) Turn the camera on.
2) When the dew icon is displayed, take off the battery and then hit/smack the spot on the camera where the battery goes a couple of times (not overly hard, but with some force).
3) Put the battery back and see if it's fixed. If it isn't, repeat the whole procedure. It took me about four tries but now miraculously my camera seems to be working, for the first time in about 3-4 years!!!
NOTE: I don't know what the exact "fixing" spot is, so I just hitted different places of the battery spot (both the upper and lower region). Take it easy first and don't hit too hard, see if it works and try again putting more force if necessary. I still can't believe this solved the problem, wish I'd tried it back when the problem first occured!
NOTE #2: I think this fix will probably also work on some other Panasonic cameras with the same dew problem - in fact, I think the guy who originally came up with this solution actually had a different camera model than I do.. I know it's a late reply, but hopefully this helps at least someone!
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic NV-DS29B Mini DV Digital Camcorder Logo
263 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
