Question about HP Compaq Presario SR1300NX (PP195AA) PC Desktop
Monitor not working
When i turn my computer on the monitor has a box that reads; self test, monitor working, check your pc and signal cable. I have been able to wiggle the cable that runs from the monitor to the pc, reset it and then it would work. It is not working any more, box still appears. I thought maybe there was a short in the wire, but not sure.
Jill
  • jmicheau2003 Sep 04, 2008
    I can not return or buy a new cord because it does not remove from the monitor. Someone told me that I need to buy a new monitor. I hate to buy a new monitor and find out it was not the monitor that was the problem. I am wondering if it could be a different problem rather than the monitor?
    Brigadier General:
  • 5,158 Answers
If you have another cable to try that's a good bet. or buy one... you can always return it if that's not it. tho i suspect if you jiggled the cable and it worked thats the most likely suspect.
Robert
Posted on Sep 04, 2008
  • Roberta Smith
    Roberta Smith Sep 04, 2008
    examine all the pins on the plug that goes into the computer. Unfortunately if it is that cord you either buy a new monitor or have someone install a new cord. considering that is labour intensive and the cost of monitors, sadly it may be more cost effective to buy a new one...
    one other thing that occured to me. is that an onboard video or is that an added video card ?
    Robert
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Cheers
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Computer powers up, but monitor shows a self test
Your video output is bad. Either the video card, or the onboard video built into the computer. You need to swap out the card or add a card to bypass the built in video port on your computer.
Thanks and please take a moment to rate as fixya.
Feb 11, 2009 | Gateway 550GR PC Desktop
Screen suddenly went blank except for a self test box
well in order to get rid of the self test window from your monitor... check the cable that connects your monitor to system tower & reset the connection... becase that is the only possible cause of the self test showing up on your monitor...
" as the self test option only appears when there is no video signal going from your video card to the monitor...
Jan 18, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Problem with the monitor
The three boxes represent the built-in diagnostics of the monitor. The letters G is green, B is blue and R is for red, the 3 color guns of the picture tube of your monitor. The words "Self Test" indicates that it is in diagnostic mode since it has powered up, it is also then expecting a video signal from a source to be coming in; the display "Check Your PC And Signal Cable" indicates that it is not receiving any video signal from the source which is your PC or more specifically the PC's video card; and the display "Monitor Working" indicates that the diagnostic has determined that nothing is wrong with itself and therefore it has got to be your PC that is in question. The intermittent appearance of the boxes is when the diagnostics restarts itself and eventually finds the same problem.
To determine if it is the PC or the monitor, use another PC (even a laptop with matching VGA output) and try it with your Compaq monitor, see it it will work or alternately, try a different monitor to connect to your PC. The outcome will determine which is at fault.
If you have determined/verified that it is indeed the PC, you should focus on the video/graphics card. In some PC models/versions, the graphics/video is built-in to the motherboard and you should check the memory since this is shared. The only way is to replace either.
Hope that this be of some help/idea. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Compaq FS7550 17" CRT Monitor
HP Compaq Presario SR1300NX (PP195AA) PC Desktop Logo
70 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
