Question about Refrigerators
The cooler of fridge doesn't work,but the freezer is still working. I have checked fridge door,plug and everything, but I can't find out reason.
I have the same issue with our refrigerator. I called a service man and he found defrost does not work. There is a heater in freezer that has been broken and lot of ice formed in the compartment. He poured hot water and melted the ice..after 1 hr I started the cooler and it works fine. So I need to replace broken heater tube and he is supposed to charge 200US$ for it. Should I fix or go for new one in dilemna..
Posted on Sep 04, 2008
Freezer is working,but fridge is warm. Fan in back of fridge will not shut off.
If your fridge is not designed with an automatic de-icing function, then there may be an ice dam blocking the cold air from moving from the freezer to the fridge. I had a fridge once that would get blocked with ice even if the rest of the freezer was ice-free.
Unplug your unit (often shutting off the breaker is easier than digging behind the fridge for the plug).
Pull everything out of the freezer and put it in a box. Cover the box completely with blankets to insulate it so your food doesn't thaw and spoil. Prop open the freezer door and let any ice accumulation melt.
Once everything has thawed out, wipe up the water and plug the unit back in. You should be able to tell after 10 minutes or so whether the fridge is getting cooler or not.
Mar 04, 2015 | Refrigerators
Freezer works but fridge doesn't for Doc Henn. I couldn't see your video but more common reason for this would be the small fan usualy behind the inside back panel of the fridge. The freezer is the pa
Check to make sure the light in the fridge shuts off when the door is closed. You'd be surprised how much heat is given off by that light. If it stays on either take it out or replace the switch.
Apr 02, 2013 | Refrigerators
Refrigerator is warm, ice on back of the freezer. What is the problem?
First check to see if the fan is spinning, it could be stuck in the ice. A full manual defrost is required for starters. Move all the food to another cooler. If the covers will come off the freezer easily, check the fan and the defrost coil.
After the defrost, plug it back in and check the fan, and the defrost timer. It should hum. Rotate it to a click, which will be defrost. Check if the defrost coil works. Leave the timer running, it should restart the fridge after a short time. If it doesn't, get a new timer. Keep checking components until you have your fridge fixed. Have fun, fridges are not too difficult to sort out.
Feb 03, 2012 | Maytag Refrigerators
The freezer is working but the fridge part isn't
this is usually do to a blockage in the air duct from the freezer to the fridge. put food in a cooler with ice and unplug and open all doors for 12 hours. If doesn't work, need a repair man due to fan probably broken
Nov 03, 2011 | Amana AFD2535FE Bottom Freezer French Door...
I woke up the other day to find my fridge warm and everything in the freezer defrosted. The light comes on when I open the door and what sounds like a compressor starts up every few minutes but seems to...
What you are hearing is most likely your compressor cycling on the overload due to drawing excessive amperage, You will have to have it checked out by a tech
Jun 26, 2011 | Refrigerators
My Maytag fridge is not working, but my freezer works fine. What do I do? The freezer is on the bottom, with the fridge being on top
Do you have any ice cream in the freezer? If it is soft than the freezer is also too warm. If you do not have icecream then you will need a thermometer to check freezer temps. Freezer needs to be 10 degrees F or colder down to -10. fridge should be 34-38... Sometimes freezer temps can seem cooler than they are with out a thermometer to test it. Also look for frosting up inside the freezer. Check that your door seals are in good condition. check that doors are closing completely.
Please let me know If I can help further.
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Not only will the fridge side not cool properly, now the door won't stay shut. Temp in fridge side stays 20 degrees warmewr than what panel says.what a pos.
Fridge problem- How to check everything
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Door problem-The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Aug 22, 2009 | Refrigerators
Freezer works great, as it should, but fridge is only keeping items room temp. I have the setting at the coldest setting: #7. What is wrong?
Here's what I did, I defrosted! I found out that the fridge temp is monitored and maintained by the freezer. Because we had a power outage one night, my freezer thawed while we all slept and then when power came back on, freezer re-froze but this cause an ice build up on the vent on the back wall of the freezer. Well, ice must have been in one (or more) vents, causing blocked air flow in my top half of the refrigerator. I turned the dial in the freezer to "off" which also shuts down power to the fridge half. I then unplugged the refrigerator, hauled all my food items into coolers, opened the freezer door and refrigerator doors and left them open for a little over six hours. I took advantage of this empty fridge and freezer and wiped everything down. After this time frame passed, I plugged the fridge back in, turned the freezer dial to my preferred freezer temp, and wah-lah! Within two hours I had a cold fridge and solid ice cubes in the freezer. I then put all my food items back into their appropriate compartments, and went to work. Bear in mind, a total 24-hour period is needed for the fridge to re-set itself, but still, after two hours the fridge was noticeably cold. Who knew, besides our parents' generation: DEFROST!
Sep 10, 2008 | Maytag MBB1954G Bottom Freezer...
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
LG fridge suddenly stopped cooling.
If the fan inside the freezer is running and the compressor behind the fridge is running and is hot to touch, you have a gas problem or the compressor is inefficient. This can only be confirmed by connecting refrigeration gauges to the gas system and should only be performed by a fridge tech.
Nov 04, 2007 | Refrigerators
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
