Question about Mitsubishi WD-62525 62" Rear Projection HDTV
TV was working earlier, today came home no green power light no nothing
We left to go somewhere, turned the TV off came back and now the TV will not turn on at all. No Green power button no lights at all, checked incoming power its good. The lamp status button had turned from green to yellow about 4 months ago but no blinking so I did not replace it yet. Can anyone help me out Please!!?
Model Number WD 62525
  • 3 more comments
  • timyon Sep 07, 2008
    Well Good news, I replaced the blown fuse, reassembled the TV now its working again. Warning to non electronic technicians this is quite a job be careful and thoughrough, or you could be in for along nite. Anyways ordered a bulb off Ebay $86 and 2 day shipping to hawaii = $115 Hopefully it will pay off and I can milk another year out of this TV that until recently I was fairly satisified with. The lamp status is still yellow will update this post if replacing the lamp turns the green status light to green again, still wondering why the fuse blew in the first place, I read somewhere that the TV ballast trying to light an old worn out bulb could have been the reason it blew not sure..
  • johnphillipl Nov 13, 2008
    my tv timer keeps blinking. the tv will turn on after a while but just checkered screen. code 12 is what i have been getting. could it be a fuse or a bad power supply. can someone tell me how to check or replace.
    thanks
  • fayeboe Nov 22, 2008
    Where is the fuse located in the mitsubishi wd-62525?
  • ARSTAR Nov 29, 2008
    TV TURNED SELF OFF NOW IT WONT GO BACK ON. NO GREEN LIGHT NOTHING
  • Elitebodyink Nuttall
    Elitebodyink Nuttall Nov 30, 2013
    wd 62525 no power at all no light no fan no nothing were do i start.
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Posted on Nov 17, 2008
  • 3 Answers
A steady yellow LED can mean 1. Excess Temperature 2. Usage time is over 4000 hrs on lamp
Blinking Yellow: 1. Filter cover open 2. Lamp Cover open
Posted on Sep 29, 2008
  • mark Jul 20, 2012
    where is the filter cover or the lamp cover
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
Pioneer PDP435PG inadvertently reprogrammed by Casablanca remote.
Some ceiling fans have jumpers that can be moved to select a different frequency but you have to be sure both the remote and the fan receiver are set the same. Other than that, you may have to use some creative control. For example, I can turn on my TV by pointing the remote at the wall opposite the TV
Mar 29, 2017 | Pioneer PDP-4350HD 43 in. Plasma...
Lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Sep 27, 2008 | LG 32LX1D 32 in. LCD Television
LG 32lcd2d
Sounds like your cable is off or your not on chan 3 . Can you go to setup and find cable , air ect ? And see if that does anything ? Check all your coaz and hdmi and make sure they are tight as well
Jun 25, 2017 | LG 32LX1D 32 in. LCD Television
No Power will not turn on WD 62525
Are there any lights indicating the Tv has power? Any relay click when you depress power button?? Try unplugging the unit for about one minute, then plug it back into power and attempt to power it up. Let me know.
Bill
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
PC is dead
I assume you installed the new graphics card already. Did you check if your power supply could handle the increased power? If your power supply is rated at 350W or less, I'd upgrade to at least 400W.
Also, ensure that the graphics card, if it has a power connector, is connected properly to the power supply, and that in the process of installing it, you didn't accidentally remove any of the power connections to your motherboard.
The Green LED lets you know that it is receiving power from the wall, and that the problem lies in the computer somewhere.
Dec 30, 2007 | Computers & Internet
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
563 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
