Question about Frigidaire ATF6000ES Front Load Washer
Spin bearing The drawings I viewed do not show a "spin bearing" Where would that be located? Do you have a drawing identifying this? Thanks. Brother Bill
  • 166 Answers
For this you need an experienced service tech with hands on experience!
Posted on Sep 07, 2008
1971 xw 302 V8 with bendo stromberg carb model WW. 2 ball bearings , 1 for the accelerator pump, the other goes where ?? - thanks wayne
both ball bearings are the inlet and outlet valves for the accelerator pump, In the workshop manual for your vehicle there will be a drawing showing the position of the balls.
Jan 22, 2015 | Cars & Trucks
How do I copy an excel sheet into word showing grid lines
Show or hide drawing gridlines Drawing gridlines appear only in Print Layout view.
  • On the View tab, in the Show/Hide group, select the Gridlines check box. " alt="Word Ribbon Image">
Sep 29, 2014 | Dell Computers & Internet
Transmission shifts fine but shifter spins
No big problem. Depending on your gearbox, it can be inside or on top. Best to speek to a vw dealer and you by and install the part yourself. The dealer salesman will show you on a drawing how to install. Very easy. Enjoy.
Apr 30, 2012 | 1998 Volkswagen Jetta
Intermittent sqealing engine runs quietly for a while, then more squealing. no overheating. friends tell me could be problem with water pump
Most likely a bearing on one of the engine pulleys, and probably the idler pulley. The best way to find out is to remove the belt and spin each pulley by hand. Listen for "roughness" or a grating sound. Try to move the pulley in and out to check for play. Little or no play is good. All should spin smoothly and fairly easy.
NOTE: Make sure you know how the belt goes on before you take it off. Draw circles on a piece of paper to match your pulley size and locations, then draw the belt around the pulleys exactly as it appears on the engine. Hope this helps....Let me know!!!
Aug 12, 2011 | 1996 Pontiac Sunfire
Ice maker not working-on off swich has burned area. do I need to have the entire ice maker replaced or just the motor part? Thanks Geri
You can replace just the switch. Do an internet search for appliance parts. Select a retailer and enter the model number of your refrigerator/ice maker. This will bring up information about how to identify and buy the part you need. They have very nice exploded view drawings available to help you easily identify the part you need.
Feb 05, 2010 | Frigidaire Refrigerators
Electric draw 6 plus amps
You have to identify which circut is the draw on. with a volt ohm meter set to mA setting you measure the the draw. remove the positive battery terminal and put the meter in series. if you have more than a 26mA draw you statr pulling fuses under thehood to identify the circuit. once the problem circuit is found find what component on the circuit is causing the draw. Good luck
Dec 11, 2009 | Dodge Durango Cars & Trucks
Heating element drawing lots of power, big bill power
Well a dryer heating element does draw quite a bit of amps(that is why it is 220) but it cycles on and off & it is not an appliance that is used everyday. The first think I would do is read the electric meter and verify that it was not misread before condeming the dryer. If the electric meter reads are correct then it is possible it could be the dryer heating element shorting. How much do you actually use the dryer? Is the heating in your house electric and have you been using it? You could also have your electric company test the meter. Look at your usage of electricity for last year at the same time(it will be on the bill) and see what the number was.
Oct 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Rear drum bearing
When it is like that you usually need to replace the drum bearing.
If the tub recently started making a lot of noise, and you can feel that the bearing had too much play when spinning by hand, that means that the drum bearing needed to be replaced.
You can find drawings and the schematics entering model number here.
Mar 07, 2009 | Hotpoint Dryers
Frigidaire ATF6000ES Front Load Washer Logo
24 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
