Question about Xerox Office Equipment & Supplies
XEROX PHASER 6180 LASER ERROR 061-370. WHAT IS THIS?
  • Anonymous Mar 31, 2014
    Error 062-360 xerox 6180
  • 304 Answers
Chain Link 061-370 An error was detected in the Laser Unit.
Initial Actions
? Cycle printer power.
? If the problem persists, follow the procedure below.
Posted on Jul 11, 2011
    President:
  • 2,072 Answers
That is a laser fault. You should have a 1 year warranty from Xerox on that product. Call 1-800-835-6100 have your serial number ready.
Posted on Sep 04, 2008
3 Suggested Answers
  • 395 Answers
SOURCE: I have a Xerox Phaser
Here is the solution I found to match exact your model and error codes
Error code 093-951 is related to print cartridge crum error magenta
Solutions include:
If the printer is connected to a network, check the Print Cartridge level using CentreWare Internet Services (CWIS) and replace the cartridge, if necessary. See the Related Items below for additional information.
If the printer is connected to a computer via USB, replace the Print Cartridge, if necessary. See theRelated Items below.
To check the Print Cartridge levels using CWIS:
NOTE: If necessary, print a Configuration Report to obtain the IP address of the printer. See theRelated Items below.
  1. Open an Internet browser window.
  2. Enter the IP address of the printer in the Address field, and then press [Enter] on the keyboard. The CentreWare Internet Services window will be displayed.
  3. Click on the [Status] button. The Status window will be displayed.
  4. Click on the [Supplies] link. The cartridge levels will be displayed in the Toner Cartridgessection.
  5. If necessary, replace the Print Cartridge (you mentioned you removed the toner only, so check the level of toner to see if you need to replace it)
  6. When finished, close the browser window.
And
  • Power off the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  • Wait at least 10 seconds.
  • Power on the machine. Press the power switch to the (') position.
  • Error 52 means Remove the Duplex Unit (if installed), check for paper under the upper tray, and turn power off then On.
  • Hope this helps
  • Thanks
  • Posted on May 05, 2011
    SOURCE: I have a Xerox Phaser 6180. I have not had any
    I have 4 of these printers and when we print lots of manuals in full colour and duplexed the printers occasionally get to hot and need to cool down. After a 1/2 hour they are good to go again. I wouldn't worry about it, it happens only when it gets lots of use and I have never had anything go wrong with the printers after these errors
    Posted on Sep 25, 2011
    Xerox phaser 6180 has error code LPR and blue horizontal marks in background show up.
    Background is usually a cleaner unit fault, need to check out more on this point. Best to start from this point and try this to see if you can make changes.
    Good luck.
    Oct 06, 2014 | Xerox Office Equipment & Supplies
    Need Error codes for a Xerox Phaser 6180
    Anonymous,
    What exactly are you asking for here?
    Best regards,
    Jun 20, 2014 | Xerox Phaser 6180N Laser Printer
    Xerox Phaser 6280 Y CRUM ERROR
    The yellow cartridge either has a corrupted chip, or the wrong chip, or its a cartridge from a different model of printer.
    Xerox 6180 and 6280 cartridges LOOK the same, apart from the label and part number - the chip is different.
    Feb 08, 2013 | Xerox Phaser 6180N Laser Printer
    ERROR 093-951
    http://www.refillbros.com/en/manuals/p1643-xerox-phaser-6280-service-manual?page=199
    see this page for detail and how to repair
    i hope this helpfull, if you think this helpfull please rate very helpfull
    thanks for using fixya
    Jan 23, 2011 | Xerox Phaser 6180N Laser Printer
    My phaser 6180 transfer life repalce soon what is
    If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
    For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
    Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
    Xerox 6180 MFP N error 016-782 Windows 7 x64
    did you get a solution to this problem. i have the exact same situation.
    Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
    Phaser 6180 error code 033-762 Fax not recieving
    possibly junk fax feature is ON which assumes every fax you receive should have sender fax numer pre-registered, otherwise it just rejects the fax sent from an un-registered number
    Jan 05, 2010 | Xerox Phaser 6180N Laser Printer
    You more than likely need to place a service call.
    Over temp can be related to the fuser control circuits,
    Don
    Dec 15, 2009 | Xerox Phaser 6180N Laser Printer
    1,511 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
