Question about Minolta Office Equipment & Supplies
Error Codes on Printer and Scanner When Scanning Result to an Email address the following result codes were received EA41A5 was received when sending to one address and Error code EA5006 was received sending to an alternative Email Address
  • Norman  J Weimar Jr
    Norman J Weimar Jr Nov 22, 2015
    Hi marc558, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    try one more did it have a code also are these two address on same network? try different
4 Suggested Answers
SOURCE: BIZhub C250
try the web based configuration
Posted on May 17, 2007
SOURCE: Bizhub 250 scan to email error
Change your account information from external to internal, i.e. yourmaildomain.com to yourADdomain.local. Change on the scan account as well as the email addresses.
Posted on Dec 22, 2008
SOURCE: Scanning to email on MFC-9840CDW Laser Printer
This is a little dated, and I hope you have found your solution already, but for everyone else:
Press the # button Use the directional pad to scroll over to the @ symbol. When It is underlines press OK
To insert a ., press the * symbol, scroll over until . is underlined and do the same as above.
Posted on Jun 28, 2010
Error code c4-oo
This is normally an authentication error when scanning to email.
Take a look at this walkthrough, it will show you how to utilize Gmail's SMTP servers using any gmail mail account. Setup Scanning to Email on Sharp Printer using GMail SMTP Servers
Feb 17, 2014 | Sharp Mx-2610n Color Copier, Printer,...
Code:7,202,15- My Canon MX-870 (Twain) gives me this error code when I try to resizew in B/W or grey scale. No problem in color.
"Internal error occurred. Scanner driver will be closed. code 7,202,15"
Received the above error while inserting scanner image using MS Word with Canon printer/scanner Pixma 439.
The solution is via the following MS Word software choices:
From Word tool bar choose: INSERT/PICTURE/FROM SCANNER/then one of two choices, either: WIA-WIA Canon MX430 Series, or choose CUSTOM INSERT (Preferable).
R
Aug 21, 2012 | Canon PIXMA MX870 Wireless Office...
Scanning document to email. 20 pgs. Get "Error Type: Transfer" result report. What does it mean? Running Firmware version 2GR_2000.022.001 2008.08.06
Error Type: Transfer means your scanner/printer is having an issue transferring the documents to the place you want it to go. This usually means the device can't find a network or you've typed in your email incorrectly.
Did you type your email in correctly? Are your networks settings correct and working?
Are you able to send just one page to test it out?
May 12, 2011 | Computers & Internet
My scanner screen says that the scanner bulb is warming up,but nothing happens. Also my cancel light continually flashes. What could be the cause of this?
Scanner Bulb Error Message
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpl12028&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=66366
ISSUE:
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner's inability to find the home reference point.
SOLUTION:
Perform the following steps to walk the scan assembly from the home base and resolve the issue.
1.
Remove and replace the power cord from the unit.
2.
Wait approximately 35 seconds for the scanning assembly to "walk out" and then quickly remove the plug again.
3.
Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4.
Replace the plug and let the product fully finish the boot cycle.
If this does not resolve the issue or the issue returns, upgrading the product firmware may help. The firmware upgrade can be found at the HP Web site Downloads, Drivers, and Notifications page .
Hope I help you a bit.
You can also send me questions on my
personal email - christian4122@yahoo
Your's Truly,
Christian from HP
Mar 27, 2011 | HP LaserJet 3330 All-In-One Printer
My dr-x10c scanner gives an P007 error code i have tried cleaning the rollers but the error stills keeps coming back. do you think that it's time ireplace mty exchange roller kit???
Solution: I had the same error P007 on a Canon Scanner. Switched off the scanner, Opened the scanner. Located all of the sensors. Sprayed Platenclene spray and used a soft cloth and cotton buds to clean the sensors. Switched back on the scanner and the error was gone and its scanning perfectly. The error P007 is a result of dirty sensors!
Nov 19, 2010 | Canon Office Equipment & Supplies
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Thank you for contacting Fixya.
This error is detected when one of the followings occurs: (TWAIN Error-Paper jammed in the ADF - Code DS32002), Scanner panel error-U1
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner performs retry operation.) 2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Check the followings: 1.Scan condition - Transported length (L) before jam 2.ADF fixed size - scanning Approximately 450 mm 3.Long paper scanning -1.2 times of the specified value
If the imprinter is installed, paper jam can occur in the following case. If the scanner starts scanning when the imprinter cable (EXT cable) is not connected to the scanner, it does not rotate the imprinter, since it recognizes the imprinter not installed, which results in paper jam in the imprinter section.
Solution:
Remove the jammed document and close the ADF. When the error frequently occurs, refer to the followings:
1. Do the documents satisfy paper specification? Please read the operator guide for paper specification. 2. Have the documents been jogged? • Align the edge of documents for stable paper feeding. • Remove documents with crease or dog-ear. • Scanning different width of documents may cause skew and result in paper jam. 3. Is the Imprinter EXT cable correctly connected to the scanner? Check the cables. (only when the Imprinter is installed) 4. Clean rollers in ADF and Imprinter and see if the error is removed. (only when the Imprinter is installed) 5. Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values shown, replace Pick roller or Pad ASY.
If the above do not help, then the issue could be caused by the followings:
6. Malfunction of TOP sensor. 7. Malfunction of Cover open sensor. 8. Faulty Scanner Control PCA.
If Imprinter is installed, then the issue could be caused by the followings:
1. Malfunction of Sensor OPB5 lever (only when the Imprinter is installed). 2. Malfunction of Motor LF if the imprinter roller does not rotate.(only when the Imprinter is installed). 3. Faulty Imprinter Control PCA. (only when the Imprinter is installed).
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
Email result EA3227
IP Scanner operations
Error Code Cause Remedy
EAXXXX ImageReceiver was not started.
Start ImageReceiver.
The IP address of the recipient
is not specified correctly in the
dialog box that appears after
clicking “Receive Settings”,
then “Connection Filter”.
Click “Receive Settings”, then “Connection
Filter”, specify the correct IP
address, and then restart ImageReceiver.
ImageReceiver is not operating
correctly.
Restart the computer.
Re-install IP Scanner.
Check the TCP/IP settings on the computer.
The LAN cable is not connected.
Check that the LAN cable is correctly
connected.
The network settings on the
computer are not specified
correctly.
The network load on the recipient’s
computer is too high.
Check that large e-mail messages are
not being received at the recipient’s
computer and that large files are not
being downloaded from the Web.
Too much data is being sent. If a high scanning resolution has been
specified, reduce the resolution or decrease
the number of pages scanned
at one time, and then scan the document
again.
Access is blocked by the setting
specified for the computer’s
firewall (Windows
firewall) for the Internet connection.
Change the setting specified for the
computer’s firewall (Windows firewall)
for the Internet connection according
to the instructions from your network
administrator.
Oct 07, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fax and cancel lights are flashing
I found this solution at HP website. It worked for me. Good luck!
A Scanner Bulb Error message is received as a result of the HP LaserJet 3300mfp series product scanner’s inability to find the home reference point.
SOLUTION:
1. Remove and replace the power cord from the unit.
2. Wait approximately 35 seconds for the scanning assembly to “walk out" and then quickly remove the plug again.
3. Repeat steps 1 and 2, three to four times until the head moves approximately 1 inch away from its normal resting place.
4. Replace the plug and let the product fully finish the boot cycle.
Oct 08, 2008 | HP LaserJet 3330 All-In-One Printer
Scanner
What make and model?????? Any error codes???? Need more information. What you have here is like calling an auto mechanicc on the phone and saying "My car won't start, what's wrong?"
Oct 11, 2007 | Office Equipment & Supplies
107 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
