Compresser will not quit running - Heating & Cooling
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Turn your thermostat off, if still running ,then the contactor is stuck in close or run position, the thermostat controls the open & close of the contactor coil.. Replace the 24volt contactor on the outside unit and your problem is solved!
Posted on Sep 04, 2008
My briggs and Stratton Intel 206, 5.5 hsp, was running fine, began to lower rpm until finally quit, oil and gas ok, cleaned jets, no change? Could it be a governor or linkage issue.
I would check Spark & Compression with Compression tester! This goes into the same place where the spark is& Compression should be above 70 if not the engine is no good. Let me know.
May 15, 2016 | Garden
Will not stay running
Very small 2 strokes need lots of compression,so keep the oil mix high,even as low as 22 to 1,should be 25 to 1,but take care mixing.scrape out all the oil and mix thoroughly.Each pull of the rope should be quite hard,and you should really feel each compression.if motor keeps on turning by itself after you've stopped pulling,it means compression poor,replace barrel,piston
Jul 24, 2014 | Poulan Pro 1129478 Weed Eater 952711557 0...
Hi. I have recently bought a GT380, however, it's not running right. It starts fine and runs, but only on 2 cylinders. Carbs have all been ultrasonically cleaned, take the plug out and lay it on the head...
just coz you put youre thumb over the hole and you have compression does not mean that you have good compression find out what the maximum pressure is supposed to be and get a porper compression tool.
oil from the exhaust is odd i think this could be v/v guides but it would not explain why exhaust is not getting hot.
Sep 26, 2013 | 1975 Suzuki GT 380
I have a briggs & strat 17 hp ohv intec model 311707 on my craftsman lawn m. it was running then with a large puff of smoke it quit. now the starter runs it with no compresion, removed the s p (oi
does the engine when it is turning over sound normal? does the engine have any compression at all or is it just not as much? sounds like a burnt valve
Sep 07, 2012 | Measuring Tools & Sensors
Quit running
In short your engine will require 3 things to fire, spark/timing of, fuel, and compression. Check the easiest 1st, pull a plug wire and check for spark, if there is spark crank the engine over a few times more then remove a spark plug, if there is fuel on plugs you have gas flow and injector pulse, now check compression if there is good compression you should have good timing. Please check the above and let me know waht you do / do not have, from there we can narrow it down and get you an answer. Could very well be a crank sensor or such, until you narrow it down, the possibilities are endless.
Please let me know and I'll try to help,
Tom
Apr 16, 2010 | 2000 Mitsubishi Galant
Craftsman weed eater wont run
MAKE SURE YOU REPLACE THE CARB GASKETS. ALSO MAKE SURE YOU ARE USING FRESH FUEL WITH THE RIGHT MIXTURE. COMPRESSION SHOULD BE AT LEAST 90LBS
Sep 24, 2009 | Garden
Yz450f that quit running
Yes, it does have an automatic decompression mechanism. It is a centrifugally operated mechanism and it is EXTREMELY unlikely that is causing your problems.
The two highest probabilities are:
1. Fouled spark plug. Forget what it looks like, put a BRAND NEW plug in. It is the cheapest form of diagnosis you can do. These bikes are terrible about fouling spark plugs and a fouled plug produces the exact symptoms you described.
2. Inspect your valve clearance. Tight valves will also make the bike hard/impossible to start with the kick starter. In some cases, it can be push started, but still won't kick. With tight valves, the bike, although hard starting, will run pretty good, for awhile. Eventually it will burn the valves and quit running though.
If your bike isn't kick starting fairly easily, something is wrong and needs to be addressed. The only other issue is making sure the idle speed is set per the service manual. These bikes have a fairly high idle, some as high as 1700 rpms. If it is set too low, it makes them hard to start too.
Sep 11, 2009 | 2004 Yamaha YZ 450 F
My 2004 Hyundai Sonata quit on the freeway 65mph timing belt had
You have to have your timing set around Top Dead Center .. use a timing light.. 9 deg before TDC
Jul 07, 2009 | Hyundai Motor 2004 Sonata
Engine will not stay running
Hi
When the engine stops check the spark at the spark plug.Check compression(remove the spark plug and ground the plug wire on the engine,seal the plug hole with your thumb.Operate the starter.If the compression preasure blows your thumb off the hole,the compression is adequate for the engine to run.Now priming the engine(put some gas into the spark plug hole,back the spark plug and try to start the engine.Let me know. savumihai71 regards
Dec 10, 2008 | Toro Garden
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
