Question about Asko W6021 Front Load Washer
Cleaning the Pin Trap
We've had the Asko for about a year and a half and I cleaned the pin trap in the first six months. Tried to do clean #2 tonite and cannot get into the trap. The manual sez to 'Unscrew the Pin trap cover and lift it out.' I twist the white cover, it comes off and exposes a white circular facing that I cannot budge. I have tried to force it out by pulling at its sides with 2 screw drivers, but don't want to damage anything. Any hints? Thanks
  • 1 more comment
  • roxkib Oct 12, 2008
    I, too, have this problem. Cannot even budge using a chizel that is the size. Don't find anyone who has an answer. If you did find a way to do it, please let me know. Oh, my model is the 6221.
    Roxanne
  • blacksand406 Jan 04, 2009
    Yes, the XXXn pin trap will not come out after the cover is removed. How do you remove it without breaking it into small pieces?
  • Anonymous Mar 16, 2014
    Pin trap cover won't turn
I also had this problem. Here is what I did. When the white cover comes off, it exposes the white circular facing. That's ok, once we get the pin trap out, the cover snaps back on. What has happened is that the pin trap is so full (of money in my case) that it is jammed. The facing has an indentation, but you can't get a grip on it with something like pliers because pliers squeeze, they don't spread. I found a tool at the hardware store called "chain pliers" that when you squeeze them, the jaws spread. There were multiple indentations on them, the first set were pretty thin and I was afraid I'd break the plastic lip on the facing. So I cut the tips of the chain pliers off with a hack saw. Once I got a grip on the facing, I jiggled it in and out until it released.
Posted on Oct 02, 2010
    Sergeant:
  • 351 Answers
You have coins etc stuck in it you will need to force the pin trap out you can buy a new one
Posted on Oct 09, 2008
  • mreinc49 Jun 18, 2011
    My pin trap was jammed in the housing with coins, rubber bands, and other stuff...:o(
    Here is what we didhttp://www.youtube.com/watch?v=b9zIDhKq-... I hope it helps you.
I had the same problem, thank you for you post as I would have wasted heaps of money on repairs! I didnt have the pliars you have though, I just forced it out with screwdrivers, $15 worth of golidies and 6 peices of builders chalk later it is unblocked and away I wash again!!!!!
Posted on Oct 08, 2011
Could you please tell me how to open the pin trap as mine will not come off either. Also how to open the door manually as I have a power blackout and need to get wahing out of machine.
Thankyou,
Leigh
Posted on Nov 19, 2008
The washing machine will not drain. I cleaned out the pin trap where there was a coin and safety pin, but this has not solved the problem. The machine will spin when I turn the program knob to spin, but...
Hello & Welcome to FixYa
If you have already cleaned the drain filter assembly located inside the bottom front panel and the problem is not solved then it is the drain pump that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Asko W6661 Front Load Washer
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
A clothes pin and piece of paper fell down the lint trap when I was cleaning the screen. How do I reach the pin and paper to get them out?
This may take you awhile to do, but once you get to it you may find a lot more than that down there. You have to remove the back on most all dryers. If the lint trap is on top, there is a metal chute that lint and other objects fall down.Remove the back and you will see what I am talking about.Once this is done, it is fairly easy to remove the collars that go down to the lint hose. You will then be able to clean all of the lint build up down below that gets by the trap.
Good luck, Sincerely, shastalaker7
Oct 30, 2009 | Dryers
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Good luck
Jurgo
Jun 15, 2009 | Asko W6461 Front Load Washer
GE model # GSS25KGMC WW
  1. There is a solenoid that operates the trap door. When the lever is pressed to get ice, the solenoid operates and there is a plunger mechanism that pulls a metal pin into the solenoid. When I took mine apart I found the pin rusty which hangs up in the sleave of the solenoid. I tried cleaning the rust off with steelwool but it just rusted a month later and is now hanging up again. I may reclean the rust and spray it with silicon spray. Most likely I will need to replace the solenoid. It is located behind the touch panel. To remove there are 3 small holes just underneath the lip of the touch panel that you must push a small screwdriver or pin of some type through the holes to release the latch for the the front touch panel. Pull the touch panel toward you while pushing on the latch. You will then be able to see the rest of it.
May 24, 2009 | KitchenAid Superba Architect KSCS25INSS...
The machine washes just fine it just want drain. I put it on the drain (11) cycle and it drains, however once it finishes I can't open the door. Someone said it may be the clogged, if so can someone be a...
You can get a PDF owners manual at:
http://www.askousa.com/customer-care/technical_documentation/
Page 23 show the pin trap and how to clean.
Good Luck.
Mar 19, 2009 | Asko W6221 Front Load Washer
W620 Drain Hose Goes Where??
The little black hose in the pin trap compartment gets hooked onto the round pin on the door of the pin trap access, that little hose is a bypass hose from the pump inlet
hope this helped
Apr 18, 2008 | Asko W620
Front drain plug
I have similar issues with my Asko W660. Once it was a key stuck between the inlet to the pin trap and the trap itself. I got it out by jiggling and poking into the trap area with a narrow strip of plastic. Mostly, though, it just requires a stronger grip on the door to the pin trap--the little handle is slippery, and hard to get a good grip on. Try making a grip out of a piece of duct tape, or grabbing the handle with pliers.
Jan 05, 2008 | Asko W6021 Front Load Washer
Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Dec 11, 2007 | Asko W620
Asko W6021 Front Load Washer Logo
589 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
