Question about Cameras
It is saying that the card door is open - Cameras
  • 188 Answers
Even if the card door is closed and it is propmting open then most probably you have broken the micro switch fitted under the card door. After getting it changed you won't get the message
Posted on Sep 04, 2008
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
Dec 12, 2015 | Renault Megane Cars & Trucks
Door handle broke
can you open from the inside, its the only way you going to get to sort this, failing that you may need to get a new door card and rip the one off the door at the top corner near to the lock latch and split the plastic and pull the door pin inside to open then take the door card off. sometimes you can do it with out braking the door card but would not say it will not brake. inside there is a plastic clip that the handle go's on then another bar to the lock. this is designed to snap if some one trys to open the door with force.failing that the handle part can snap where the bar fits to it. that you would need to change the handle.
Dec 06, 2013 | Land Rover Cars & Trucks
It says "sd door open"
SD Door open means that the SD card Slot door is not clsed properly. open the slot remove the card & re insert the card & close the door.
May 08, 2010 | BenQ DC E53 Digital Camera
Card cover open error message
Hi!
You need to make sure that the memory card is correctly installed on the camera and that its door lock is closed.
Sep 05, 2009 | Olympus Stylus Verve / ?-mini Digital...
Sd card
Well, you can try removing the SD card and reinserting the card again. If you don't know where it is located, it is right below the green send key. If you look on the side of the phone there is a door that you can open if you open the keyboard. If that doesn't work, you may need to try the card in another device and try to reformat the SD card. Beware as this will delete everything on the card, but clear up any errors the card may have.
Jun 07, 2009 | HTC G1
Every time i turn on the camera it say card-cover open
clean the seal around the door... else it is repair
olympusamerica.com/repair
Jan 20, 2009 | Olympus FE-310 Digital Camera
When i power on my camers the screen says card-cover open
the switch that controls the door may be going bad.. and would need repair.. but you can try to reset the camera or leave battery out of camera for a couple days
Jul 06, 2008 | Olympus Stylus 720 SW Digital Camera
Olympus FE-140
Yes I had the same problem, however, where is says "push to eject," it means to push the the memory card down and it will eject. You pushed down the latch for the plastic door cover. Try pushing something into the hole so the camera thinks the door is closed. I am still having trouble with mine. Hope this helps alittle.
Sep 16, 2007 | Olympus FE-140 Digital Camera
"Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
May 07, 2006 | Olympus Stylus Verve / ?-mini Digital...
Cameras Logo
101 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
