Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Acer AL1719 19" LCD Monitor Problem
Could some one help me with the above monitor as power supply is blown. Model number of the board is AR577 VP-583. The problem is Mos fet is blown as well as on the printed circuit board R811,812,813,814 are roasted hence can't find the value to replace it. If any one has the monitor opend or got circuit diagram please post it for me .
Thanks and regards
2 Suggested Answers
I have the service guide for this monitor and the values for the R811 to R814 are the same: 1.8 . The mosfet is a 2SK2645. I will like to send the pdf file, but I new in this site and I don´t know how to attach a file due the only options that I see is a link, image or you tube clip.
Good luck
Posted on Mar 19, 2009
Ic number of acer lcd monitor v193hqv?
Hi guys the pwm ic number in acer v193hqv is TEA 1530 AP.......
Aug 05, 2014 | Acer Computers & Internet
Acer AL1711 17" LCD Monitor showing white screen
A white screen indicates the power supply board is not putting out the correct voltages to properly power the monitor, just the back light. This type of issue is caused by a failure of the filter capacitors on the power board. You can rebuild your power supply board and bring the monitor back to life by just replacing the the bad capacitors. The problem is that model the Acer AL1711 could come with 1 of 4 different power supply boards install depending and the date manufacturer and supply on hand. If you want to repair the monitor if you could open the unit and get either the model number of the power supply board or send a picture of the board to me I will be glad to help you repair the unit and get it back up and running. You can contact me to send the information at
Nov 30, 2012 | Acer AL1711 17" LCD Monitor
Hi, i have an acer lCD monitor model x223w, the screen light flickers for a few seconds then the moniter shuts down. what can i do to fix it?
if no any power led indicator at the front panel after of shut down, the cause could be power supply failure. you will need to remove the back cover to gain access of the internal part of the monitor. look for a blown fuse or burnt parts at the power supply board. if you have an idea about electronic parts just replaced defective parts with the same rating and value. hope this can help good luck just let me know if you need further assistance.
Nov 08, 2012 | Acer 22" X223w LCD Monitor
V193W 19" acer monitor is connected to computer
Hi, Try turning off your system, activate your monitor and then activate your computer. Check the troubleshooting section of the manual received with the monitor and if that still does not help, let me know.
Regards, Icom1
Apr 01, 2011 | Acer V193w LCD Monitor
I have a Acer V193W Computer Monitor. When I turn it on I get a white screen then it goes black for like two seconds then comes back on with a white screen and stays on that way. What could the problem be?
The LCD panel is not getting the 5/12vdc from the logic board or the fuse on T-CON board is blown or bad T-CON board, it can also be due to bad 5VDC power supply caps in the power supply and in the logic board.
Please read my guide and look at the pictures at my photobucket.
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, Caps :
Capacitor kits: he can make you a set of caps for you.
Please post back what you find.
Nov 03, 2010 | Acer V193w LCD Monitor
Need to know what to replace on the AR577 VP-583 REV:1B power board for acer 22inch lcd
It doesn't costs much to try to change all the electrolytic capacitors on it, often it solve the problem.
Jan 27, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
LCD Monitor Acer AL1717 shtting down problem
Aside from the capacitor and IC, there's a relay that you need to change. You need to locate that defective relay on the PCB and replace it.
It would be best to consult the manufacturer of the LCD and get the exact part number of it.
Have a great day!
Apr 26, 2009 | Acer AL2216WBD LCD Monitor
Menu keeps poping up & won't turn off
have you found a solution to this problem? i have the very same problem. i have taken apart the back of the monitor and found that if i take the small circuit board that is plugged into the power switch it goes away leading me to beleive that it is this small board but i do not know where to get it at. the number on the board is ar577 vk-583 rev:1. any help would be greatly appreciated. my email address is
Oct 22, 2008 | Acer AL1914 19" LCD Monitor
Good luck
Sep 04, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
I have an Acer 1715 that also turns on, then goes dark after a few seconds. The capacitors on the AR577 supply/inverter board were good, but I replaced them anyway. There is a good write-up with photos at:
This shows the board nicely and capacitors for the 1712 Acer, which is very close to the 1715.
This didn't cure my problem, and after chasing signals, I believe the problem is a bad inverter chip. The SG6841SZ on the back side of the board is a 20 pin gull wing surface mount package that drives the FETs to switch voltage off and on to the high voltage transformer. I know the diodes and FETs work because it comes on. The transformer drive stops when the backlights go out, though the voltages are all there. The 5V drive signal from the control board is there, so the problem has to be the inverter, or all 4 FETs.
If I can get hold of the part and it fixes it, I'll post it here.
Jun 16, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
667 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
