Question about Jenn-Air JED8430 Electric Cooktop
JED8430BD has 3 wires no ground. Wall has 3 wires including ground
Cooktop has Red, Blk, and White
Wall has Blk, White, and bare ground.
I connected White-White, Blk-Blk, and Red to Ground. The burners and the fan work except that the burners do not heat all the way.
What am I missing?
Thanks
  • mocitysam Sep 04, 2008
    Thx MR. Fantastic. I tried the same combination right after posting the question and it worked.
  • 116 Answers
I think the white on the cooktop should be on ground.
cooktop wall
Red White
Black Black
White Ground
Posted on Sep 04, 2008
I have a new second hand stove top which has 3 wires: black, red, green. From my panel there is a three wire, should I wire it blk blk, red red, and white green
Yes, Red and Black are supposed to be your Load wires (110) each then green for ground which should be white..Before I wire it up use a tester and make sure that is what is going on.
Jan 08, 2012 | Jenn-Air JED8430 Electric Cooktop
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Cooktop wiring
usually black(120v) white (n) and red(120v) bare wire to ground, but if htat what yo got and your sure of incoming voltage, blabk to black , red to red, and white to white is normal..co loang as you 2 power legs are hooked to either power line, the bare goes to the nuetral/ground. thikn i mighta confused myself here, but theres no other way to wire it
Nov 07, 2008 | Cooktops
JED8430BD Wiring
from supply
white, black - should be hot then ground
On cooktop
red, black - should be hot white - neutral then ground
If you have a volt meter measure
supply
between white - black 220v
between white or black - ground 110
cooktop
between red - black 220v
between red or black - ground or neutral 110
If the above is confirmed
connect
red (cooktop) to white(supply)
black (cooktop) to black(supply)
white (cooktop) to ground(supply)
Regards
Sep 06, 2008 | Jenn-Air JED8430 Electric Cooktop
Burners not working but fan is
Are you sure that is the proper wire from the wall? What you are describing is a 110 volt circuit. THis cooktop should be connected with at least #10 wire and fused at 30 amps. You should have black red and at least white with possible bare ground wire. Assuming somebody used the wrong wire during original install job, you have it connected right. Please replace with heavier wire if it is not #10 Or at least make sure it is fused at no more than 20 amps if smaller wire. (You may sometimes blow circuit breaker if all burners are used on high at once) Use a volt meter and check voltage. If this is a 220 volt circuit you should have 220 volts between black and white and 110 volts from either one to bare ground wire.
Jul 02, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
158 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
