Question about Toshiba Televison & Video
The TV comes on and after a while, the video/picture goes black while the audio continues. I hold down the off button for 5 sec (to reset) and sometimes it comes back on, sometimes it takes many tries. Once on again the video/picture continues from anywhere 5 min to 30 min or more and it goes out again. I've tried to punch recall as well...sometimes the picture returns sometimes not.
  • 5 more comments
  • IreneMatt Sep 04, 2008
    This is an Integrated High Definition LCD TV not a projection TV
    It's only one year old
    Toshiba Regza 32HL67 is the make and model
    no semblance of video with flashlight and/or volume held
    The TV is fairly close to a wall and there is a shelf above it, so I moved it forward perhaps to allow more air to circulate. The top of the back unit was pretty hot before I turned it off. This a.m. it was cool again. Do you think moving the TV forward might help?
    We're also thinking of raising the shelf above the TV 3 inches for more air flow. Just wasted effort?
    Good feedback, problem not yet solved, but we have alternatives. Thanks Benimur
    Brigadier General:
  • 6,966 Answers
This could be indicative of the built-in protection circuitry kicking in to prevent further damage to the unit. It has sensed a fault and therefore shuts the unit off. Alternately, it may be heat related. A component is heating up and triggering the unit to turn off.
Further diagnosis/repairs of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back the brand and model, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 04, 2008
  • 3 more comments
  • Louie  Role
    Louie Role Sep 04, 2008
    Hi again,
    Appreciate your comment/postback.
    All LCD type TV have multiple backlight (CCF lamps) that are powered by a high voltage/high frequency inverter. This inverter, the CCF lamps and the other electronics on the PCBoard of the HD LCD TV all produces considerable heat. This heat is detrimental to the operation of most (if not all) electronic components. Particularly prone to heat damage are the capacitors that would dry up, burst or simply fail to operate.
    Pls post back the brand and specific model
  • Louie  Role
    Got it thanks.
  • Louie  Role
    Perhaps you could try a check.
    When the picture goes black (but with sound), could you pls try shining a flashlight at an angle to the screen and see if there is a semblance of the video. You could also try pressing on the volume control while doing this and focus on the area where the volume level is normally shown.
  • Louie  Role
    That being the case and if you are considering a DIY, then the back cover of the unit has to be opened and voltage measurements done on the components. You may want to start checking the driver board.
    Otherwise, an onsite qualified professional or a service center maybe your best bet.
  • Louie  Role
    Since the unit operates normally but would develop picture fault after a few minutes, you could try improving the ventilation at the rear as you have posted or additionally/alternately, install temporarily a blower/electric fan. If the problem persists, then it is an internal problem, if length of time for the picture to be gone, then you have just confirmed that it is heat related.
TV was working fine earlier today. Now, when the TV is turned on, audio and video will be fine for the first 30 seconds, then everything goes black and audio cuts out. When this happens, a faint buzzi
this works for me.....hold down the off button on top of the tv for at least 5 seconds....(not the remote).....then try the remote on button
if it does not work the first time....try holding down the tv off button a bit longer
Jan 02, 2015 | Panasonic PT-56DLX76 Television
My ps3 is connected to tv via hdmi cable. After playing online i changed the game disc to another and now there is no picture on tv. there is the sound but no picture??? Any ideas? Thanks
Press and hold the power button until the system beeps.
Restart the system. This should default the audio and video settings to whatever cable is plugged in, which in this case is the HDMI port.
This should fix your sound issue.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Cant set up a ps3 with my tv, my tv is a sony picture in picture
Reset the video settings back to standard definition by holding the power button down for 5 seconds.
Jul 18, 2010 | Sony Playstation 3 (PS3) Console
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
Samsung 50" HD DLP TV video goes out
Common problem of a bad lamp call your local repair shop on price and availability of lamp.
Oct 22, 2009 | Samsung DLP HL-P5663W 56" TV
FIX for Vizio - no video or black lines or A/V inputs not working
TV needs to be reset. Unplug and while unplugged hold down power button on TV for 30 secs. Plug back in and it should work fine.
May 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
It has sound but no Picture
This is because of a resolution problem. Just hold the power button for 5 secs, it will reset the PS3 and you will be able to see the picture.
Apr 05, 2009 | Sony Playstation 3 (PS3) Console
No picture or sound
Dear friends,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Mar 11, 2009 | Cyberhome CH-DVD 300 DVD Player
No vedio output but audio is coming out
Dear friends,
Jan 18, 2009 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
