Question about Atari 2600 Console
Possible Control Port Issue for 2600
So I hook up my 4 switch Woody 2600 and am playing Pac Man...I can turn left, right, and down but not up...I tried 4 different joysticks...all the same...I tried a different game...still no up...then I got my 2600 Junior and low and behold I can move all directions...I'm thinking there's some kind of messed up situation with my control port...is this a common problem? Can it ever be fixed? Thanks for the help!
John
  • the gameboy Oct 29, 2008
    i get the same thing....
    i can go left, right, up, down, but in avery game i try, the RED button works...
    until i tryed to play a copy of berzerk, the button didn't even show response...
    now it only does something when i hold the button for like 3 seconds... not good for a strategic game...
I have an atari 2600 jr that has a similar problem- the button doesn't work. i found out that one of the pins in the controller port was broken off so this is a possibility
Posted on Jun 20, 2013
  • 52 Answers
Superdrafan:
you sound like you have a conection problem within you atari
open the Atari up and look to see if there are any dry solder joints from the joystick ports
just dabbing the point with a solder iron shold freshen up the connection
The Gameboy: you sound like you have dirt in your joystick
open it up and clean the connections with a cloth and spirts
Posted on Oct 29, 2008
Why does my Atari woody 2600 only play in black and white and is flickering
There is a switch by the car slot that will switch it back to color.
Aug 11, 2013 | Atari 2600 Console
How do you get a pacman screen
Instructions
Turn on your iPhone and press the App Store button.
Select the Search option on the bottom of the screen, and type in "Pac-man"
You will see both PAC-MAN and PAC-MAN Lite come up. Select the application you would like to download. This will bring you to the description page with an INSTALL button in the upper right corner.
Press the INSTALL button. You will be prompted for your iTunes Password. Enter your password and the download will begin.
Once the download is complete, you will see a PAC-MAN icon on your iPhone main screen. Select the PAC-MAN icon, and follow the instructions to begin playing the game.
Jul 21, 2012 | Apple iMac Z0GF0005F Desktop
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
How do I reformat the smartmedia card for the 2600 zoom?
First Move the mode switch to the Play position then follow these steps
1 - Press the "MENU/OK" button to display the
menu.
2 - Use the left or right arrow buttons to select "ERASE" and then
use the up or down buttons to scroll to "FORMAT"
3 - Press the "MENU/OK" button
4 - You will see a confirmation message confirming that you want to format the card, Press the "Menu/OK" button to confirm.
Note - This will erase ALL of the picutures stored on the card whether you've protected them or not.
Mar 05, 2011 | Fuji FinePix 2600 Zoom Digital Camera
Blower will not achieve maximum rpms and bogs down when accelerated
most new homelites etc have the high speed screw too lean because of epa standards---you usually need a special tool either a splined or pac man screwdriver to open the adjustment screw another 1/4 to 1/2 turn to get the right rpm's
Nov 07, 2009 | Homelite Consumer Products Backpack...
Madden NFL 07 instruction booklet
There are two optaions for you to find one, one of the simpler ones would be to find a video game store and ask if they have the booklet in stock and they should be able to give you one, or you can try e-bay, im sure there is something on there. I hope I have helped you in anyway.
Wayne
Jun 26, 2009 | EA - Electronic Arts Madden NFL 07 for...
Pac-Man Adventure in Time CD will install on my windows XP, but when you start game it goes blank and you have to reboot.
Is this an old game? Might need to have a special software that runs game in a different mode to operate properly. Right click the icon that executes the game and see if there is a "run as" listed and then you can adjust how the program is handled.
Sounds to me by your description that the video setting is too high for the game to operate. You could also try lowering the resolution of the video settings and see if that helps. Right click anywhere on the desktop click properties and then advanced you will see resolution setting and move slider to the left to turn it down.
Hope this helps
TankMurdock
Apr 24, 2009 | Infogrames Pac-Man: Adventures in Time for...
Uploading a video clip to my computer
The issue may be that your camera captures via FIREWIRE for video and USB for stills. It's a common issue. You'll need hook up your camera to a firewire port. If you don't have one due to this PCs age, you can always pick one up for about $20 and with XP pro, installation is practically plug and play.
But I'll tell you this. If you're computer is that old, do yourself a favor and double the memory. Video is a bandwidth hog and if you don't have enough RAM, you'll run into all sorts of dropped frames and synch issues.
It's also probably time to start looking to upgrade that Dell.
JD
Digital Camcorder HQ
Nov 30, 2007 | JVC Cybercam GR-D90 Mini DV Digital...
Atari 2600 Console Logo
154 people viewed this question
Top Atari Video Game Consoles & Games Experts
Hanzu
Iron
Iron
Reggie brown
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
