Air conditioner works good but compresser will not shut off thermostat has been changed
  • 3 Answers
Hi there
well in this situation thermostat capillary is not attach to cooling coil b.coz of that your compressor is not cutting off so attach the thermostat capillary correctly to cooiling coil unit thank you
Posted on Sep 04, 2008
When the thermostat calls for unit to shut down fan stops compressor stays on and will not shut downn untill breaker is turned off
It sounds like the contactor is stuck in it's closed posation Try tapping it with the plastic end of a screwdriver. If it then starts to work then you will probably have to change the contactor.
Good luck,
Marty
Jul 13, 2014 | Dometic Rooftop RV Air Conditioner
Dometic rooftop a/c compressor will not shut off. The only way to stop the compressor is to shut it off at the breaker. The fan and all other funtions operate properly from the thermostat. I tried...
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Oct 03, 2011 | Dometic 57915531 Air Conditioner
Duo Therm Thermostat
Hi there
I think this is a setting on your air conditioner, the air conditioner will turn off when the room is at the correct temperature and when the room starts to warm up, the air conditioner will turn back on. (You need to find the settings and change them from auto-adjust to manual-adjust)
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Dometic Rooftop RV Air Conditioner
Will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Jun 03, 2008 | Dometic Rooftop RV Air Conditioner
Coleman rv roof air conditioner
(1)Check compressor contactor or relay if it stock in the close position
(2)Check for welded contact points
(3)Check switch control for defect
(4) Check if compressor contactor still geting power when it is off
Let me know what works for you.
Mar 30, 2008 | Heating & Cooling
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
