Question about Q-Logic Q-Customs Car Speaker
Intermittent problem no sound
6x8 kenwood 3 way speaker,2003 mustang gt convt.mach factory sound system; replace factory speakers with this kenwood, they play some and then stop, then start again,then stop it happens more with certains songs and at higher volume,already check terminals for lose wire, after all I just weld everything but still the same. could the wires be conected in the wrong side?
    Novelist:
  • 100 Answers
Double and triple check your connections. I soldered my connections on a speaker a little while ago and I found out that it only looked soldered and it was alittle loose and would cut out. Also you could check a site out, installdr.com. You should be able to find out the wire colors for you speakers there. Although I don't think that, that will cause a big problem. If you are listening to music at loud volumes, I would also recomend an aftermarket amplifier. It adds so much more that a factory amp can. Just food for thought. Good luck.
-Andrew Hawkins
Posted on Sep 04, 2008
2ooo Ford Mustang,Got MP538U TUNER work. cd look like it was playin no sound though.Exchanged it for MP638u.SAME BULL. cAR GOT ripped out mach system. Carstereo wires without harness
If you are wiring a Kenwood KDC-MP638U to a 2000 Ford Mustang, then below information may be of help:
  • to my knowledge, the original stereo unit uses 2 8pin connector and a single 7 pin connector;
  • if the connector with the harness has been cut, then wire splicing may have to be used based below;
  • If you are using external amplifiers, then it is possible to trigger/switch them with the blue/white wire and their RCA INputs connected to the appropriate RCA OUTputs of the Kenwood;
  • Additionally, the KDC-MP638U has built-in USB port/interface.
  • Incidentally, if what was previously installed is a full Mach system, pls be informed that there are seven (7) versions from Mach 1000.0 to Mach 1000.7, which one was installed?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 17, 2008 | Kenwood Car Audio & Video
Will 5" x 7" work
No. The 5x7" speaker is smaller than the stock 6x8" speaker. In order to make this work you will need to create a thin baffle that can be screwed into the mounting holes of the OEM 6x8. A table router and some 1/8" hardboard works great for this. Cut out the new baffle to accomodate the 5x7 and you are good to go.
Dec 21, 2010 | Kenwood Car Audio & Video
I Have a 97 mustang gt with the mach system in and I am trying to install a deh-p3700mp into it. I have power but no sound can you help
could be as simple as hooking up the amp turn on wire, or wrong harness, or bad amps or blown amp fuses
May 19, 2010 | Car Audio & Video
Bought a '90 Mustang GT with these speakers in the
sounds like the wires maybe crossed try this 1st fade your stereo left or right if it sounds better with one speaker playing your polarity is backwards unhook 1 of the speakers and reverse the wires hope this helps
May 11, 2010 | Boston Acoustics CX8 Car Speaker
I'm tryin to change my rear speakers in a 2005
Hi.i cant help you with the rear dash but the speakers are my expertise. They are 6x8 in the front and back without the shaker 500 or 1000 system. If you have the shaker 500 or 1000 it will still be 6x8.
Jan 19, 2010 | Car Audio & Video
MY FACTORY RADIO VOLUME PROBS
More than likely with a 2003, the speakers that cut out are in the door or doors. Do they cut out of both speakers?
If they cut out of one, then you may have an intermittent speaker ( the wire to the cone becomes partially connected)
If both speakers turn off at the same time and you hear NOTHING on all speakers, then you more than likely have an intermittent connection on the radio itself and probably replacement is probably cheaper than fixing the radio.
One more thing
Factory radios sometimes have an amplifier in them. Sounds funny but they call the Radio in the dash the Head Unit and the amplifier is buried in the dash. You could have a bad amplifier or a loose power connection to it, but that is very unlikely.
Hope this helps.
E
E
Mar 02, 2009 | 2003 Chevrolet Silverado 1500
Factory car speakers
Go to Crutchfield.com and go through their application charts. It will tell you what size car stereo and speakers will fit in any car. I have shopped with them many times over the years and been very satisfied with their prices, advice, and service.
Feb 25, 2009 | 2002 Ford Taurus
2003 ford mustang speaker wire color code
Without knowing which system you have (460 or 1000) I can only suggest going to this web site for more info:
http://www.flemworld.com/Mach460/Mach.html
Sep 06, 2008 | 2003 Ford Mustang
Car Audio & Video Logo
113 people viewed this question
Top Q-Logic Car Audio & Video Experts
xxxxxx xxx
Are you a Q-Logic Car Audio and Video Expert? Answer questions, earn points and help others
