Question about Fuji FinePix A303 Digital Camera
Very slow After I take a picture it takes a very long time until I can take another one. The viewfinder lamp swithces slowly from green to orange and the camera is not responding to anything until the lamp stays green. It takes even longer if i used the flash. Anyway I can fix it? I opened the camera and I noticed there is a battery (like a watch battery). Can that be replaced? Anybody knows anything about this battery? Thank you in advance for any feedback.
  • 52 Answers
Hi, you have a few options. In fuji finepix model cameras they have a setting for continuous mode that may help shoot faster.  when you press the menu button it should be under resolution.
2nd try a higher speed memory card. Some SD and Xd manufacturers make higher speed cards that can write and dump info faster than normal.
3rd - make sure batteries are fresh if they are rechargeable, and may need replacing if they are fully charged.  Or if they use AA style try the higher capacity styles available for a premium from energizer and duracell.
if none of these work, the digital converter (CCD) 3.4 in your case, inside your camera is much like a processor in a computer. The higher the model the faster the speed. The first digital camera I bought, cost $200 and took 5 seconds to even turn on, let alone between pictures.  Try a new one at a store to compare, or the finepix Z series is a great camera at an affordable price if you want to upgrade!
Don't forget to rate me, or reply if you need more help! Thanks, NGK
Posted on Sep 04, 2008
Panasonic TV slow to turn on, works fine after it turns on.
If you have to try to turn it on several times it is power supply related.
If dirty inside on fans etc it would cause set to shut down(the set monitors the fans for speed)>
I would suggest (take it outside) using a air compressor and cleaning the entire set out.
Lamps do fail---average life is 2000 hours for a original lamp and much less for a generic one.
If picture comes up try to watch the light from the lamp---if dim at first and then slowly comes up---it could be the lamp or the ballast the set uses to power the lamp.
Jun 10, 2012 | Panasonic Televison & Video
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Don't know what buttons on back of camera are for.
Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
c3015.gif Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
c3014.gif When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
  1. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
  3. Frame your subject within the VIEWFINDER EYEPIECE.
  4. Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
c3013.gif When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
  4. Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
c3016.gif Use this feature to include yourself in pictures.
  1. Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
  2. Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
  3. Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
  4. Frame your subject within the VIEWFINDER EYEPIECE.
  5. Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
    • To cancel the self-timer selection before the shutter releases, close the flash.
    • The self-timer automatically turns off after the shutter releases.
Night-view with flash
c3012.gif In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
  3. Frame your picture in the VIEWFINDER EYEPIECE.
  4. Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger. Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
  5. After 12 seconds, release the shutter button to take the picture.
Night-view without flas
c3011.gif In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
  2. Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Jun 17, 2010 | Kodak Advantix C400AF APS Point and Shoot...
Watching tv when the picture went black and now the green on light flashes for 30 times and turns off
A green flashing light for this model of TV indicates that the lamp cover is open on the TV.
  1. Unplug the power cable to the TV.
  2. Remove the 2 retaining screws on the lamp cover with a Phillips type screwdriver.
  3. Remove the lamp door completely from the TV.
  4. Remove the two retaining screws on the lamp case.
  5. Lift up the fixed wire handle of the lamp.
  6. Pull out the handle slowly and remove the lamp case.
  7. Insert the new lamp gently into the correct position. Make sure it is inserted correctly.
  8. Using a manual Phillips screwdriver (Do Not use an electric screwdiver), tighten the screws you removed in
    step 3.
  9. Replace the lamp cover and tighten the cover screws.
  10. Plug in the power cord and turn on the TV. After the initial warmup period (which may take up to several
    seconds for full picture brightness), the TV should operate normally.
If any of the following conditions exist, turn off the TV, unplug the power cord, and repeat steps 1–9 to ensure that the lamp unit and lamp unit
door are installed correctly:
  • The lamp indicator flashes green.
  • No picture
  • Dark picture
  • TV will not turn on
If, after repeating steps 1–10, the problem still exists, call Customer Service at 1-800-631-3811.
Source
Aug 31, 2009 | Toshiba 44NHM84 44" TV
TROUBLESHOOTING c-750
There are a couple issues related to "slow" that I have with my C-750, and this is how I get around them.
One is the write speed to the xD card. This can prevent you from taking sequential pictures quickly, as the camera displays the current picture it is writing until it finishes. You can make the image of the current picture go away and use your viewfinder again, while the camera is writing the picture, by pressing the shutter button halfway and releasing it. Then you can see your subject in the viewfinder again!
Second is the delay between the time the shutter button is pressed and the time the shutter actually opens (when the camera actually takes the picture). This can be fixed by lining up your shot and pressing the shutter button halfway and holding it for a few seconds. This will give the camera time to adjust and lock focus, shutter speed, etc. There is a small green dot on the display below the battery indicator which will blink a few times when the button is pressed halfway, then remain on steady. When the green dot is steady, the camera is ready. Press the shutter button, and the camera should immediately take the picture.
Nov 12, 2007 | Olympus Camedia C-750 Ultra Zoom Digital...
Olympus Camedia C-450 orange and green lamps on viewfinder
well u can´t do a thing.... because when that happen it´s the mainboard that needs to be replaced, just sent it to a repair centre, if it´s under warranty they will fix it for free, cause it´s normal to happen with that kind of cameras.
Feb 26, 2007 | Olympus Camedia C-450 Zoom Digital Camera
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Fuji FinePix A303 Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
