How to install generals zero hour in a computer, pls help, because i have 2 disc, when i insert the disc 1 it install but he does not asking for the disc 2, when disc 1 finished installing i insert the disc 2 but nothing happens i opened the game the game say's please insert the correct cd in the cd room...
install a virtual drive and configure your CD installer on a virtual drive. Once you want to play the game you must mount the virtual drive of your CD so that it will not ask for any CD.
try to download Alcohol for the virtual drive software.
Hope it helps thanks.
Zero is the expansion pack, do you have the original Generals game? if not it will not work.
What CD is it asking for?
Do you have the CD that you use to install with in the drive?
i am sorry to give u bad news, game CM is game that need disc to run the game because a lot of stuff that still need to run the program left behind in the disc. it was factory setting.
But u can use alternative way by make the disc to image then run it with daemon tool. first u need program that can make image file like .iso, .nrg, etc. ( i use nero) make an image file from CD 1 and CD 2 and save it in computer. second install program that can make image drive to run image disc (i use daemon tool). make one image drive then mount the image disc to the drive. now u can play without real disc. (after finished play the game unmount the image disc)
1. Disconect your printer from your pc
2. uninstall your printer driver from your pc
3. insert cd of your printer
4. run setup (with out connecting printer to pc untill setup ask you to)
i have installed crashday and also copied and pasted the exe file inthe place where the game has installed but still its asking to insert the cd or wrong disk inserted. please help me.
put disk 1 it should say type in a serial number wait for disk 1 to install then it should say insert disk 2 wait for that to be install after a message should pop up saying insert disk 1
You could try to renistallboth generals and zero hour. If that doesn't help, and you really want to play the game, you could try reinsaling Windows, because that then probably is the problem.
I hope this helps,
Yannick.
