Question about Harman Kardon AVR 100
AVR 110 The system turns on and off but no sound at all .... I did notice that it states SURR OFF, but can't find a way to turn on.... Also it says ANALOG ... but we don't even have sound from the radio either.... We have checked all connections and have had it setup for quite some time the same way... Could it be the machine itself or is there something we are not doing. Turn the unit on, L.E.D.'s light up as they should, turn on the radio, turn up the volume, made sure everything was connected, even played a multi-disc CD player through the unit.  "NO SOUND" at all. Please reply with remedy.
    Brigadier General:
  • 6,966 Answers
This could be indicative of the built-in protection circuitry kicking in to prevent further damage to the unit. It has sensed a fault and therefore shuts the unit off.
Further diagnosis/repairs of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 04, 2008
  • Louie  Role
    Louie Role Sep 04, 2008
    Hi again,
    If the unit turns on, the light indicators/display are as supposed to be but no sound, pls check:
    • tape monitor is OFF;
    • speaker selector pressed;
    • mute is off.
    It could possibly also be a hardware fault, are considering a DIY?
  • Louie  Role
    Have you tried a reset? unplug from the mains for an hour at least.
How to hard reset a Harman\Kardon AVR 55
That sounds like a classic case of processor overheating. Open it up and check for a cooling fan.
I found this in Fixya!
All it needs its a hard Reset press the power button once its on standby mode press surr button for 5 sec and it should reset.
This is different
service manual
http://www.hifi-manuals.com/Harman-Kardon/AVR-55/downloads
Jul 17, 2017 | Audio Players & Recorders
States zone 1 off on startup. cannot get any sound.
In the manual that I just uploaded on page 61 there is a big WARNING. You might have accidently adjusted the audio form zone 1 (main system audio) to turn off. use the manual I uploaded to walk you through the re-setup of zone 1. It's in 'main menu - system setup - advanced - Zone 1 Setup A'.
Nov 01, 2009 | B&K AVR-307 Receiver
Can n ot get rear surrround speakers to work
On this reciever you have rear surround and rear back spkrs, if your using the surr back they have to be assigned if unassigned in the settings. If using rear surr spkrs change your surr field to 5ch stereo and your rear speakers will work.
There is no 7.5 unless you have 5 subs the 7 is the total number of speakers and the .1 is the number of subs in the system
Feb 02, 2009 | Denon AVR-1708 Receiver
Keeping the settings permanent
Hello, are you making the changes in the speaker settings section in programming? Thank you, CB
May 24, 2017 | Onkyo HT-S670 System
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
AVR 110
sir if ur not a technician plz do not try to repair ,this solution is to b for someone that knows this field ie electronics
its not a wiring problem but a reset of the micoprocessor
Jun 06, 2008 | Harman Kardon AVR 100
Home theatre
I had this same problem. All I did was switch the sound type by repeatedly pressing the "SURR." button on the bottom left corner of the remote. Usually after 10 times the sound is back,
Jan 26, 2008 | Philips HTS3440/37 System
Harman Kardon AVR 100 Logo
146 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
