Question about Systemax Venture PC Desktop
What are the prompts?
Thanks for the rsponse, however when I try to use the cd for recovery it goes to the screen where it asks for a password, I just hit enter and the it asks for a prompt to either reboot, or fxconfig and a whole list of other acronyms and I am simple lost. Do you think you can do a step by step outline ads to get through this?
  • Flokeayon Sep 05, 2008
    Hello I think I may have done something else wrong for when I am looking for my Lan connections after the restore it says it cant fin the Ethernet controller, is this not apart of the OS, or should it be on the restore cd? Do I need to restore and repair or what next?
    Genius:
  • 1,226 Answers
sorry for the late reply. I am not familiar with recovery console of the systemax, but i assume that all recovery disk are all the same.
can you show me a pic after you hit enter.
Do you know how to boot from cd? anyway booting from cd you can the information from your manual.
When using the the recovery disk, i think there are two option, either you retain the the original files only the windows system files will be deleted and restore and format the entire harddrive and refresh you system from first day you bought.
just insert your cd and boot your pc from cd rom and then you will be guided.
just tell me incase;
melnavz
Posted on Sep 04, 2008
  • Emelio Navaja
    Emelio Navaja Sep 11, 2008
    there is another cd labeled Cd utility or utility disk. You need it to install all that drivers in order to work the land card and all hardware which are needed to be functional.
Password Recovery,cannot get on to my Packard bell easy note as I cannot remember my new password and it isnr accepting my old one either, i have tried for almost 3 evenings to get on to it but it wont...
First you have to get administrator privileges (if you already do, Ignore this) but when starting up your computer get into recovery mode (Esc then F11, or whatever you have to do in the startup menu). If you have HP support on your computer, click the center panel and go into command prompt cmd prompt you cd to System32 folder on windows 7 (like C:\Windows\System32). you do that, then follow this order very carefully: copy cmd.exe cmd1.exe then rename sethc.exe sethc1.exe then rename cmd1.exe sethc.exe then get out of recovery mode, but typical people have NORMAL COMPUTERS. when you try to recover, hit cancel when asked about system restore. When the error message pops up, click on the details, open the text doc, and click save as. In that window, you browse to C:\Windows\System32 and basically do what you can do in the cmd prompt. copy cmd.exe, rename sethc.exe, then rename cmd.exe's copy to sethc.exe, then reboot normally. at the login screen, trigger sticky keys (hit shift many times) which brings up the command prompt. You can type explorer.exe in it to bring up SYSTEM's taskbar, which probably has internet explorer on it. That is the only browser that works on it. Warning: it may disappear randomly and make your computer slower. But SYSTEM has admin privs! do as you please. But to get your password changed, use the command prompt, type net user "USERNAME" * in order to reset your password. You are welcome.
Nov 19, 2013 | Exercise & Fitness
Toshiba a215 bios password then prompted for hdd password space bar enter didnt work
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Jul 27, 2012 | Computers & Internet
Black screen with white arrow
Step 1: Opening a command promptThis error prevents Windows XP from opening. This problem has to be addressed from a command prompt environment. Use the following steps to open a command prompt environment:
  1. Turn on the PC and press the F8 key repeatedly when the first screen appears.The Windows advanced options menu appears.
  2. Use the Up and Down Arrow and Enter keys to select Return to OS choices .
  3. Select Microsoft Windows Recovery Console .
    NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CD's, press the R key to open the Recovery Console.
    NOTE: If "Microsoft Windows XP Recovery Console" does not list and you do not have a CD with recovery console, try the following:
    1. Turn on the PC, and press the F10 key repeatedly at the first screen.
    2. At the Recovery screen, click Advanced Options .
    3. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
  4. When the log in prompt appears, press the number next to the windows version (min int or Windows) and type the log on password. Try pressing Enter if you do not know the password.
  5. At the command prompt, type the following: disk part
  6. Press Enter , do one the following:
    • If a table of volume names appears, remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO) and press the Esc key.
    • If a disk part prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
    NOTE: If the main drive volume name does not appear in the list, the PC needs to be recovered. For more information, refer to Performing a Full System Recovery in XP .
Step 2: Replacing the file from a backup folderUse the following steps to find and replace the L sass file from the command prompt environment:
  1. Type the following at the command prompt: CD X:\i386 (where X is the main drive letter)
  2. Press the Enter key. If the error The system cannot find the path specified appears, enter the following paths, in order, until the error does not occur:
    • cd X:\Windows\i386 (where X is the main drive letter)
    • cd c:\i386
    • cd c:\Windows\i386
  3. Press the Enter key, and type the following at the command prompt: expand lsass.ex_ X:\windows\system32 (where X is the drive letter)
  4. Press the Enter key, and type the following at the command prompt: cd X:\windows\system32 (where X is the drive letter)
  5. Press the Enter key, and type the following at the command prompt: attrib lsass.exe -r
  6. Press the Enter key, and type the following at the command prompt: rename lsass.exe lsass.bak
  7. Press the Enter key, and type the following at the command prompt: rename lsass.ex_ lsass.exe
  8. Press the Enter key, and type the following at the command prompt: exit
  9. Press Enter and the PC restarts without the error. If the error persists, go to the next step.
Step 3: Recovering the PC If the error still continues, recover the PC .
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 11, 2010 | Dell Inspiron 530s Desktop Computer
My dell 600 goes into the blue screen and Wont Load (Error mesg)
This is quite common, and easy to fix, I have included a link below to help you.
http://support.microsoft.com/kb/811014
Insert the Windows Recovery CD into the disk drive and reboot the computer.
Check the computer's boot order. This must be done from the BIOS set-up before boot begins. Pressing "F2" will start the BIOS set up on most PCs. (This is not always the case, and the boot screens will tell you which button will take you to the system set-up.) Make sure that your CD drive comes before your hard disk in the boot order.
Select the drive with the Windows installation you wish to repair when you see the menu to select a hard disk drives. If you have mistakenly swapped a Windows Installation CD for the recovery disk, enter the automated system recovery and place the recovery disk in the drive when prompted to do so.
Select the drive that needs to be prepared. You will be asked for the administrator password. Enter the administrator account password if one has been set up.
Type "expand d:\i386\ntoskrnl.ex_ c:\windows\system32." Windows is not case sensitive, but you must spell the commands correctly. This copies the ntoskernel.exe file to the approrpriate directory.
Press "Y" when the program asks if you want to proceed.
Enter the exit command and the reboot the system. Take the CD out of the drive and Windows should load correctly.
Feb 28, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
Blue screen help
Try doing this
1. Boot to your windows XP cd
2. On the welcome to setup screen press "R" to go to recovery console
3. It might ask to select a drive to letter something like that just choose the number represent "x:/windows" then press enter
4. If it asks for admin password just press enter (most system has a blank password for admin user as a default)
5. Type "chkdsk /r /p" on the command prompt
6. This might take 1-2 hours depending on your computer.
Hope this helps...
Jun 10, 2009 | IBM ThinkPad T23 2647 Notebook
Dell M70 laptop won't boot up
If you have a Windows installation CD, you can use the Recovery mode to attempt to fix the problem.
Turn on computer, insert CD into drive.
Press any key to boot from CD
Windows installation process will start
After a few minutes, a screen will come up telling you to hit ENTER to install Windows, or to press R to enter the Recovery Console
Press "R"
You will be asked which operating system
Most times there is only one option, select 1
At command prompt, type "fixboot" and press ENTER, if it asks if you're sure, type "Y" press ENTER again
Then, at command prompt, type "fixmbr" and press ENTER, again, type "Y" and press ENTER if it asks.
Type "exit" and press ENTER to exit recovery console and reboot.
Give that a try and see if it will boot for you.
Mar 08, 2009 | Dell Precision Mobile M70 Notebook
My friend has a HP Pavilion 533w and when we turn it on it goes threw the loading screens and then to a black screen and nothing happens you can move the mouse and see the pointer but nothing happens...
It is possible that the file Lsass.exe has become damaged or is not properly linked to the other files in the security system. Reset this file by using the following steps:
NOTE: If "Microsoft Windows XP Recovery Console" is not listed, restart the PC with a Windows XP CD, Recovery Console CD, or Recovery Tools CD in the top CD or DVD drive and open Microsoft Windows Recovery Console. If a Windows XP Setup screen appears when using Recovery Console CDs, press the R key to open the Recovery Console.
a. Turn on the PC, and press the F10 key repeatedly at the first screen.
b. At the Recovery screen, click Advanced Options .
c. Press the Alt + D keys at the same time to open a command prompt window and skip to step 5.
4. When the login prompt appears, press the number next to the windows version (minint or Windows) and type the logon password. Try pressing Enter if you do not know the password.
5. At the command prompt, type the following: diskpart
  • If a diskpart prompt appears, type list volume , press Enter , remember the drive letter next to the main drive volume name (usually D or H next to HP_PAVILION or PRESARIO), type exit when done, and then press Enter .
Dec 26, 2008 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
RE: WINDOWS XP
Have you tried starting it with a XP recovery disk??
Jun 18, 2008 | Microsoft Windows XP Home Edition
I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
  1. Watch for a Press any key to boot from CD... message similar to the one shown above.
  2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
Enter the Administrator Password
The Recovery Console now needs to know the administrator password for this Windows XP installation. Unless you are using a PC in a sizable business network, the administrator password is most likely the same password you use to access Windows XP on a daily basis.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
  1. When you reach the command prompt (detailed in Step 6 in the link above), type the following command and then press Enter.
    bootcfg /rebuild
  2. The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
    Type Y in response to this question and press Enter.
  4. The next prompt asks you to Enter Load Identifier:.
    This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  5. The final prompt asks you to Enter OS Load options:.
    Type /Fastdetect here and press Enter.
  6. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
    Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
May 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Dell reinstallation CD XP admin password
When you get to the command prompt use chkdsk to attempt the repair of your blue screen. Type this in the command line:
chkdsk c: /r
Apr 18, 2008 | Dell Microsoft Windows XP Home Edition
Systemax Venture PC Desktop Logo
80 people viewed this question
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
