Question about Sony DCR-HC38 Mini DV Digital Camcorder
Sony handycam hay i am not getting how to copy my dv in computer thurough usb
  • devrajbansal Sep 04, 2008
    my hanndy does not getting powering off
Dear Sir
i already instal that cd but it still not working
Posted on Sep 19, 2008
  • 43 Answers
Dear devrajbansal,
you wil be provided with software cd (picture package) on purchase of camcorder. just instal the software and connect your system and camcorder. you
Posted on Sep 06, 2008
  • 30 Answers
Physically, there is only one way to connect the Sony Handycam to your computer via the USB port
All you have to do is connect the cable, turn on the camcorder, and switch it to "Memory" or "Playback" mode (depending on the specific camcorder). Windows Vista or xp will automatically detect the camcorder and install the correct driver.
Sony Handycam DCR-HC40 Mini DV Digital Camcorder. How do I copy tape to a PC?
I'm happy to assist you with the information to transfer the videos the computer. Refer the URL to
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C353938&fes=true
NOTE: USB streaming not supported for Windows Vista and Windows 7. Instead use i.LINK cable to transfer he videos.
Dec 23, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
I cant transfer my videos from sony handycam dcrhc36 to my computer os window 7 evenafter downloading pmb from sony sitemy computer is not detecting the handycam
You don't say what type of connection you are trying to use. This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable. Confusingly, Sony call Firewire "i.Link".
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
Dec 11, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
How to transfer minidv video to computer?
Ensure you have been installed picture motion browser ( sony handycam sotfware) on your computer. Connect your handycam to PC using (supplied) usb cable. You will find new hardware pop up. Just click and follow instructions. In you can not find connection, run explore and find your files to transfer and copy. Done You can now re-produce your AV to other media. Regards,
Dec 08, 2010 | Sony Handycam DCR-PC110 Mini DV Digital...
Can not copy MiniDv to Mac 10.6.2
usb is not compatible with mac os. so, use a firewire/i.link cable to transfer the videos to the mac computer
Mar 16, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
I can't copy from sony handycam mini DV to my computer. it is like the usb cable is not registering as an import option, even though i did the hardware installation
Check the connections. The plugs should be fully inserted in the handycam or its stand. If you are using the stand, then the camera should fit properly on it and the USB streaming switch should be at ON position.
If these are OK, then check the USB cable.
Probably you are aware that you have to use a USB 2.0 port in the PC. If your PC is old and has lower USB ports, then the picture will freeze many times and the import will not be of acceptable quality.
Oct 14, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
I am having a sony hi 8 ccd trv 58 model handycam. i want a driver to transfer my videos to my personal computer. any free drivers available?
CCD-TRV58 is analog camcorder and can not be connected with computer directly as camcorder does not have USB or iLink/ DV ports.
Computer needs digital format movie data to store / edit files.
You need to hook camcorder audio-video out to DVD recorder and burn DVD of camcorder movie so you will get digital format of movie. Put that DVD in computer and copy files for further process.
Apr 19, 2009 | Sony Handycam CCD-TRV58 Camcorder
DCR-TRV350 Sony Handycam won't load pictures to Vista
You need to purchase a video editing software program. If you have a usb or dv port on your computer you will need a firewire card on your computer or a spare usb port.
Pinnacle Studio will work with Vista. Once the software is installed and the camera is tuned on, A dialog box will appear asking to run Pinnacle Studio. Go into capture mode to copy the video to your hard drive.
Jan 05, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
SONY DCR 905E handycam
Check your battery is fully charge then reset it to factory setting..
hope this may help;
dont forget to rate;
Aug 17, 2008 | Sony DCR-HC26 Mini DV Digital Camcorder
Import videos from handycam to computer
i am unable to import videos from my mini dv digital handycam to my laptop with vista as operating system.is a i-link cable required or usb cable will do? i have the picture motion software and import from handycam software dowloaded through net. can u help me out???
Jul 20, 2008 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony DCR-HC38 Mini DV Digital Camcorder Logo
172 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
