Question about Bose Lifestyle 38 Series III System
Problem with display in Bose Lifestyle 38 Series III
We have this system and recently we noticed that although the sound is fine when we play music, when we play dvds the video display shows 2 screens and the display is in a black and white mode.
Any suggestions to fix this would be greatly appreciated.
  • lois_weir Oct 03, 2008
    I have the same system but mine wont play audio and the remote has no range.
  • cmar123 May 11, 2010
    Is it ALL dvds? Are they brunt dvd? Check dvd format, bose might not be compatable with dvds. Try turn off and unpluging leave for hour, then try again. try update cd, might work..
5 Suggested Answers
  • 14 Answers
SOURCE: Bose Lifestyle 38
No reset button. Simply unplug the power cord in the rear, wait 20 seconds and power back up.
Posted on Dec 24, 2007
SOURCE: Lifestyle 38 and HD
I have also have this problem with a lifestyle 28 system. Bose sent me a new cable then a software update. The problem remained, after contacting Bose and unplugging cables and powering down the system this solved the problem. However 2 days after and the problem has re-appeared. Back to square one. I should add that this is the second unit I have had the retailer exchanged the last one because of the same problem.
Posted on Apr 09, 2008
  • 4 Answers
I believe there is a USB port on the back of the unit. Has anyone been able to connect to it? Can anything be seen of the files on the hard drive?
Posted on Aug 10, 2008
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
MarineTech1
  • 76 Answers
SOURCE: No sound Bose Lifestyle 38 III
I am quite sure that the indicator lights should be green. The blinking yellow likely indicates that there is no communication between the head and the audiomass. Verify that the connections are tight and then try powering off (unplugging) the system (both head and audiomass) for 30 seconds and then powering on again. That will often re-establish communications.
Posted on Aug 22, 2009
I would like to hook up a usb thumb drive with music to my bose lifestyle 38
You can buy a thumb drive player from MCM Electronics, Radio Shack, Parts Express, etc. Probably around $20.
Nov 10, 2013 | Bose Lifestyle 38 Av38 Series Iii Hdd...
I have a Bose lifestyle 38 and whenever I watch a show with a lot of background sound - ie music in a movie or crowds cheering for sports, it overwhelms the voices of the actors or the sports casters. How...
What makes background sound comes out from Bose lifestyle 38 system is because there is jack cable or a cable that has a jack mouth that brings out a mono sound is being inserted..
Mono cables, when inserted inside a wrong input,it's makes the sound comes out with a background noise just like the one you can hear from it now..it seems as if you are not using the right cable for connection..
To resolve these issue, you will need to use the right cable for connection, by doing these,you will get a clearer sound from you Bose lifestyle 38..
Also it can be from the settings inside the Bose lifestyle 38...So you will need to check both sides to resolve this issue..
You will need to use the manual to know the right cable and the right setting for clear volume..
You can download the user's guide from the below link..
http://www.retrevo.com/support/Bose-Lifestyle-38-Series-III-Home-Theater-Systems-manual/id/524dj979/t/2/
Hope it helped.
Thanks for using fixya..
Aug 15, 2011 | Bose Audio Players & Recorders
Can I connect my pc to a lifestyle 28 system
If you want to connect your PC's audio output to the Bose Lifestyle system, simply get a cable with 3.5mm stereo male plug on one end, and dual RCA male plugs on the other end. The 3.5mm side will plug in to your PC's LINE OUT jack. The two RCA male connectors will plug in to the Bose AUX IN jacks. On the Bose console (or the remote control) select AUX as the audio source. Your PC's sound will play through the Bose Lifestyle system.
For persons having a large library of MP3 music files on their PC, this is a great way to listen to the music on your hard disk.
Nov 28, 2009 | Bose Lifestyle 38 System
Aug 18, 2009 | Bose (321GS) System
No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Jun 25, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Display not working
I think there are some solutions available from www.AnyoneCanFixIt.com for the Bose Lifestyle 20 series with the display issue.
May 26, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 5
Hi it could be R428 open circuit replace with a 330 ohm resistor
Dave
Oct 12, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
Not an Audio CD/Format Unsupported
Clean the CD and try again. Also, if DVD displays "not supported", call Bose and ask to recieve an update disc. These updates are released every 6 months. Document your remote control settings before loading the update as they may be erased by the update and will require re-entering settings after the update.
Dec 24, 2007 | Bose Lifestyle 38 System
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle  38 Series III System Logo
32 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
